Vector white lightning
jordison   10 mW
Post by jordison » Jul 06 2019 3:37pm
Just thought sharing my build.
It's a vector light and I replaced the battery cover to fit a bigger battery.
Specs:
Mxus 3k 3t
Kelly kls72180
24" wheels
72v 30ah vtc6 (diy)
Fork marzocchi
kfleungxnyc   10 µW
10 µW
Re: Vector white lightning
Post by kfleungxnyc » Jul 06 2019 7:31pm
Great build !
Where did you get your fenders ? Is the rear one attached to a fixed plate coming off the frame ?
jordison   10 mW
Post by jordison » Jul 07 2019 7:44am
Thanks.
The fenders are some cheep ones from decathlon, I gave it some heat to mold them to suit the 24"s. At the moment there's no fixed plate, just fixed it to the swing arm, just plastic, needs to be reinforced though, it's to wobbly right now
ben.katz.1992@gmail.com   1 µW
Post by ben.katz.1992@gmail.com » Jul 12 2019 5:44pm
jordison wrote:
Jul 07 2019 7:44am
Thanks.
Try these: https://www.aliexpress.com/item/3295505 ... 4c4dwjcBOr
flat tire   1 MW
Post by flat tire » Jul 12 2019 5:55pm
Trim steerer tube.
JimmyJazz   1 mW
Post by JimmyJazz » Jul 14 2019 9:44pm
Dumb question -- compared to a normal bicycle with a typical tube frame, do these wide frame e-bikes feel strange to pedal? Is the bottom bracket significantly wider? Are your feet, knees & thighs splayed out somewhat? Do your legs rub the frame whilst pedaling?
Edit: Awesome looking ride, btw. Very clean and professional.
devo1223   100 W
Post by devo1223 » Jul 16 2019 3:10pm
200 cells??? nice job, will you provide more detail on how you made the battery cover? How many watts? What is your top speed?
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
jordison   10 mW
Post by jordison » Aug 07 2019 8:48pm
The battery cover I just asked a local shop to build it since they have the proper tools.
Glued together it could fit more than 200cells.
Max power is 8kw
Top speed is 85kph, will be less with the 17" rim.
The rear wheel has the spokes all bent and already broke 3of them, so I will be building a 17" wheel soon with Heidenau K36/1 2.50 tire, later I will do the front one.
The crazy bob are not good at all in the rain and heat quite a bit on the dry.
Pedal? You don't pedal this things, I just move my feet so I don't hear "hey were is your number plate?". At the moment I don't even have a chain.
I have a wider BB just to make sure I don't touch the frame.
jordison   10 mW
Post by jordison » Sep 18 2019 1:56pm
Finally I changed the back wheel for a 17", I really like the new look
Gained some weight, lost some top speed, but the tire offers so much more than bicicle tire
kfleungxnyc   10 µW
10 µW
Post by kfleungxnyc » Sep 18 2019 2:02pm
That looks awesome ! Nice work.
Is your kick stand just bolted straight onto the frame or do you have an adaptor plate ??
jordison   10 mW
Post by jordison » Sep 18 2019 3:50pm
kfleungxnyc wrote:
Sep 18 2019 2:02pm
Thanks.
Has an adaptor plate.
Bg-electric-cycle   100 mW
Post by Bg-electric-cycle » Sep 28 2019 2:37pm
Very nice build love the drop out from the main frame to increase battery pack size. What’s your pack details beyond 200 cells?
jordison   10 mW
Post by jordison » Oct 02 2019 1:55pm
Bg-electric-cycle wrote:
Sep 28 2019 2:37pm
Sony vtc6
Honeycomb spacers.
I used 1 layer of nickel and soldered copper wire on top of the nickel
I wanted to fuse every cell but found it a bit difficult
