Just got 29 more 2200mah lithium-cobalt 18650s delivered promptly from all-battery.com. I'm constructing a small 2s15p 30-cell pack to add in series to my bike's pack of the same chemistry.
Originally, I planned instead to make a small 18V 6ah "boost" pack of lithium manganese emoli's -- the cells used in Milwaukee V28 powertools -- but concerns over voltage spikes from the relay damaging the controller led me to take the more conservative route of adding more of what worked before.
Though the specs are the same, the new batteries are a little different than the old one's. The new exterior color is lighter -- as seen in the photo where the green arrow denotes the old style (awaiting this day, I've stored this extra in my fridge for months next to the butter
). The tabs are much thicker, and unlike before, stamped to the end caps uniformly in the same place on each battery. Hopefully resistance through the new tabs will be less.
To construct the pack, I first built the platform on which they'll sit with holes drilled for ports for the XLR charging jacks. Now, I'm lining up the batteries in a row atop cardboard, securing them in place using dabs of silicon glue so that later if I have to, I can peel the batteries apart and replace a bad one, reconfigure the pack, etc.
I folded the tabs so as to make a cradle for the main, 12 gauge power wire, and a second cradle for the 18 gauge charging wire. Doubling the wires in this manner isn't necessary, but provides insurance in case a solder joint breaks, and a little less electrical resistance.
Next up: soldering the first row.
