My current set up is built on an Schwinn aluminum mountain bike frame and will be switching everything over. When I first started this project on an aluminum frame had different motor, controller and battery with way less power and now this has gotten out of control
So here we go with a steel frame! Bombs away!
-72v 20ah 20s6p - Will upgrade eventually to 40ah
-Sabvoton7280 - Will mod controller but not right away
-Mxus 3K 5T 6ml statorade with HubSink’s - 8ga phase wires
-Wheel set Halo sas 27.5” front/rear built with 13/14ga dh spokes. Probably switching to motorcycle wheels though
-Front suspension DNM-USD8
-Rear DNM coil shock/ 350lb Rock shocks spring/Might have to up the lbs.
-203mm rotors, Shimano 4 piston hydraulic MT420
-7 speed with 32tooth chairing - still like to pedal, sometimes
Considered all the different clone frames online and this one caught my eye the most. From the pictures it looks to be well finished. Found several good reviews on this frame online so went for it. Like the fact the torque arms are built into the frame.
I’ll be posting progress pictures as I build. I’m really hoping to squeeze this Sabvoton controller inside the case, but we’ll see! It’s the 80 amp version so it is smaller than the traditional 150 amp or 200 amp.
My main thing to look forward to with the stronger frame is I can ride much more aggressive off road now. I always took it easy off-road being on a Schwinn frame with so much weight. Also will enjoy the extended wheelbase to help keep the front wheel down. That’s also a plus for rolling burnouts right
