Page 3 of 3
Re: Xtracycle Build Log
Posted: Dec 19 2020 9:22pm
by dequinox
I actually do have one. That's how I'm determining watt hours used. It's like 9 years old and still ticking.!
Posted: Dec 20 2020 11:40pm
by amberwolf
neptronix wrote:
Dec 19 2020 4:33pm
A turnigy watt meter ( ~$25 ) is a nice ghetto alternative to a cycle analyst.
Not for this purpose--it can't modify the throttle signal based on settings to "alter" (reduce) the current limit of a controller.
Posted: Feb 22 2021 12:10am
by dequinox
OK, so a little update on what's been done recently:
-New custom sewn "freeloader" bags installed.
-Front and rear derailleur installed, functions ok.
-Rear freewheel Had to be spaced out from the hub motor a bit to allow it to shift into lowest gear
-Front BB7 caliper installed (got a used version, no torx bit on the inside adjustment, I highly recommend getting the newer versions)
-New handlebar & grips are in
-New rear tire (one that came with the hub-motor/wheel had a significant crooked section in it, whole bike fishtailed every rotation)
To-dos:
-Make running boards for the xtracycle frame (kids need a place to put feet that isn't my panniers)
-Mount rear BB7 brake
-Tune the BB7 brake up front, feels like it's under-performing
-New seat
-Better position the computer
-Splice in the plug to the old throttle into the new one (going from half-twist to thumb)
-New pedals
-Make a chain idler system similar to this
-Re-mount the hailong battery with a reinforced plate similar to Justin's triple-bob plate
-Relocate controller and clean-up wiring
-Get no-load max rpm value, run grin simulator to determine where my efficiency should be
-Mount headlight
-Finish mounting rear fender
Issues:
-Chain can fall off the largest sprocket on the freewheel
-Front brake under-performing
-Spokes on rear wheel likely need re-tensioned
-Budget update:
Purchased:
-$15 frame
-$62 fork
-$140 free radical
-$20 xtracycle wood deck
-$80 rear 1000W motor kit 26"
-$40 paint job
-$23 disc brakes kit
-$35 Headset
-$24 bottom bracket
-$12 grips
-$75 front wheel
-$7 front derailleur
-$25 rear derailleur (old one was shot)
-$65 avid BB7 calipers
-$418 52v hailong style battery with samsung cells, ebay (seller: cowellcowinbattery ... relatively new, they had a small mess up that cost me some time, but they made it right (sent wrong battery by mistake)
-$0 Custom pannier bags (thanks mom!)
-$55 New rear tire, Schwalbe marathon plus
TOTAL: $1096 all-in so far. I might be missing cable ends, housing, and the sort... but really that totals about $20 or so.
NOW, photos:
TGB 2.jpg (257.2 KiB) Viewed 337 times
As an aside: These old-ass BB7s do not have the torx fastener that you can adjust with a t-wrench... ANNOYING.
bb7 inner.JPG (134.3 KiB) Viewed 337 times
That is all for now. It's finally coming together!
OH- and my daughter tentatively titled the projec "The Green Bean" ... I think it's going to stick! :lol:
Posted: Mar 05 2021 1:11pm
by dequinox
Progress:
-Tuned the BB7 brake up front, feels like it's under-performing
-Spliced in the plug from the old throttle into the new one (going from half-twist to thumb)-->not so happy with this one.
-New seat ordered
-New pedals ordered
-Finished mounting rear fender, mostly.
-Got no-load speed of 70kph, need to do the calc for circumference, but that's tire/wheel dependent. I need to do a GPS run and compare it to the computer's value, that should get me a correction factor that's fairly accurate. Either that or get an RPM-meter ...
-Re-mounted the hailong battery with a reinforced plate similar to Justin's triple-bob plate
hailong brkt.JPG (45.21 KiB) Viewed 298 times
To-DO:
-Mount headlight
Made progress on the to-do list with an item that was not on it: Make a new front attachment plate, or FAP.
This is the part I'm copying, because it's either too expensive or to hard to get a hold of one. So I at first made a delrin one with my table-saw:
FMP Delrin.jpg (183.03 KiB) Viewed 303 times
It was plastically-deforming (yes, that's a pun), so it was time to upgrade to a new one. I got a non-ferrous metals blade for my saw some time back, and decided it was time to give it a go:
FAP Alum & Delrin.jpg (220.63 KiB) Viewed 303 times
It works fairly well, and enables someone with an average shop tool to do some basic machining. A bit of filing after and it's pretty much done. I want to take out some weight by cutting a profile as below, then will probably powder coat it.
FAP cutout.JPG (109.37 KiB) Viewed 303 times
I also wound up finding a score on some "Footsies" for my kids to put their feet on for $15!
Up next is to:
-Put on brand new BB7s, I kind of hate the old ones.
-New seat
...everything else on that last list :lol:
Posted: Apr 03 2021 2:56am
by dequinox
amberwolf wrote:
Dec 19 2020 2:05am
You don't really need to know the specific winding...
Once you know the unloaded RPM, you can guesstimate the loaded RPM as around 80% of that...
But with the RPM you can try to match a similar motor on the simulator to use as a stand in for yours when experimenting with the simulator to find a more optimal setup.
I got the no load RPM and voltage/current, which came out to 10.00KV on the nose. Running a custom motor with similar KV and the default winding resistance, I'm getting a simulator value of 27wh/mi at 75% throttle 52v. Right now I'm getting 40+, so something seems wacky. I have a hunch it's this craptastic controller, which is only good to 13A. I can get to 30mph, but only just. Once i get the new brakes on I'll give it a try for another efficiency measurement. Then I'll maybe have a good idea of what this system is capable of.
Posted: Apr 26 2021 4:04pm
by dequinox
I am having a pretty severe concentricity issue with the rear hub-motor-wheel and its tire. This problem was present on the previous cheap tire that came with the wheel motor kit, so I think that's some evidence ruling out tire manufacture error to a reasonable degree.
Any input would be helpful. I took the tire off the rim and inspected the inside for possible manufacturing defects on the rim, but didn't spot any. I will take another look at it as soon as I can, as I feel I might've missed something. External dimensions on the rim are pretty consistent (rim braking surface-to-surface) when measured with a caliper.
Here's a video of the issue:
Posted: Apr 26 2021 4:10pm
by dequinox
After a little hunting, I found this page. It details what to do if the bead is sitting too low, so I'll try some extra high tire pressure when I get home. I've ridden on it for miles with the offset and it hadn't self-corrected, so I was sure there was some sort of manufacturing defect with the rim bead surface.
Posted: Apr 27 2021 8:55am
by dequinox
Welp, I tried soaking the Schwalbe tire in soap and going clear to 70psi, massaging it as it inflated, and multiple inflations, but i could not get that tire to seat.
I tried the cheap tire that came with the kit again using the same techniques, aaaaand now i have a fully seated tire. Huh. What the hell Schwalbe?
I have to try to return it now... where's that damn receipt... :pancake:
Posted: May 03 2021 1:09pm
by dequinox
I managed to snap the old tire into place properly for now. I will make another attempt at the Schwalbe this week and see if I can get it to go. My spokes still need re-tensioning I believe, so I'll be putting it back on the table for that soon.
Other than that, the little 4 bob support plate I 3d-printed seems to do really well at holding the hailong battery on. Right now it's only in place with the two bottle cage screws, but I have an updated version I still need to print (out of a less heat-sensitive plastic than PLA) that will allow for hose-clamps to go over it.
I'm finding the chainrings I have up front are far too small for my pedaling cadence to keep up at 45kph! I'll need to get some bigger chainrings up front, but that's not a huge issue.
The throttle I bought has issues, namely a very narrow range of input. I'm either too slow or full bore. Hard to get any throttle values in between. If anyone knows of a source for a good high-quality no-LED thumb throttle, I'd love to see it.
I also need to install a switch for activating the PAS. You'd think it would be smart to include a button-driven function on the controller LCD display to turn that on and off, but as it is if it's plugged in PAS is on, which is annoying. It's not like you can turn the assist level to 0 and just use the throttle either, as 0 turns off the throttle as well! That's all for now I believe... need to get a headlight system in place and re-adjust brakes/derailleurs a little but that's about it. This one's almost done!
Controller re-positioned into the free radical attachment arm. Not sure if this is permanent yet... probably will do a cover and mounting plate of some sort.
TGB Controller mount.jpg (198.2 KiB) Viewed 143 times
Posted: May 03 2021 9:12pm
by 99t4
dequinox wrote:
May 03 2021 1:09pm
Is your controller programmable? You may be able to dial in the throttle or otherwise better tune the controller's reaction to it.
Posted: May 04 2021 1:31am
by Chalo
dequinox wrote:
May 03 2021 1:09pm
Are you using the Wuxing 130X throttle?
If so, it's pretty abrupt and insensitive. I've gotten much better feel and definition from the Wuxing 108X paddle type throttle:
Note that the 130X can be used on the left or right, but you have to get the 108X in one version or the other.
Posted: May 04 2021 12:06pm
by dequinox
Sadly it's not. Just a cheapo brushless, nothing special about it. At least I don't think so...
The throttle didn't become a problem until I switched to the Wuxing 130 Chalo mentions above.
99t4 wrote:
May 03 2021 9:12pm
dequinox wrote:
May 03 2021 1:09pm
Posted: May 04 2021 12:07pm
by dequinox
Thanks for the suggestion! Yes, the problem with the 130x (which I didn't know that was until you mentioned it) is that it's dead, then abrupt near the full throttle. I'll give that other model a try.
Chalo wrote:
May 04 2021 1:31am
Posted: May 05 2021 2:12pm
by dequinox
Purchased a new throttle, the 108X, which should show up later this week.
I'm noticing that I get about 30% higher energy consumption than my RBF Cruiser with this bike. My cruiser gets around 30 Whr/mi, whereas this one gets about 42 Whr/mi with similar weight and throttle aggressiveness. I notice significantly higher spinning resistance (push wheel with a finger and see how long it takes to stop) than my RBF Cruiser as well... what causes might this point to?
Posted: May 07 2021 9:50am
by Chalo
dequinox wrote:
May 05 2021 2:12pm
Too-tight axle bearings, or a dragging brake pad. In neither case would it make a difference in Wh/mi efficiency, but in both cases it would dramatically increase wear of the affected component.
30% difference in efficiency between your two bikes probably indicates one of two things: either a major difference in aerodynamic qualities (mainly riding position), or a difference in average speed. Motor efficiency and mechanical losses might differ, but not by nearly that large a margin.
Posted: May 07 2021 10:18am
by dequinox
Chalo wrote:
May 07 2021 9:50am
[/quote]
I'm not entirely sure it's aero, as I tuck when I go over 25 on both vehicles. Both have similar top speeds, though slightly different acceleration feel. I kind of attributed the latter to the front vs rear wheel difference. It really does feel as if there's drag of some sort on the rear... so I'm thinking bearing. I've ruled out the disc rubbing already through inspection. I'm leaning toward a screwy bearing or some sort of shenanigans with the rear axle/motor.
Posted: May 07 2021 10:24am
by Chalo
dequinox wrote:
May 07 2021 10:18am
Chalo wrote:
May 07 2021 9:50am
Note that moving through air at 28.5 uses 30% more power than it does at 25. It could be as simple as that.
Posted: May 07 2021 10:26am
by dequinox
Chalo wrote:
May 07 2021 10:24am
That's true, however I do ride at nearly 30 on both vehicles :lol:
I do need to verify the weight too though, the xtracycle is all steel and my cruiser is aluminum.
Posted: May 17 2021 11:43am
by dequinox
Well shart. :evil:
The Green Bean broke down yesterday... Something in the motor-controller system. Went to accelerate across a road and the power cut out followed immediately by MASSIVE cogging torque slowing my momentum down. The display read "error 6" also... Which I have yet to interpret. I haven't a manual. It felt like the leads to the motor were shorted. I'm leaning toward a controller failure, but will know more when I tear it down. I'm the meantime I'm going to rest the motor with a spare controller I have, then send it out for spoke re-tensioning. I've not been able to get that right myself.
