Non-overclocked Vector Light Build
Show off your Ebike creation here.
Overclocker   10 kW
Post by Overclocker » Jul 01 2019 10:20pm
as the title suggests this will be a somewhat "low" power build but i'll still try to maximize the thermal capacity of the hub motor which would be the QS 205 35H 5T winding https://www.aliexpress.com/item/32816512376.html
inspired by skeetab's build w/ the funny frame color :lol:
also ordered the Kelly KLS7230S https://www.aliexpress.com/item/32888145048.html
bottom plate is scratched up. is this normal?
adapter cable has bare wires coming out :roll:
shall be using parts i have lying around:
-Marzocchi drop-off triple 170mm travel
-Rockshox sektor gold 150mm travel
-Marzocchi roco 220mm 300lbs spring
-DNM rcp-2 220mm 550lbs spring
will try 2 wheel size combos:
1) 26" front, 26" rear
2) 24" front, 17" moto rear
skeetab5780   10 MW
Re: Non-overclocked Vector Light Build
Post by skeetab5780 » Jul 03 2019 5:51am
Sub'd Need more battery space for that monster controller! Have fun on your build I like this frame and parts list
Overclocker   10 kW
Post by Overclocker » Jul 03 2019 10:18am
i'm taking a gamble w/ these cheap (PHP95 or USD1.86 per piece, landed) chinese cells made by JSZH (jiangsu zhihang new energy). i've cycled a cell and got 97.8% after 152 cycles :shock: that's pretty good cycle life!
3A discharge curve compared to samsung 26F
here's the raw data from the cycle test. in retrospect i set the LVC too low at 2.5V :lol: if you look at the discharge curve it begins to fall off the cliff at around 3.2v. but this didn't seem to hurt the cell at all :lol:
Code: Select all
JSZH 18650 2600mah TEST!
charging time: 2:06 == 126 mins
rest: 0:05
discharging time: 0:54
rest: 0:05
TOTAL: 190 mins == 3.16~hrs per cycle
1.5a charge, 3.0a discharge, 2.5v cutoff
1 cycle: 2711mah
10: 2704
14: 2681
18: 2726
22: 2710
27: 2690
33: 2685
36: 2690
39: 2688
42: 2702
45: 2696
48: 2701
51: 2693
54: 2678
57: 2665
60: 2700
63: 2666
66: 2677
69: 2690
72: 26xx
75: 2659
78: 2661
81: 2658
84: 2644
87: 2671
90: 2666
93: 2665
96: 2655
99: 2668
100: 2665
101: 2663
104: 2660
107: 2661
110: 2656
113: 2651
116: 2660
119: 2657
122: 2649
125: 2619
128: 2636
131: 2609
134: 2643
137: 2650
140: 2645
143: 2646
146: 2643
149: 2646
152: 2651
Overclocker   10 kW
Post by Overclocker » Jul 07 2019 1:41am
working fine. i'm a kelly noob btw. the pink #7 wire sparks when i connect to B+. apparently that's normal based on the other threads i've read. kelly's wiring diagram also doesn't specify a precharge resistor for the pink wire
speaking of precharge the 1kohm that's included charges way too slowly. i guess xt90-s is OK to use? 17s pack btw, 71.4v max
Overclocker   10 kW
Post by Overclocker » Jul 15 2019 2:03am
i'm posting this high-res drawing w/ the numbers to punch into your spoke calculator:
qs 205 35h v1.jpg (225.94 KiB) Viewed 4460 times
frame should be arriving soon. can't wait :lol:
Overclocker   10 kW
Post by Overclocker » Jul 17 2019 2:50am
IMG_20190717_110954 (Medium).jpg (139.12 KiB) Viewed 4401 times
IMG_20190717_123613 (Medium).jpg (115.8 KiB) Viewed 4401 times
IMG_20190717_123911 (Medium).jpg (117.88 KiB) Viewed 4401 times
IMG_20190717_124447 (Medium).jpg (128.32 KiB) Viewed 4401 times
frame is here! seems like this is the latest revision :thumb: headtube accepts tapered fork (the included headset accepts both tapered and straight steerers). dropouts are clamping.
thanks Artur for this great frame!
Overclocker   10 kW
Post by Overclocker » Jul 19 2019 12:12am
strange knurling inside the head tube...
IMG_20190718_214732 (Medium).jpg (252.25 KiB) Viewed 4334 times
also strange that Vector decided to use a full 1.5" headtube. forks that use straight 1.5" steerers are quite rare. the "integral" type headtube is simple to machine, lighter, and accepts tapered forks using an appropriate bottom cup
Overclocker   10 kW
Post by Overclocker » Jul 21 2019 4:31am
IMG_20190721_153555 (Medium).jpg (284.77 KiB) Viewed 4286 times
geometry seems OK w/ this configuration. 26x2.35" front, 17x2.5" rear. i want as small rear wheel as possible since this is a DD hub. if it looks awkward i will go w/ 24" front wheel and the longer dual-crown Marzocchi to maintain more or less the same geometry (the 24" will drop the axle around 1" but the Marz should compensate by having a longer axle-to-crown)
Overclocker   10 kW
Post by Overclocker » Jul 23 2019 5:46am
i went ahead ang ordered 110mm (off the shelf size)
j bjork   10 kW
Post by j bjork » Jul 29 2019 3:33pm
Nice work so far, it will be interesting to see how it continues :)
Overclocker   10 kW
Post by Overclocker » Aug 02 2019 1:31am
IMG_20190802_130310 (Medium).jpg (135.75 KiB) Viewed 4072 times
31.8mm is the correct seatpost size. fyi...
Overclocker   10 kW
Post by Overclocker » Aug 10 2019 3:47am
IMG_20190810_142900 (Medium).jpg (213.37 KiB) Viewed 3996 times
the Grin (www.ebikes.ca) spoke calculation was spot on :thumb:
j bjork   10 kW
Post by j bjork » Aug 10 2019 9:59am
Nice, but you seem to get some bend in the spokes? I plan to have one out, one in of the crossing spokes on my wheel build. But we will see how it goes.. Where did you buy the spokes?
Overclocker   10 kW
Post by Overclocker » Aug 12 2019 2:40am
the spokes are from greentime. slight bend is OK. i'll retension after they bed in
here it is w/ 26" front and 17" rear. IMHO it doesn't look too awkward especially when you consider the benefits of having a small rear wheel in a DD hub (and also the advantages of having a large front wheel)
pwd   1 kW
Post by pwd » Aug 12 2019 9:01am
Nice looking build so far. The wheel diameter difference doesn't look bad at all.
Commuter/Street Build viewtopic.php?f=6&t=98286:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
Samsung 40T 14S7P
Offroad Build viewtopic.php?f=6&t=102195:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 36T chain ring then 32T chain ring to 11T-46T Cassette
em3ev 14S5P 30Q or 14S6P 25R pack
skeetab5780   10 MW
Post by skeetab5780 » Aug 13 2019 6:08am
Looking real good! How does it ride?
Overclocker   10 kW
Post by Overclocker » Aug 13 2019 11:18am
skeetab5780 wrote:
Aug 13 2019 6:08am
right now? probably heavy to pedal :lol: BMS arrived today will build the pack asap. i also got some lower profile bolts to increase the internal dimension
IMG_20190813_002830 (Medium).jpg (178.51 KiB) Viewed 3893 times
IMG_20190813_234907 (Medium).jpg (246.38 KiB) Viewed 3893 times
pwd   1 kW
Post by pwd » Sep 12 2019 2:54pm
That is a beautiful looking battery pack. What is the max current you plan on drawing from it?
Samsung 40T 14S7P
Overclocker   10 kW
Post by Overclocker » Sep 14 2019 1:19am
pwd wrote:
Sep 12 2019 2:54pm
thanks. 40A max
Overclocker   10 kW
Post by Overclocker » Sep 21 2019 9:30am
stainless is a bitch to tap
skeetab5780   10 MW
Post by skeetab5780 » Sep 23 2019 3:00pm
Ouch! I would have taken a ride to the hardware store :)
hats off to you
Overclocker   10 kW
Post by Overclocker » Sep 24 2019 10:56pm
skeetab5780 wrote:
Sep 23 2019 3:00pm
hats off to you
haha but i did! they didn't have the exact size. it's a good opportunity to use the tap & die set anyway, these dies (dice?) get rarely used.
finally got it running! the KLS7230 is too big (obviously) for this build :lol: both in terms of amps and physical size :lol: i might a KLS or KBS mini. i like that these controllers can read the KTY-something-something sensor inside the hub to protect the hub from frying. i hit over-temp twice during this short ride
IMG_20190925_103746 (Medium).jpg (387.03 KiB) Viewed 3364 times
