Neematic clone
Amateur   10 mW
Neematic clone
Post by Amateur » Aug 07 2019 10:08pm
Let me know what you think D135RAG 60 38120 headway......and a homemade buck chopper 60 hrs so far....
2019-08-07 21.17.36.jpg (253.28 KiB) Viewed 1620 times
2019-08-07 21.18.47.jpg (383.13 KiB) Viewed 1620 times
2019-08-07 21.19.28.jpg (415.59 KiB) Viewed 1620 times
2019-08-07 21.19.54.jpg (353.18 KiB) Viewed 1620 times
2019-08-07 21.20.16.jpg (243.73 KiB) Viewed 1620 times
2019-08-07 21.20.44.jpg (297.86 KiB) Viewed 1620 times
2019-08-07 21.21.04.jpg (317.64 KiB) Viewed 1620 times
2019-08-07 21.21.35.jpg (397.66 KiB) Viewed 1620 times
2019-08-07 21.21.59.jpg (377.53 KiB) Viewed 1620 times
2019-08-07 21.22.27.jpg (217.15 KiB) Viewed 1620 times
2019-08-07 21.22.52.jpg (216.96 KiB) Viewed 1620 times
2019-08-07 21.23.15.jpg (467.08 KiB) Viewed 1620 times
amberwolf   100 GW
Re: Neematic clone
Post by amberwolf » Aug 07 2019 10:11pm
Amateur wrote:
Aug 07 2019 10:08pm
What?
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 07 2019 10:12pm
Are you able to see the pictures?
efMX Trials Electric Freeride   1 MW
Re: Neematic clone
Post by efMX Trials Electric Freeride » Aug 07 2019 10:14pm
link??
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
amberwolf   100 GW
Re: Neematic clone
Post by amberwolf » Aug 07 2019 10:18pm
Amateur wrote:
Aug 07 2019 10:12pm
You don't have any pictures attached to the post, and you don't have any links to pictures in your text, so there aren't any pictures to see.
You do have an attempt to make your text gigantic, which there is no reason to do. Thankfully you didn't put any text between the size markers so your text remains normal-sized and readable.
If you click the Attachments tab below the box you type the text in, you can directly upload the picture files, and then anyone that can see the post can see the pictures.
If you use external site links, then 1) only those with access to the site (not everyone, depends on their location and their provider, etc) can see the pics, and 2) when the site changes or goes away all the pics are lost, and the thread is left orphaned and useless (especially because the text you do have in your post doesn't have enough detail to make sense).
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 07 2019 10:29pm
He thinks Amber wolf I appreciate that!!! this is the forum have admired for longest time. and now i have something contribute!
Re: Neematic clone
Post by efMX Trials Electric Freeride » Aug 07 2019 10:39pm
looking good now .. nice work:)
amberwolf   100 GW
Re: Neematic clone
Post by amberwolf » Aug 07 2019 10:48pm
There we go! :)
Looks good so far; is that an Agni motor?
If you'd type in the details of what you're trying to accomplish, and what you've done so far, and still have to go, along with what parts you're using, it would be helpful to others that come along and want to do something similar. The more details, the better. ;)
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 07 2019 10:49pm
Thank eFMX!!
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 07 2019 11:14pm
OK amberwolf ! You got it the first attempt ended up with me going over the handlebars realizing I needed more break.... as it turns out you can't send 18 Kw through a bicycle :oops: also rim brakes smoke at a certain point in there life with me as there master.
But enough back story. The controller I was using is one of the cheap Kelly controller KDH12600. but no matter how the computer software tells me the the acceleration table is linear it's really not. The motor is from cloud electric. With part number D135RAG I will attach the pdf from LMC. The first battery pack that I made was 30 A123 20Ah cells squeezed between two plates quarter inch aluminum. And will not be used the second te around.
lmc-lem-200.pdf
Lmc-lem-200
(631.54 KiB) Downloaded 28 times
Drunkskunk   100 GW
Re: Neematic clone
Post by Drunkskunk » Aug 08 2019 4:06am
Awesome looking build. I like how the swing arm is mounted.
So why are the fork legs backwards? With that much trail on the front wheel, it would handle like a bucking bronco with a burr in it's backside.
Merlin   10 MW
Re: Neematic clone
Post by Merlin » Aug 08 2019 6:39am
subbed :D
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 08 2019 8:29am
Thank you so much drunkskunk!!! I would had never look at that. And would have always wondered that would be the cause
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 12 2019 7:18pm
More work and some thing I can sit on like a bike from the 1870s....
2019-08-12 18.12.18.jpg (181 KiB) Viewed 1429 times
2019-08-12 18.14.46.jpg (203.56 KiB) Viewed 1429 times
2019-08-12 18.15.03.jpg (211.47 KiB) Viewed 1429 times
2019-08-12 18.16.54.jpg (196.45 KiB) Viewed 1429 times
2019-08-12 19.28.34.jpg (315.11 KiB) Viewed 1418 times
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Sep 30 2019 1:49pm
Not to much to say. But some more progress!!!
For the first time is can move under its own power! !!!
2019-09-30 12.47.54.jpg (181.46 KiB) Viewed 1133 times
SlowCo   100 kW
Re: Neematic clone
Post by SlowCo » Sep 30 2019 4:30pm
Wow nice build!
What battery cells are those? And did you keep them that far apart for cooling? Otherwise it seems you would have room for more cells when getting them closer together. And with more cells in parallel they stay cooler anyway. Also the seat seems to be very far rearward.
Keep up the good work :thumb:
Xtr6   100 W
Re: Neematic clone
Post by Xtr6 » Oct 01 2019 1:28pm
Those are LIFEPO4 Headway cells. Also being used in BMW i3. I have a lot of these for sale because I do not use them. I'rather stick to Lipo because of the weight.
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Oct 01 2019 4:02pm
Slowco thanks for the comment! It means a lot!
And you hit the nail on the proverbial head!! The cell's are space far apart for air cooling and also, space and for a rubber retaining ring to keep them isolated from the aluminum sheets that hold them together. I set the seat that far back for a comfy ride.
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 01 2020 11:33pm
Well after some time, I finally got the dam thing mostly usable. The 38120 headway cells did not go over so well..... so RC Lipo it is. 2 series 4 parallel.
Within the pack. There are 12 cells in total, half of which are in series. The other half are in parallel total pack voltage 100.8@ 20Ah. I have completed a 30 mile 15 there and 15 back. Got back to my house at 82 volts. Max discharge i's at 72 volts. More distance writing will be performed at a later date.
So my big question now is should I make another one to sell? If you guy's and girl's could imagine,
A bike with options, in which you could select total output power or range could be selected. Or a fine balance of the two. With the option of being brushless or brushed. Having the ability to choose Total pack voltage and/or ampacity of motor controller.
Price for......
Motor 1700$
Motor controller 570$
Battery's 2000$ Frame/fab/fit/weld.....finish to come later. Keeo this in min, this is a prototype, so I am asking you guy's and girl's, would any of you pay for a bike capable of 30KW no joke. And if so how much? For me, I have the Sigma Drive motor controller PME817S. And at full tilt It will pull 160 amps, at 98 volts ish. Which more or less is about 15 KW or also. But there is much more room to grow. My question to you, is how much would you pay for a 10-20-30-40-50-60-70 KW motorcycle?
Amateur   10 mW
Re: Neematic clone
Post by Amateur » Aug 01 2020 11:47pm
So some of the progress i have made in some time...
2020-08-01 22.42.11.jpg (400.05 KiB) Viewed 58 times
2020-08-01 22.43.30.jpg (480.06 KiB) Viewed 58 times
2020-08-01 22.44.41.jpg (368.59 KiB) Viewed 58 times
2020-08-01 22.45.13.jpg (420.21 KiB) Viewed 58 times
2020-08-01 22.45.53.jpg (394.93 KiB) Viewed 58 times
2020-08-01 22.46.32.jpg (399.79 KiB) Viewed 58 times
