Mark_A_W wrote:I was wondering if there was a de-facto wiring standard for the mini-XLR connectors for hall sensors.
Be careful! There is not, and you can blow hall sensors if you wire it up wrong. See how the picture above shows different standards between BMC and xlyte. I don't know MAC, but I saw a picture of one that reminded me of the old Pumas. Doesn't mean squat in terms of the wiring though.
I got the hall connector finished up, and I think it is correct... The wheels spins in the right direction, but throttle seems to drop off the more I turn it. Maybe the controller cuts out on 'runaway', or maybe a throttle issue. I tried a pair of xlyte throttles but neither one worked at all, but the one I hacked from a tidalforce at least spun the wheels.
I started to get ready for a test ride when I heard the patter of rain. This is the start of the SoCal rainy month last week or two of Dec and 2-3 weeks of Jan), forcasted for tomorrow but apparently here now. Hope there is a break so I can road-test!
Anyhow, I built a little 15s3p a123 M1 pack that will hang under the frame between the pedals. This will put the 8lb+ of battery weight in the center of the bike, and underneath the center of rotation (yaw?). I'm gonna build a little metal box for it and paint it flat black, so it should be for all purposes invisible to the casual observer. The wire end of the pack will be bolted to the double-kickstand housing, and the power/charging connectors will be accessed right by the rear wheel. The front side was intended to end right in line with the frame, but my design for joining the rows was flawed so there are big gaps between each column and the pack it will stick out a inch or two.
What I did was take (3) packs of dewalts unfolded into tubes, tape them to together, and refold them at two spots to form the "z" shape you see in the first pic below. I paralleled the three cells in each row by soldering a charging wire to all 3 factory tabs. In the next pic you can see the "z" formation collapsed, and the 4th 3s3p row stuck on top. In the background are the cells that were formed into the 2s3p section. Note that there are is only one row of cells in the 4th column - the double kickstand has a metal tab and spring that intrude into one side of this space, which is why the pack is 15s instead of 16s. I made a 2s3p section that is rotated 90* to the other cells to use the remaining space.
- cells in a z_7941.JPG (75.79 KiB) Viewed 4440 times
- 13 cells_7946.jpg (111.42 KiB) Viewed 4441 times
Although I only plan to pull 50a from this pack, I used 8ga discharge wires. I plan to bulk charge it in 15 minutes through a pair of 12ga charge leads. I also have a balancing-charger connector that I hope I don't have to use much. The pack has something like 240 usable wh, and I'll be very curious to see the whm I get from the overall setup.
For the power train part of this bike, I have added very little weight:
8lb 2.6oz - battery
1lb 14oz - controller
12.8lb motor wheel (Minus weight of average wheel)
??? Throttle. Cycleanalyst, 8gau motor wire upgrade, power switch/fuse, battery box
Of course, the RockShox Boxxer double-crown fork, the durable double kickstand, the Thudbuster, the Alex DX-32 rims, Hookworms, Kenda downhill tubes, and kevlar lines add weight too, but those are comfort issues rather than powertrain.
Right now I am hoping to end up with a ebike that is light, but can climb hills, achieve 35+ mph, range 6+ miles at 20+mph, lunch-charge in 15 minutes, and is so stealthy that people scratch their heads wondering how easy you make pedaling look.
Here is a pciture of the battery and the controller wiith connectors, and then a picture of the battery wrapped in cardboard, ghetto but good enough for my tests.
- Batt and Controller_9182.jpg (102.72 KiB) Viewed 4441 times
- batt in cardboard_9186.jpg (77.02 KiB) Viewed 4441 times
