Norco Atomik with BBSHD
PRW   10 kW
Post by PRW » Jan 18 2020 12:49am
At long last I got around to finishing this build - a 2005/2006 Norco Aline/ Atomik, with a battery box cut and welded by Samd. Battery is 52v 21ah 14s battery, BBSHD. Boxxer World Cup forks, Fox rear shock, Lekkie bling ring.
Test ride this morning - bike is really lightweight, very smooth. The rear suspension on the bike is very impressive. Next up, dropper post.
goatman   10 kW
Re: Norco Atomik with BBSHD
Post by goatman » Jan 18 2020 1:25am
I really like the old framed bikes, like the Sinister R9 build. im really tempted to do a bbshd. my last build is so ass heavy 43lb at the rear wheel and 28lb on the front. whats the bike weight?
PRW   10 kW
Post by PRW » Jan 18 2020 2:22am
goatman wrote:
Jan 18 2020 1:25am
28kg/ 62 lbs. Nice to be able to lift the bike up easily into the truck bed!
goatman   10 kW
Post by goatman » Jan 18 2020 2:52am
those norcos, theyre popular here in Vancouver, but I think theyre called Norco shore or vps. I saw 1 of those frames with a lower what looked like a flat bar and another that didn't. did you have to cut that bar out to fit the battery box and did you weld the box to the frame?
PRW   10 kW
Post by PRW » Jan 18 2020 3:10am
this was done by Samd - the picture below shows how it works
and the bike it comes from
norco 8.jpg (16.51 KiB) Viewed 773 times
DHebike   1 µW
Post by DHebike » Feb 26 2020 4:49pm
Nice build! I have a 2005 Norco Atomik as-well! Did you need any BB adapters/spacers for the BBSHD/chainring or any special mods other than the battery? Thanks
