Hey, thanks for the helpful info/hints and positive comments! Let me see if I can add anything worth knowing...
I'm putting in a 72V 35A Lyen edition controller and was wondering how you planned on routing your wiring. I've used the built-in cable tunnel with good success, however, I'd love to see other ideas.
Sorry, Ambrose, I don't have anything that spectacular in mind - with the rear motor, controller on the rear rack, there are just two (for now) wires coming from the front of the bike. Those are routed through the tunnel as you suggest. I don't have any big, honking cables to run or good ideas for you other than El-Steak's build, which I'm sure you have seen.
Have you adjusted the amps on the controller? I am curious though why you didn't use the built in rack mounts on the TF frame for the battery rack.
Hi, Stud: Haha, you guys don't miss a thing! The dang supports got in the way of the rear brake and shoved the brake shoes right up against the rim, so I ran them to the seat post figuring no one would ever notice.... I have not adjusted the amps on the controller, but I need to - this thing is not performing up to its potential --- YET!
Get creative on the fenders just find some that are wide enough and then mod or fab some sheet metal or plastic mounts for them.
Wow, biohazardman, that is a very nice looking build yourself! I ordered a rear fender off of Amazon and I'll follow your advice - which is to create something that works!
So, there's a lot more to do on my build yet, and the list keeps getting longer! For me, I was willing to tackle building the bike with frame and parts from Oatnet/JD (plus dumped a wad of $$ at the local bike shop), and tried my hand at tearing up my brand new $250+ battery and ordering a BMS and charger from Ping in China (no warranty..). But so far, I'm not up to tearing the motor apart and improving the wires, or some of the other re-wiring suggestions made by others. First, I want to get the darn thing on the road!
Thanks again - you guys are great!
Mike
