Echoppcycle
Hickbeard   100 W
Echoppcycle
Post by Hickbeard » Jul 29 2020 3:26pm
So haven't finished the current hire bike build and already design/planning the next one.
This will be hard tail, then the one after this will be air suspension rear end, maybe even car wheel, who knows.
This is the plan so far.
I'm copying @Naxyl tube sizes. 40mm x 40mm x 2mm for frame, 40mm x 20mm x 2mm for rear arms, 20mm x 20mm x 2mm for front forks. Image
Sent from my CLT-L09 using Tapatalk
goatman   1 MW
Re: Echoppcycle
Post by goatman » Jul 29 2020 11:25pm
frame is pretty low to ground, youd have to mount the pedals/bottom bracket higher to keep from striking ground.
ill share some of my dimensions
the center of my pedal cranks are 13 inches to center from ground, my rear tire is 13 inches to center( tire od is 26 inches)
front axle is 13 3/4 inches to center.
my pedals are forward on the stiletto, if i measure from center of pedals/BB to center of seat its 32 inches.
Hickbeard   100 W
Re: Echoppcycle
Post by Hickbeard » Jul 30 2020 12:52am
@goatman yeah BB will be mounted somewhere near the bottom of the front triangle.
The bottom tube is 100mm from the ground.
Naxyl   100 µW
100 µW
Re: Echoppcycle
Post by Naxyl » Jul 30 2020 1:46am
Looks super long. What is assumed wheelbase?
Hickbeard   100 W
Re: Echoppcycle
Post by Hickbeard » Jul 30 2020 1:54am
Naxyl wrote:Looks super long. What is assumed wheelbase?
Between 2m & 2.5m.
Originally the idea was for the seat to be on the bottom tube which made the length 3m.
Hickbeard   100 W
Re: Echoppcycle
Post by Hickbeard » Jul 30 2020 10:02am
Battery box design. This will sit on top of the main tube and drape over it either side. This will give two cavities. One for the controller one for something else. Maybe a gun! Image
The aim will be to make this look like a fuel tank.
Battery inside will be 14s 8p.
Hickbeard   100 W
Re: Echoppcycle
Post by Hickbeard » Aug 01 2020 3:10pm
Bit more design work.
I've managed to shrink the length ever so slightly. Also dropped the height of the saddle.
Battery box is too big though so need to shrink that a little.
goatman   1 MW
Re: Echoppcycle
Post by goatman » Aug 01 2020 3:32pm
having the battery that high with that rake of fork makes slow turns kind of tippy. thats why i turned my "battery tank" into a
"tank bag" and mounted the batteries as low and more centered as i could.
over all length of my bike is 84 inches and it just fits into most newer elevators
Hickbeard   100 W
Re: Echoppcycle
Post by Hickbeard » Aug 01 2020 3:42pm
You reckon it'll have that much effect?
Think this will be just under 95" rim to rim.
What have you got that's that long?
goatman   1 MW
Re: Echoppcycle
Post by goatman » Aug 01 2020 4:16pm
giant stiletto
viewtopic.php?f=6&t=103833
this one just showed up on craigslist in Vancouver
https://vancouver.craigslist.org/van/bi ... 07210.html
Hickbeard   100 W
Re: Echoppcycle
Post by Hickbeard » Aug 01 2020 4:26pm
Yeah love it.
Proper bikes.
I'm trying to keep the inner triangle clear though for an idea I've got.
goatman   1 MW
Re: Echoppcycle
Post by goatman » Aug 01 2020 4:43pm
beer fridge?
maybe beer fridge on the bottom and the compressor could keep your fish and chips warm up top :thumb:
Hickbeard   100 W
Re: Echoppcycle
Post by Hickbeard » Aug 02 2020 1:38am
Hmm, beer fridge could work. Now I'm thinking about a nespresso machine down there though.
