72v PSI leggo - X5304 Chopper
Postby Ypedal » Tue Jul 07, 2009 1:28 pm
I"m finally taking the time to build up my chopper once again ! :P
The X5305 with 48v 12ah prismatic cells was ok last year but the 12ah cells are fizzing out and they are dying one at a time making the chopper a sitting duck, and on top of that the X5304 i built for my Norco did not work out so well either after it pulled itself out of the frame....... so it's chopper upgrade time !
I got my Leggo's from "AndyH" on this forum,
http://www.rechargeablelithiumpower.com ... /index.php
The cells themselves i got direct from PSI in taiwan last year..
So let's begin !
I've decided to build the pack in 12v blocks, given my history of relocating bits and pieces to different projects as i burn things up :wink: ..
ES site status page:
Ypedal
Re: 72v PSI leggo - X5304 Chopper
Postby Ypedal » Tue Jul 07, 2009 1:30 pm
The blocks are incredibly well made, sturdy, strong, low flex, and they lock together very tightly 8)
After lining up the notches, i used a block of nylon and a hammer to set them in place..
Ypedal
Postby Ypedal » Tue Jul 07, 2009 1:33 pm
I dug thru my stash of carboard and found the template i made last year when building the 12ah pack.. as you can see, the 6 x 12v packs will fit in the frame perfectly with not much room to spare once i add sides to the packs..
Ypedal
Postby Sacman » Tue Jul 07, 2009 2:33 pm
Hi Gaston,
So the cells will sit perpendicular to the frame? Those cells about 6-inches long right? Add another inch for the plastic legos... that's about 7-inches wide you gotta straddle your legs around to pedal. Oh I see the chopper no pedals... just foot pegs.
What are you gonna do to support the individual 12-volt packs appart from each other? You gonna have a board or cover of some sort at the ends? Looks like you can even fit your controller in that triangle if you arrange your 12-volt packs closer to each other.
Sacman
Postby deecanio » Tue Jul 07, 2009 3:07 pm
nice.
i got my bms from AndyH top guy :)
so whats happening with the dually :?: :lol: and wheres the badassical dh'er? eh? eh?
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby Ypedal » Tue Jul 07, 2009 3:52 pm
Sacman : Alot of unknowns lol... i figure it out as i go .. :lol: .. i measured the assembled 12v pack and with end plates etc it will be 7.5" long, and that's correct, no pedals.. just footpegs. :wink:
D : The Norco is screwed, needs a new swingarm( fudged the dropouts with an X5 !! .. ouch ) .. i'm ordering a new swingarm from the local bike shop if we can work it out somehow, i'm admitting to personal stupidity and not trying to go for a warranty claim.. it is my fault. The Dualy will end up either on the norco if i can get a new swingarm, or on the TF frame once i buy a front end for it ( trying to find a good deal on a tripple crown fork with front 24" and disk )
as per " BMI " in the battery section of the forum, one layer of electrical tape and the cells wedge right into the blocks..
Ypedal
Postby Ypedal » Tue Jul 07, 2009 3:56 pm
one side :
Ypedal
Postby Ypedal » Tue Jul 07, 2009 3:58 pm
Cha Ching ! 8)
I started the electrical tape between the white barcode sticker and the cell's shrink wrap stamp, this way the stickers and tape seams all point in the middle and out of sight ! ( OCD ?? :lol: )
Ypedal
Postby Ypedal » Tue Jul 07, 2009 3:59 pm
top view
Ypedal
Postby Ypedal » Tue Jul 07, 2009 4:02 pm
And this time i'm using a BMS !!! ( or " vms " .. )
Ypedal
Postby Ypedal » Tue Jul 07, 2009 4:06 pm
The packs need to allow for the ballancing wires and i don't want to make them any wider than needed ( I have no spare room !! ) .. so using a 9/64 bit drilled thru one of the corner holes !!! :D
Ypedal
Postby Ypedal » Tue Jul 07, 2009 4:07 pm
On the back side of each block, one corner has a bigger space, perfect for fitting 3 wires !
Ypedal
Postby Link » Tue Jul 07, 2009 11:20 pm
Methinks Ypedal has uncovered a design improvement...
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
Link
Postby deecanio » Wed Jul 08, 2009 6:49 pm
nice work on the psi's Y.
major bummer on the norco (just caught up on that) :cry: hopefully you can get a replacement swingarm for her.
If the norco is a no go can't you use the duallys on that on the tf?
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby rkosiorek » Fri Jul 10, 2009 8:30 am
Each of the 4 -cell boards has a little LED fuel gauge. will those be visible?
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby Ypedal » Sun Jul 12, 2009 1:13 pm
Rk, had not realized there were LED's on there, re-read the PSI bms document and aparently they are voltage regulated ( not capacity ) and yeah.. i'm going to have to figure out a way to keep them visible... i have an idea but will wait until i get there to see how it will look..
A few days ago i went to Home Depot and picked up some acrylic, one .118" x 36" x 72" and a few smaller pieces of 1/4"...
Ypedal
Postby Ypedal » Sun Jul 12, 2009 4:07 pm
Stuff is expensive... 200$ for all 3 pieces.. :|
Ypedal
Postby Ypedal » Sun Jul 12, 2009 4:10 pm
Back to the blocks..
Drilling out the corner to fish the wires is one option but it still puts the wires in the way of the acrylic panels i plan to use.. so using a dremel and a routing bit. and my sacrificial block ( always order a few extras !! ) ..
Ypedal
Postby Ypedal » Sun Jul 12, 2009 4:12 pm
Keeps all the wires inside the blocks !
Ypedal
Postby Ypedal » Sun Jul 12, 2009 4:13 pm
Other end, that will also have the power leads.
Ypedal
Postby Ypedal » Sun Jul 12, 2009 4:20 pm
8)
Ypedal
Postby Ypedal » Sun Jul 12, 2009 4:23 pm
If i was going to build the whole 72v pack permanently into the chopper, i'd hook up all the blocks with the tabs, but i'm building 12v packs.. so off with their heads !
Ypedal
Postby Ypedal » Tue Jul 14, 2009 8:21 pm
Ok, so tonight i cut the acrylic sheet in two with the help of my neighbor using my table saw, we tried a big industrial paper cutter i have but the pinching action of the blade cracked the acrylic and it's a no go.. table saw worked great in the end..
And now to bench test the pack before spending hours working on boxing this thing... if i have a problem i prefer to know now, not later..
Found a way to stack all 6 x 12v packs so i can connect them with the tabs.. Put stickers on each pack to visualize it all.. checked and rechecked.. and checked again .. a few more times to make SURE i have the + - + - + - order correct... !!!!! :shock:
Ypedal
Postby Ypedal » Tue Jul 14, 2009 8:25 pm
Each 12v ( 4 cells in series ), has a 6pin VMS pigtail, 2 of those wires i had to cut in order to fish them thru the blocks.. Soldered those back on . I plan to cut the excess wires down to 1 or 2 " from the pack, just long enough to bolt the boards at the end of each pack with the wires facing the cells, and LED"s facing the outside of the pack !! 8)
Ypedal
Postby Ypedal » Tue Jul 14, 2009 8:28 pm
snapshot of the backside.. this will have a clear acrylic and remain visible.. ( left side of the bike )
Ypedal
Next
Who is online
Users browsing this forum: 1HP, Im_Getting_Better, Yahoo [Bot] and 12 guests
