Mongoose fatbike BBSHD build
Show off your Ebike creation here.
powrtrip   1 mW
Post by powrtrip » Jan 21 2021 10:34am
So I wanted to add some build info that I didn't find .... using the 120mm motor you'll need spacers. The best line up with both cranks fairly even distanced, 8mm worth of spacers go on the bracket side. The chain ring is dead middle when doing this. Also plenty of room for casing and bottom chainstay...
