Jetdryvr   1 mW
Re: E-S Stealth Electric Bike Owners
Post by Jetdryvr » Jul 02 2015 4:00pm
Hi guys,
Hopefully I'll be a B-52 owner very soon.
Could you guys help with a couple easy questions?
I am looking at whether to get a 2014 (4500W) one or a 2015 (5200W) for a LOT more money.
1. Is there a noticeable difference on torque/speed?
2. I know the 5200W display is bigger but does it do much more?
3. Is the motor the same (other than they added a thermal sensor)?
4. Is the speed control the same?
Any other differences I should know about but am not asking?
I really appreciate you guys' input.
I would probably upgrade some things over time but don't want to be limited by something that can't be upgraded easily without a lot of $.
Erik
Emmett   1 kW
Post by Emmett » Jul 02 2015 4:36pm
Cowardlyduck wrote: Emmett, have you actually spun up the motor yet?
You might have just bought yourself a spare of the same winding.
No I've not spun it up yet. I knew it might be a H4065 before I bought it. That would be fine. I think it is a H4040. Shall find out later this year.
Rix   100 GW
Post by Rix » Jul 02 2015 6:34pm
Jetdryvr wrote:Hi guys,
Erik
That's a tough one Jet. Here is my take for what its worth, get the 2014. I say this because if you get bit by the Stealth Ebike bug like most of us have been, you are going to want to modify your bike down the road whether its a 2014 with the CA putting down 4.5kw or the 2015 with the DC1 putting down 5.2kw. The DC1 Stealth now uses is better and more user friendly then the CA. It modulates DC input into the controller correctively quicker and more precise than the CA. I don't know how it compares to the CA V3, but this is the case with the CA V2. If you are a tinkerer, you will like the CA better than the DC1. CA settings can be accessed through menus and advanced menus where as the DC1, can be if you know how to :wink: but it will void any warranties and the diagnostic screen will show that as well.
Jetdryvr   1 mW
Post by Jetdryvr » Jul 03 2015 12:36am
Fix,
Thanks for the reply.
I probably could have found a better place to ask the questions.
I suppose the AC and DC etc are the older and newer displays.
Do you know if the motors are the same?
Speed control the same?
Thanks again,
Erik
Rix   100 GW
Post by Rix » Jul 03 2015 1:31am
Jetdryvr wrote:Fix,
Thanks again,
Erik
For 2014 and 2015, both motors and controllers are identical. Top speed should be the same, the 5.2kw Bomber should get there just a hair quicker than the 4.5kw Bomber, all else being the same of course with rider weight, wind conditions, temperature. Whether you go with the 2014, or the 2015, you cant go wrong.
remf   10 kW
Post by remf » Jul 03 2015 6:05am
Jetdryvr wrote:Fix,
I don't think so...Rick (Fix) :) is undoubtedly the best man to answer these questions...he's owned both CA type and DC1 type...and the difference between them is pretty interesting! I think the thermal rollback is a great new feature...not to mention the absolutely incredible new packs...minuscule sag and deep reserves but either one's the best choice for different reasons...the older model being obviously excellent value for money.
stevebills   100 W
Post by stevebills » Jul 03 2015 9:20am
Erik
buy the cheapest and modify to adaptto 12Kw in the future :lol: :lol:
Optibike and Stealth Bomber
stevebills   100 W
Post by stevebills » Jul 03 2015 9:33am
Whats the best way to practice whellies on a bomber
and best setup like should i drop my seat to the lowest postion?
thx steve
Jetdryvr   1 mW
Post by Jetdryvr » Jul 03 2015 9:55am
Thanks to all of you who responded to my questions. Very much appreciated. Now if I can get the seller to send a picture or two.
Rix   100 GW
Post by Rix » Jul 03 2015 6:56pm
remf wrote:
Jetdryvr wrote:Fix,
Oh yah, I did forget to mention the thermo rollback, and also, if the 2015 comes with the next generation battery, get it, even if the price is a few grand difference. Yah the new Bomber pack is what, 20 or 21s and 30+Ah? And a heavy duty rated BMS capable of north of 100amps. Hard to beat. Thanks Remf for pointing out what I left out.
Kepler   1 GW
1 GW
Post by Kepler » Jul 03 2015 9:00pm
Also worth mentioning MT5 brakes on the 2015 which are a big step up from the MT2. And the DNM front fork that have been re valved and tuned to Stealth specs.
If i was going from a 2013 to 2014 bike, I would go with the old model just because there really wasnt that many changes. 2014 to 2015 is a different story though and has been a big development year for Stealth. No right or wrong desicion here, just need to consider all the facts.
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
proper159   1 kW
Post by proper159 » Jul 03 2015 9:48pm
Really? Next gen Bomber batter is 30+ ah?
Rix   100 GW
Post by Rix » Jul 03 2015 10:24pm
Kepler wrote:Also worth mentioning MT5 brakes on the 2015 which are a big step up from the MT2. And the DNM front fork that have been re valved and tuned to Stealth specs.
Yah, Kepler, I should have thought a little more about my response to Jet. 2015 Bomber was a ground breaking year. Sort of a model overhaul.
Yah, Remf posted several pages back that he got the next generation battery for his Bomber, went for a long ride, and consumed 35Ah and still had a little left. Not surprising as battery tech is improving every year.
Rix   100 GW
Post by Rix » Jul 03 2015 10:28pm
remf wrote:Some more FYI - I just got a new pack and so reset my CA...had a look and have travelled exactly 60 miles since. That was 3 recharge cycles, used 35 Ah, unrestricted Amps at an average speed of 25 mph over hilly terrain without using regen (I need a new button).
Here is the post Proper.
Kepler   1 GW
1 GW
Post by Kepler » Jul 03 2015 10:32pm
My understanding is the Fighter battery has had a significant capacity increase or is about to but the Bomber battery cap stays the same for the time being. As mentioned by Rix, the big difference with the 2015 Bomber battery is how well it holds voltage and gives you consistent performance across the full range of the battery.
Current Rides
Kepler   1 GW
1 GW
Post by Kepler » Jul 03 2015 10:39pm
Speaking to Joe at Stealth last week he was getting up to 120km of a prototype Fighter with the new battery. Entirely new chemistry. Battery tech is moving in leaps and bounds. exciting stuff.
Current Rides
proper159   1 kW
Post by proper159 » Jul 03 2015 11:00pm
Wow...that would be my dream to have 35ah. If I could cover a 60 km trip as if I'm riding 35 km trip (hard), that would be pretty amazing. I have to get up really early tomorrow to ride my Mando Footloose in Eco with hard setting series hybrid (pedal power generation) just to cover 35 km at 13 mph. I'm curious how much alower Eco mode is on the new fighter.
remf   10 kW
Post by remf » Jul 03 2015 11:39pm
I should clarify & emphasise that the 35Ah consumed was over 3 charge cycles...as Kepler said, the capacity of the Bomber pack hasn't changed but the capacity of the new Fighter pack sure has...30Ah of absolute awesomeness!!! It's amazing to go for a ride and finish at the same voltage you started at. Also the new fast charger makes short work of an empty pack. Don't ask me how much the new pack cost...that's the painful part...ask me was it worth it. So worth it.
Rix   100 GW
Post by Rix » Jul 04 2015 12:16am
Kepler wrote:My understanding is the Fighter battery has had a significant capacity increase or is about to but the Bomber battery cap stays the same for the time being. As mentioned by Rix, the big difference with the 2015 Bomber battery is how well it holds voltage and gives you consistent performance across the full range of the battery.
Yah the Fighter battery has a significant increase in capacity. I misunderstood Remf's post about his Bomber's battery, but still, that doesn't change the fact that the new batteries are performing way better than the older generation. That translates too power to the rear wheel, and a bigger grin on the riders' face. :mrgreen:
remf   10 kW
Post by remf » Jul 04 2015 1:24am
Just came back from another short burst on the Fighter and found out that my regen actually does work. I thought it was broken but it isn't...it's just that the new pack has such little sag that it took 22 km before the voltage dropped below 56V, enough for regen to kick in. Jaw dropping.
sethgl   100 µW
100 µW
Post by sethgl » Jul 04 2015 1:53am
Hi, I have a current issue with my fighter, after riding for a couple of kms I use full throttle and it works for about 1 km or so the the bike shuts off with nothing on the cycle Analyst. Then I pedal down a hill to get enough speed up and use the re-gen button and it powers up again and I can get another 10kms or so. But again if I use full throttle it shuts down again. Does anyone know of any reasons this is occurring. Thanks in advance.
remf   10 kW
Post by remf » Jul 04 2015 2:16am
I think I can say with maybe not 100% certainty that you have a problem with your pack, possibly a fried cell or 2. I would contact Stealth...they can repair it or point you to other solutions depending on your location.
sethgl   100 µW
100 µW
Post by sethgl » Jul 04 2015 5:15am
Thanks remf I appreciate it. I will contact stealth.
Theodore Voltaire   10 MW
Post by Theodore Voltaire » Jul 04 2015 10:54am
So when is the new bigger Bomber battery coming out? :D
Rix   100 GW
Post by Rix » Jul 04 2015 11:07am
Theodore Voltaire wrote:So when is the new bigger Bomber battery coming out? :D
Got to be soon, Stealth can't leave the smaller Fighter as it is with more range potential than the Bomber.
