trike velomobile
ivanio   1 mW
trike velomobile
Post by ivanio » Apr 12 2010 1:47pm
Vi presento la mia creatura in costruzione 5.304 Motore
saluti
John in CR   100 GW
Re: trike velomobile
Post by John in CR » Apr 12 2010 5:00pm
That should be a powerful and fun adult gokart. I wish I had a place to ride something so low and with no suspension. Do you plan a fairing?
full-throttle   10 MW
Post by full-throttle » Apr 12 2010 5:08pm
ivanio wrote:Vi presento la mia creatura in costruzione 5.304 Motore
saluti
Translation: "I'm presenting you my 5304-motor-creature in construction, cheers"
Ciao Ivanio, mi piace la tua creatura!
ivanio   1 mW
Post by ivanio » Apr 13 2010 12:21am
You will have a body I am going to start building. It felt wonderful to drive, I tried to 48v and is 47 km / h 60 km range with a battery of 30 Ah greetings
[quote = "John in CR"] Questo dovrebbe essere un potente e adulti gokart divertimento. Mi piacerebbe avere un posto da guidare qualcosa di così basso e senza sospensione. Non si pianifica un cupolino? [/ Quote]
[quote = "John in CR"] tempo condensato delle Nazioni Unite dovrebbe Potente Essere Adulti gokart e divertimento. Mi piacerebbe AVERE Un Posto da Guidare Qualcosa di sospensione Così Senza Basso e. Non SI pianifica cupolino delle Nazioni Unite? [/ Quote]
ggielen   1 µW
Post by ggielen » Apr 19 2010 4:58am
I like it. Allthough it might look like a go-kart, I think it is in all respects an HPV-tadpole trike. If you break it down to it's essence, it is more of a bicycle than a go-kart, allthough there is no real line separating the two.
This is going towards the direction I plan on taking for the MkII, step away from the tadpole trike 'standard' central tube down the middle in favour of dual main tubes. This allows for lower cg positioning, as well as offering a degree of crashcage. It also has structural benefits once you start taking it beyond a certain point and offers more options for attachment points if a full body fairing would be implemented.
The box down the middle contains electronics, batteries etc? And how is the ergonomics of the steering set-up? It looks like your arms could interfere with part of the frame when reaching for the sticks, but I guess this has been accounted for and I cannot judge properly just from the photos. Could you please post a detailed shot of how you constructed the kingpin pivots? This part was the most challenging to me, with all the angles required for handling meeting at one point of concentrated pita-ness. In hindsight, I think my solution is not even adhering to a few basic design rules regarding bearing mounting, I'd be interested in yours!
As I understand you are working on a body (fairing?) for this trike, coming along well?
Nice work!
Gijs
ivanio   1 mW
Post by ivanio » Apr 19 2010 1:51pm
I gotta start bodywork now or time trope work for summer use without bodywork and testing the trike to September beginning Carrozzeria greetings
John in CR   100 GW
Post by John in CR » Apr 20 2010 1:11am
ggielen wrote:I like it. Allthough it might look like a go-kart, I think it is in all respects an HPV-tadpole trike. If you break it down to it's essence, it is more of a bicycle than a go-kart, allthough there is no real line separating the two....
I like the no central tub too, for the same reasons. I do have to disagree though, in that except for the leaners, all of the tadpoles are much more like go-karts than bicycles. It's the nature of turning that puts them so distinctly in different categories. It's irrelevant though, because something like this looks like a ton of fun to ride.
maco10810   10 µW
10 µW
Post by maco10810 » May 02 2010 10:05pm
It looks great - nice work
ivanio   1 mW
Post by ivanio » May 15 2010 12:32pm
Nizza Cambiare Il frontale
Alla necessariamente per rendere Il Movimento centrale di 55 millimetri
bzhwindtalker   1 MW
Post by bzhwindtalker » May 15 2010 1:35pm
we'll need to race this summer :)
can you post some details about the pivots? they are from a kart ? I also have some for my build, how did you modify the front hubs?
ivanio   1 mW
Post by ivanio » May 16 2010 1:31pm
What's new Telaio Change
ivanio   1 mW
Post by ivanio » May 17 2010 2:46pm
Particles drawings and I find them here http://www.ilruotino.it/prodotti.htm
johnnythefox   1 mW
Post by johnnythefox » May 19 2010 8:00pm
Very nice.... This is the type of thing dreams are made of.
