Non-overclocked Vector Light Build
skeetab5780   10 MW
Re: Non-overclocked Vector Light Build
Post by skeetab5780 » Sep 25 2019 11:33am
Looks cool with the battery showing thru the side panel, be careful of a short! would hate to try to pull that battery out in flames! I always think of that when there are 10x screws locking it in place inside the frame.
I'm sure its a ton of fun with that controller, but make sure you have enough power when you go to buy a mini replacement, maybe a KBSX72151X
Overclocker   10 kW
Post by Overclocker » Sep 26 2019 10:29pm
skeetab5780 wrote:
Sep 25 2019 11:33am
IMG_20190926_172635 (Medium).jpg (278.66 KiB) Viewed 882 times
i bonded the cells to a caddy which is a precise fit inside the vector's compartment. then i placed a few strips of rubber foam so that when you screw the metal cover it holds the pack in place to keep it from sliding forward.
i now like to build packs w/ open sides for ventilation. but i'll definitely reinstall the vector's side covers when i'm done testing...
skeetab5780   10 MW
Post by skeetab5780 » Sep 27 2019 6:20am
it certainly looks powerful, hows it go on those flats this is where the hub motors shine!
Overclocker   10 kW
Post by Overclocker » Oct 11 2019 11:08pm
skeetab5780 wrote:
Sep 27 2019 6:20am
those are the volcanic sands coughed up by Mt. Pinatubo in the early 90's (which cooled the earth by about a degree). this hub does well on pavement and hardpack. but terrible off-road :lol: so it's never going to replace my BHT bike
btw the caliper mount on the Vector is a bit wonky. requires a weird combination of adapters to get the alignment right
IMG_20191011_105634 (Medium).jpg (191.48 KiB) Viewed 801 times
none of these adapters work:
IMG_20191011_214620 (Medium).jpg (212.96 KiB) Viewed 799 times
Overclocker   10 kW
Post by Overclocker » Oct 17 2019 5:29am
IMG_20191017_100909 (Medium).jpg (203.7 KiB) Viewed 768 times
added kickstand and rear cargo rack
Overclocker   10 kW
Post by Overclocker » Oct 21 2019 2:20am
Overclocker   10 kW
Post by Overclocker » Nov 11 2019 10:15pm
new custom crankset w/ short 152mm arms. i'm getting pedal strikes w/ the "normal" 175mm arms. also added a 48t chainring because 152mm cranks NEVER come w/ 48t :lol:
short arms ideal for ghost pedaling :lol:
Overclocker   10 kW
Post by Overclocker » Jan 19 2020 5:29am
the 26" front wheel was too big so i went 24". this dropped the axle height so i needed a longer fork to maintain the same geometry. good thing i got a marzocchi dropoff triple, lying around
