macribs   1 GW
1 GW
Re: Zerode Tangent
Post by macribs » May 20 2017 1:59pm
zerodebikes wrote:Tangent ascent inboard where the gearbox usually goes.. super fun!
Sweet! We need more pics pls. Did you need to alter the frame or did the tangent drive fit straight in?
Does the chainline stay stationary while swing arm moves? It seems so from the pic but I don't know Zerode frame.
Overclocker   10 kW
Re: Your Creation's Before & After Pics
Post by Overclocker » May 27 2017 12:14am
neil.b   1 mW
Post by neil.b » Jun 26 2017 5:08pm
This was what my bike looked like when I bought it.
This is what it looks like now. :D
Hyperious   1 mW
Post by Hyperious » Jun 29 2017 12:08am
she started life as an ugly as hell hardtail conversion. Eventually I went into maximum overdrive on her
https://imgur.com/a/VHPwZ
upgraded from 48v to 72v @ 20ah, same hub but ventilated now and running 100+amps, shunt modded the controller, replaced the fets with 4110's, built an entire 12v side, added regen braking, added a BMS protected LiFePo4 battery, added onboard charging (will likely build a J1772 adapter box soon), beefed up the phase cables, and replaced the CAv3 with a KT LCD3. I'll likely get the motocross seat for the enduro frame as the bike seat is a pain in the ass to get on and off of since I'm pretty short at 5'9".
Jamessaki   10 W
Post by Jamessaki » Jun 29 2017 4:17pm
Refixing the page sorry
macribs   1 GW
1 GW
Post by macribs » Jul 02 2017 4:14pm
Always room for well made step thru frames. Those can be really nice for daily riding around town.
lester12483   10 kW
Post by lester12483 » Jul 08 2017 10:56am
Just made this one..
750 Watt front hub motor
48 Volt 23AH ALLCELL Battery pack
Locking storage trunk to house the controller, battery and wires.
Kevlar tires, and thinker tire tubes
*50 miles on a charge
electric mountain bike 2017.jpg (213.13 KiB) Viewed 4259 times
MT6 Hybrid- Electric Bicycle 48V
48V 23AH AllCell Lithium Manganese Battery Pack
http://www.chicagoelectricbicycles.com
Chalo   100 GW
Post by Chalo » Jul 08 2017 1:35pm
I bought one of those hard cases from my shop, just to see what I could do with it. My boss called it a trash can. :) I still haven't figured out an arrangement for it where I get to open the lid even 90 degrees. (On my bikes, the seat is above and overhanging the rack.)
wolf_rt   1 µW
Post by wolf_rt » Jul 13 2017 4:32am
Thought i would share a pic of my new baby.
Have had this bike for many years gathering dust, with the demise of my ute, i decided the time was right for an ebike.
BBSHD with 48V 11Ah battery.
I was initially worried about mounting this kit to the frame, and thought i would have to build a custom battery box, but it has actually worked out perfectly.
Really happy with it, and having a blast commuting to work... Have a rack, panniers and guards on the way, and will be wiring up lights to the pack as well.
Sean9002   1 kW
Post by Sean9002 » Jul 18 2017 12:07am
wolf_rt wrote:Thought i would share a pic of my new baby.
Photo bucket are a bag of dicks, so you can no longer use it as a third party host without paying. they will be out of business soon as this is an act of desperation, so i suggest backing up all of your photos to Flickr or Imgur.
OSET 20+ - Custom frame and swingarm, Motorims - 66V
Ruff Cycles Porucho - MXUS 3000w - whitewalls - Gloss black/Pearl blue/copper leaf - custom tanks - bobber saddle
Giant Glory 00 - Clyte X5404 - Hubsinks - 18FET Sinewave
Fuji Nevada S - MXUS 35mm- Hubsinks - 12FET Sinewave
39inch longboard Dual 50mm, 12s lipo
pwd   100 W
Post by pwd » Jul 20 2017 7:04pm
Current Build:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
em3ev 14S5P 30Q + 14S6P 25R pack
Build Thread: https://endless-sphere.com/forums/viewt ... =6&t=98286
Old Build:
GIANT ATX 980 w/ Cycle Analyst v2.25
Golden Motor Magic Pie (internal controller) X2
14S3P 15aH: 6X 6S 5000mAh + 3X 2S 5000mAh LiPo pack
Cricket_Swe   100 W
Post by Cricket_Swe » Jul 22 2017 1:46am
Crescent Njord 29" with AFT 1680W mid drive and Samsung 25r pack from EM3EV. This thing is a BEAST! I never anticipated such power but man! I'm in love :D
Before:
After:
neil.b   1 mW
Post by neil.b » Aug 06 2017 10:05am
Sorry I don't have a before pic but here is my latest build based on a Haro Extreme X7 I have owned for years. I have fitted a BBSHD and carry a 52v 17.5ah battery in my bag. :)
amberwolf   100 GW
Post by amberwolf » Aug 06 2017 6:44pm
SB Cruiser cargo / dog carrier trike:
https://endless-sphere.com/forums/viewt ... =2&t=67833
Been about 3/4 of a year since the last before/after:
https://endless-sphere.com/forums/viewt ... 5#p1251113
and it's changed appearance and functionality a fair bit.
Present appearance (August 2017):
That's without the white dog crate/kennel in the cargo area (it's still designed to slide in there to carry the dogs or loose cargo that wouldnt' sit or strap into the bed easily). Not all of the woodwork is complete; eventually once I have enough lightweight wood in decent shape, the sides and back of the cargo area will have removable panels to replace the need for the crate/kennel. That will give more room for the dogs and look nicer, as well as providing more insulation against the direct sun heating it up inside (aided by better ventilation than is possible with the crate/kennel). Yogi pretty well completely fills the plastic one:
Link to a post with present configuration info:
https://endless-sphere.com/forums/viewt ... 0#p1306890
"Original" appearance was a pile of cut up bike parts and scrap tubing/etc. :lol: But it's first pedalable appearance was this, back in March 2015
First decent appearance was
Had painted coroplast fenders and front "triangle" cover, which were easily damaged and only ziptied on.
Last appearance December 2016
All the covering was removed while the frame was reworked to move weight forward and add more secure cargo area, fix seating, pedal drivetrain, etc.
Ville   1 µW
Post by Ville » Aug 14 2017 6:31am
Just put a MAC motor on my Giant Anthem SX 27.5. Sawed-off thru-axle :lol:
Still got finishing to do.
Wolfeman   100 W
Post by Wolfeman » Aug 16 2017 10:35am
Ville wrote:Just put a MAC motor on my Giant Anthem SX 27.5. Sawed-off thru-axle :lol:
Great looking bike Ville, thanks for posting. 8)
Trek 4300 w/ H3580 Crystalyte at 3600W
https://endless-sphere.com/forums/viewt ... =3&t=82738
Worksman Mover M2020-3CB w/DD 750W front hub
https://endless-sphere.com/forums/viewt ... =3&t=96873
BCBeaver   1 mW
Post by BCBeaver » Aug 18 2017 11:23am
Before: Stock Giant Stiletto
After: 1000W Currie permanent magnet motor with roller clutch on the drive shaft turning a 13 tooth cog, with a chain turning a 68 tooth cog turning a bottom bracket. On the other side of the BB are 2 chain rings one is fixed to the BB shaft with a chain to the rear cassette the other is a BMX freewheel with a chain to the pedal BB. When I pedal with no power I don't have to turn the motor, when I motor I don't have to pedal & I can motor and pedal at the same time. Controller is a 100A 48V Kelly with the limit set at 40A, the battery is 36V, 30A continuous, 70A max output. It goes OK but not as good as it did with the first unlimited battery I used about 10 years ago. I was pulling about 70A from some paralleled NIMH packs, they lasted about a week before they burned. I'm ordering a 48V pack for it. It has a right hand twist throttle, left hand rear 7 speed grip shift.
neil.b   1 mW
Post by neil.b » Aug 28 2017 1:28pm
Well I decided to remove that fugly display and jumble of wires from my Haro/BBSHD combo, also got some new bars and a new direct mount stem to complete the new clean look. :D
skeetab5780   10 MW
Post by skeetab5780 » Aug 29 2017 8:13am
neil.b wrote:Well I decided to remove that fugly display and jumble of wires from my Haro/BBSHD combo, also got some new bars and a new direct mount stem to complete the new clean look. :D
Nice pic! Im saving a copy. Really clean looking bike (even though its cheating with no battery :)
neil.b   1 mW
Post by neil.b » Aug 29 2017 9:44am
Thanks for the kind words. I know its cheating but unfortunately its not an easy frame to mount a battery to. I would if I could though. :D
ferret   1 kW
Post by ferret » Aug 29 2017 10:48am
neil.b,
I believe that, for off road riding, a backpack battery is better than a frame mounted one. On my first build I switched from a battery box to a backpack and I went for a backpack from the get go with my second build.
Avner.
Don't believe everything you think.
Cove GNG-Spot build thread
Astral Rune build thread
neil.b   1 mW
Post by neil.b » Aug 29 2017 5:07pm
I agree that the backpack battery is better for off road. I have tried it both ways with my BBS02 on my hard tail and it definitely feels more like a motorcycle with that extra weight on the frame, although its much more convenient for the day to day use.
chefkendra   1 mW
Post by chefkendra » Aug 31 2017 1:02pm
This was my first bicycle build from just a frame, it's also a budget build.
*UPDATE
Information
60v 16ah Battery Pack (Built by me using 18650's) Upgraded from 48v that has been moved to another bike
1500w Rear Hub Motor Ungraded from 1000w that has been moved to another bike
Weight 75 pounds
Top Speed 40 mph (I didn't push it further so it might can go faster)
I ride normally between 18 -28mph this was only a test
The batteries are in the panniers
I KNOW THE BEST PLACE FOR BATTERIES ARE LOW AND IN THE MIDDLE BUT I LIKE THIS LOOK
My Ebike rides like a absolute dream, comfortable, fast and smooth
I've built 3 more ebikes since this one :) I'm completely hooked
Some Extra Stuff
Wired Dual Front Headlights
USB Port
Dual Battery Button for two packs
Custom Plug In Port
Suspension seat
Front Suspension Folk
Loud Scooter Horn
Bell
Rear Light
Aluminum Phone Holder
Trunk
Cup Holder
Alloy Pedals
Custom Stickers
Some Painted Touches
Mirrors
Before
After
Completed
Kendra Ebike.jpg (289.25 KiB) Viewed 1180 times
Women who build cool stuff...ROCK!
Wolfeman   100 W
Post by Wolfeman » Sep 01 2017 9:29am
chefkendra wrote:I just finished building this and I also believe this is my first post although I've been reading ES for quite some some time.
I bought a frame and build a bike. This is the first time I've build a bike from frame. It was an eye opening experience. I enjoyed it. This is an economy build sourcing parts from ebay, amazon, etc.
The hub is 48v 1000w motor off ebay.
Very clean looking build chefkendra. Hope you get a lot of miles out of it.
chefkendra   1 mW
Post by chefkendra » Sep 02 2017 5:05am
Thank you. :)
