Page 1 of 4
electrifying a cannondale bad boy 700
Posted: Oct 05 2009 6:18am
by e-cannon
Hi there.
Sorry my English I am from Switzerland.
I just finished my e-bike project. It did last longer than expected, but now it is finished and riding my bike really rocks.
The concept:
I just wanted a bike of my choice to be electrified. I did not want a front hub so I had to find another place for the battery than a rear rack because of the improper weight distribution. And I did not want to see much of the wiring. So the battery had to be somewhere in the bicycle frame. And in a case. I decided to buy an ezee-kit from http://www.ebikes.ca and so I did. Thanks to Justin at this place for all the answering on my noob-questions about electricity.
Then I bought a cannondale bad boy:
Before the bicycle was assembled by my dealer (I had to wait about 2 weeks) I just made an exact drawing from the frame geometry in my dealers shop. Cannondale would not give me a CAD drawing of the frame geometry. I asked.
Then I made an 1:1 Autocad drawing of the project (I am an architect. So no problems here):
Of course I verified the design in 3dsmax (what we do with all our projects). I had a low poly 3d model of another bike which I adapted to the original frame geometry. Good enough for an impression.
I then spent some time in fibreglass forums until I thought I knew enough. Then I started with modeling the form out of styrofoam (mainly used to insulate buildings).
Some priming & grinding:
Epoxy over it so the separating agent would not destroy the styrofoam. Once again verifying the form...
I placed those strong inserts where the case will be connected to the bicycle frame. Just to be sure.
Put some separating agent on the thing. Ready to laminate:
Laminating in process. I do not want to do this again. It's so toxic (endless-sphere?).
Posted: Oct 05 2009 7:19am
by e-cannon
After about 24 hours: Cutting out. First contact with this really strong material. You need tools for metal editing to deal with fibreglass.
Arghh...Done...
Now getting out this blue stuff (2 hours).
Now the thing with fibreglass is: if you don't bake it it will melt at a temperature point of about 60 to 70 °Celsius. While I wanted to place the battery inside the case and also wanted to ride my bike in summer I had to build an oven to bake the case for a minimum of 10 hours at the wanted resistance temperature minus 30°Celsius. Means: If I bake it 10 hours at 100° Celsius it will be stable up to about 130 °Celsius and so on.
I found an old metal corpus on the attic I transformed into an oven. The rest of the styrofoam for insulating, three 100W bulbs for heating. And a joint thermometer for measuring.
My temperature curve. By the way: you should not rise the temperature to fast (10°Celsius per hour). I got up to about 80°. Enough for my needs I hope. Means stable till about 110°.
Posted: Oct 05 2009 8:02am
by e-cannon
After baking I had to do a lot of grinding, drilling, preparing the electronic parts by soldering water proof connections and so on. And of course the finish of the case. I will not go in detail by now. Look at the images.
The big connector you see here is for the 3 motor phase leads. It's water prove just in case. When I have to dismount my rear wheel for repairing I just disconnect this one and bring it out of the case through that big hole you see in the picture above.
With the lock I can start the system. And also close of course.
In here will sit the battery:
I made some mods on the battery itself for better handling.
Mounting the battery:
There is some space left for carrying something (like the charger unit).
Closing the case:
Posted: Oct 05 2009 8:12am
by e-cannon
Finally...
Re: electrifying a cannondale bad boy 700
Posted: Oct 05 2009 8:38am
by e-cannon
Thanks for your welcoming..
No. The epoxy is also part of the fibreglas (its the so called matrix). Its just the separating agent (something like wax) which would destroy the styrofoam. And you need some separating agent because it makes it much easier to get the laminated thing off the form...
Posted: Oct 05 2009 9:04am
by e-cannon
There are many products you can use.
I think you have to find a shop in your country which is specialized in composite technology.
I have all the epoxy stuff from a Swiss online shop:
http://www.suterkunststoffe.ch/pdf/prod ... rsicht.pdf
pages 132/133
I used "SCS-Wachs-Trennmittel" on page 132. Worked perfectly.
And the (German) forum I got my knowledge from: http://www.r-g.de/
Posted: Oct 05 2009 9:30am
by karma
nice work :wink:
Posted: Oct 05 2009 11:49am
by Drunkskunk
WOW
Speachless...
:mrgreen:
Posted: Oct 05 2009 12:42pm
by dnmun
way cool. how did you make the side panel?
this has gotta be the most top notch without going over the top.
very applicable to other bikes, was it too large to fit inside an electric oven? now i am gonna watch CL for super large electric ovens, big enuff for the molds to fit inside. let it live outside under the woodshed to make them.
if you did not need access later, you could put in a lot of mold release, then cut it right down the middle or maybe leave the foam in place and dig out a cavity to mount the cells or pack, then close it and attach the two sides around the perimeter with tape, attach straps or brackets with mounts to strong points molded into the case.
way cool, very inspiring.
Posted: Oct 05 2009 1:19pm
by nicobie
I think that is just about the nicest battery box I have ever seen.
You even have room for a little boost battery :twisted:
Posted: Oct 06 2009 2:33am
by e-cannon
thanks for all the nice reactions..
@dnmun:
yes, too large to fit in a standard electric oven : )
the side panel is completely flat so I decided to make it out of an acrylic glass plate (3mm).The advantage here was that I could hold it over the opening to precisely draw the shape on it because of its transparency. However I run in minor problems getting the finish on the surface (there was some chemical reaction I did not understand...).
The closures on both sides - the case and the side panel - were formed out of an PVC profile, which I could heat deform to get the curvatures:
Front part just filled with glue (a bit primitive, but worked). You see the tiny cracks in acrylic glass? They happened when I was cleaning the acrylic glass with aceton before applying the primer. Strange. And I don't care.
By the way: The only glue I used was a two-part adhesive. This one is the flagship of this huge glue company UHU. Take a look at the specs. I always raised the temperature with a tiny radiant heater up to 50° to 60° Celsius where I thought it was important...
sorry bad picture...
Posted: Oct 06 2009 5:01am
by biohazardman
Looks like quite a bit of work and it came out very nice so was definitely worth it. Appreciate the DIY it will be helpful to some I am sure. Thanks for the post.
Posted: Oct 06 2009 8:01am
by adrian_sm
Awesome job. Very nice indeed. I was toying with the idea of a sheet metal enclosure, but now that I have seen this I might have changed my mind.
How is the side panel held in place?
Posted: Oct 06 2009 9:57am
by jetguy
You really did a very nice job! makes me glad to know that people (you) can research topics and learn from each other. you started w/ little or no composite experience, and self taught off of things on the internet. you even built your own oven!! then the impressive ramp-up and cure of your cook along with a plot is really very cool! again very nice work. you should be proud of your self. i hope you get alot of enjoyment from your bike for many many years.
p.s. i used to be an aircraft mechanic for over 10 years and specialized in advanced aerospace composites (carbon fiber/fiberglass/metal bonding)for most of my career.
Posted: Oct 06 2009 10:15am
by e-cannon
@ adrian_sm
It's just the triangle geometry: when closed the lock cylinder fits exactly in the hole and blocks any movement in ride direction and the profiles on the two longer sides of the triangle are then interlocked so the only method to open the case then would be brute force... :evil:
The wet weather concept is that the water flows inside the profile on the case itself, which goes completely all around the opening. In case water gets in the case it will hopefully flow down to the very lowest point where I provided a hole. There are a couple of other holes on the downside and the rear side of the case to assure some airflow to cool the battery and mainly the motor controller...
Posted: Oct 06 2009 10:26am
by e-cannon
@jetguy
thanks! I am a bit proud but MORE happy that it is finished by now...
Posted: Oct 06 2009 12:58pm
by Zoot Katz
That's got to be the cleanest build I've seen yet. It's gorgeous!
Now I want to tear apart my bike and start over.
Nice work. Bravo!
Posted: Oct 06 2009 1:10pm
by 317537
Good stuff. Looks real pro when finished. I did fibre glassing some time ago, I hated it.
Seeing this thread i will probably use it to house some lithiums myself. Very versitile and very informative thread, thank you for sharing.
Posted: Oct 06 2009 7:39pm
by adrian_sm
e-cannon wrote:@ adrian_sm
Cool.
So the lock barrel somehow gets out of the way when you remove the side panel? Does it come out into you hand, or retract back into the enclosure?
e-cannon wrote: The wet weather concept is that the water flows inside the profile on the case itself, which goes completely all around the opening. In case water gets in the case it will hopefully flow down to the very lowest point where I provided a hole. There are a couple of other holes on the downside and the rear side of the case to assure some airflow to cool the battery and mainly the motor controller...
Ahhh. That makes more sense now. Should work nicely.
Any issues with heat buildup? I was playing with ideas of allowing airflow through my battery box, while avoid water ingress, but was not sure if a really need it. I have never had my batteries or controller feel hot. With my super accurate "calibrated" hand, it is hard to tell if they are more than a few degrees above ambient.
Posted: Oct 06 2009 10:09pm
by BLUESTREAK
BEAUTYFULL WORK, you are to be admired for such thoughtful work. I have seen a lot of things fabricated in my 65 years and this rates in the top tier. always keep this in your mind. DO the best job possible at anything you set your mind to build. :D :D :D :D :mrgreen:
Posted: Oct 07 2009 5:18am
by e-cannon
@ BLUESTREAK:
Thanks! :D
@ adrian_sm
the lock barrel retracts. its a furniture lock that could be locked in both positions.
using these components:
Posted: Oct 07 2009 6:31am
by e-cannon
adrian_sm wrote:Any issues with heat buildup? I was playing with ideas of allowing airflow through my battery box, while avoid water ingress, but was not sure if a really need it. I have never had my batteries or controller feel hot. With my super accurate "calibrated" hand, it is hard to tell if they are more than a few degrees above ambient.
I read in the manual that comes with the ezee kit:
"If you plan to ride in hot weather, without pedaling up
steep hills, etc., mount your controller outside of the
battery bag to prevent thermal shutdown."
My controller is mounted with some spacing around it so its maybe not comparable with bag surrounding it but I just decided to drill the holes. They are placed in the middle axis of the case and the bicycle frame so I don't think there will be a direct water ingress. The most critical point is maybe the short end of the triangle where the side panel just overlaps the profile but an eventual water ingress there won't hurt anything...
Posted: Oct 07 2009 6:25pm
by adrian_sm
e-cannon wrote: @ adrian_sm
Very neat. I like how you have integrated the enclosure lock with the main power switch. Makes for a very clean look.
Does that mean when it is powered on the side panel might be able to slide off while you are riding.
Sorry for all the questions. But I have been inspired, and am now thinking of tackling something similar myself.
Posted: Oct 08 2009 1:38am
by e-cannon
adrian_sm wrote:Does that mean when it is powered on the side panel might be able to slide off while you are riding.
no. while riding the lock is always in "pos. closed". it's a push-button switch (push once - ON, push again - OFF). So starting the bike goes like: put in key, rotate, push down, pull back (you do not actually have to pull 'cause there is a spring in the lock), rotate back, pull out key.
if you rotate it back after "push down" you can pull out the key in the "pos. open" , the barrel will remain there and you can then open the case (with sometimes ON, sometimes OFF system, then I just turn off the battery on its own switch).
Posted: Oct 08 2009 4:07am
by e-cannon
adrian_sm wrote:Sorry for all the questions. But I have been inspired, and am now thinking of tackling something similar myself.
no prob. I would like to expect something like that: :D
