sprocket
- Joined
- May 7, 2009
- Messages
- 11
Two poor quality videos:
A video of the kit before installation:
http://www.youtube.com/watch?v=Me4K6lozFKk
A vid of the bike in motion on a bike path:
http://www.youtube.com/watch?v=DKM7Jnbq5H4
Some stats on the bike if you care:
Motor and controller:
Volts, amps, watts: 36-72V , 30A pedal first (500-1500W motor)
Weight: 15 pounds without rim (need the rim anyway,right?)
Cost: $585.00
Other stats: Motor is water resistant, comes with
computer, controller, throttle, and wiring, purchased from
www.ebikes.ca
Battery:
Volta, amps, watts: 48V, 50A (2.4 kW)
Size, Weight: 8.5" x 11.5" x 4" (21 lbs) It's about the
size of two reams of paper, but weighs more
Range: 30-50 miles on one charge (to work it's
8.6 miles, I can charge at work if needed)
Cost of battery: $728 (With shipping)
Other stats: Battery is LiFePo4 chemistry, ordered from
www.pingbattery.com (V 2.5)
Total
Estimated Speed (Sim) : 28 Mph (no pedaling) 35 mph (moderate pedaling)
Measured Speed: 32.5 Mph (no pedaling) 33.6 (moderate pedaling)
Ah per mile: 20.2 (moderate pedaling always, but only 5 miles tested so far, will update)
Total Weight: 54 lbs = 16 lbs (bike) + 21 lbs (battery) +
15 lbs (motor) + 2 lbs( controller and etc.)
Total Cost: $1,313
Notes on the installation:
Both ebikes.ca and Ping are really great to deal with. They offered good customer service and I am generally happy at this point. But there are a few things I could recommend to them and a few bumps I ran into during the installation:
1. DOCUMENTATION: Neither of these guys is big on documentation (save for the manual from ebikes for the Cycle Analyst, which is very nice). For the Ebikes kit, I really could have used some help figuring out how to mount the torque arm and the magnet for the speedo. (yes, i'm below average intelligence, but 50% of us are too, right? ). For Ping I got a battery with 4 wires and a charger with a 3 pin connector, no documentation. The pinout of the charger is easy enough to measure, but how about a piece of paper? And if anyone cares: The large RED and BLACK wires from the PING are output (to controller) and the THIN BLUE wire is the negative charging wire while the THIN RED wire is the positive charging wire. At least this was the case for my battery.
<Edit>
2. TIRE SIZE: I had some confusion on the tire size. The 700c rim is quoted as being a 622-20. After some help from Russel (see below) I see that this would require a 622-32 tire minimum (which is what I used). Clearly!!!??!!
</Edit>
3. WHEEL BALANCE: The ebikes hub is laced such that the wheel does NOT wobble left to right when it spins. However, the axis of rotation is not centered with wheel's axis such that the wheel moves up and down (about 3-4 mm). I don't know what to do about this right now. It doesn't appear to be too disturbing when riding.
4. THROTTLE: I got a thumb throttle, but had a hell of a time mounting it to the handlebars. As you can see from the first pic, I have curved bars and their diameter is larger than the throttle's inner diameter, so I had to glue it on (minor point).
5. CHARGER: Ping's charger looks nice and compact, but I really wish it didn't have a fan, so I could leave it inside my pannier bag and just charge with a single wire coming out. Yes, i know.. i has to get rid of the heat. I would even settle for a charger with less amperage.
Cost: $585.00
www.ebikes.ca
Battery:
Total
Total Cost: $1,313
<Edit>
</Edit>
