Road bike conversion 350W with in-frame batteries
DvH   1 µW
Post by DvH » Jun 24 2019 2:42am
Hi, i would like to share my 1st E-bike build. Tried to have it as minimalistic as possible. Spec:
Shimano TACX road bike
Aikema 350W rear hub motor, in 700C wheel. 6S06 controller
Battery 10S2P configuration. 21700 type Samsung 50E. Divided in 3 separate packs to fit in the tubes of the frame: 2x7 + 1x6 with BMS (more than enough to do the 25km commute)
Thumb throttle only
Total weight 15 kg
Motor assist up to 41 km/h
Einsgruber   10 µW
10 µW
Re: Road bike conversion 350W with in-frame batteries
Post by Einsgruber » Jun 24 2019 6:21am
:D :D :D wow this is a lush build... Ive been planing something like this for my bike which is similar
https://www.bikeradar.com/news/boardman ... lideshow=1
I just need to find a small enough hub like the Aikema 350W but that has a disc adapter If you don't mind me asking where did you source yours and is it 24 or 36v?
Many thanks
E-HP   10 kW
Post by E-HP » Jun 24 2019 9:22am
Can you share more details about how you got the batteries into the frame tubes?
DvH   1 µW
Post by DvH » Jun 24 2019 10:33am
The battery cells are inserted via holes in the front vertical tube with removed stem. The 3th one goes in the tube with removed seatpost. Not the best servicability but we’ll see...
Drunkskunk   100 GW
Post by Drunkskunk » Jun 24 2019 11:15am
That is impressive.
E-HP   10 kW
Post by E-HP » Jun 24 2019 11:45am
DvH wrote:
Jun 24 2019 10:33am
Cool. I guessed the seatpost part looking at your cable routing, but wouldn't have guessed the top tube part of the pack. Is that little circuit board in the bag the controller?
icherouveim   1 kW
Post by icherouveim » Jun 25 2019 7:26am
Great Job!
Now you can race your friends or other bicycles without for them to know!
JimmyJazz   1 mW
Post by JimmyJazz » Jun 25 2019 2:50pm
Very nice -- clean & subtle. I've always wanted to do the battery-in-frame, but I think you're the first DIYer that I've seen actually do it.
Matador   10 kW
Post by Matador » Jun 25 2019 9:24pm
What he said ^
Super nice stealthy eBike!
Thumbs up!👍
DvH   1 µW
Post by DvH » Jul 19 2019 3:52am
Had Some issues with the tire alignment on the new rim so decided to respoke the motor into the original rim. Problem solved and looks better too..
E-HP   10 kW
Post by E-HP » Jul 19 2019 10:35am
DvH wrote:
Jul 19 2019 3:52am
Blend in even more. :thumb:
How do you charge (in bike?)?
flat tire   1 MW
Post by flat tire » Jul 19 2019 12:02pm
Nice battery. Very creative. Your next mod should be a seat tube motor that connects to a special bottom bracket for total stealth. You can buy that off the shelf actually search "seat tube motor". It goes INSIDE the seat tube.
DvH   1 µW
Post by DvH » Jul 21 2019 2:27pm
E-HP wrote:
Jul 19 2019 10:35am
There is a charge connector inside the saddlebag, where also the BMS and controller are placed
cwah   10 GW
Post by cwah » Sep 22 2019 10:41am
Looks nice.
How harder is it to ride?
Turbotd04   10 mW
Post by Turbotd04 » Sep 30 2019 2:34pm
Nice! Proper stealthy
