Show off your Ebike creation here.
FL bomber   100 W
Re: E-S Stealth Electric Bike Owners
Post by FL bomber » Jan 02 2020 3:38pm
Do I turn allen wrench clockwise to remove left side crank arm on v-box?
A New year's Eve mishap 😒 don't mix bomber
With flor de Cana. Should have used with my A2B 😲
Theodore Voltaire   10 MW
Post by Theodore Voltaire » Jan 02 2020 5:51pm
FL bomber wrote:
Jan 02 2020 3:38pm
Yes, left side is reverse thread.
Post by Theodore Voltaire » Jan 02 2020 5:54pm
Thorsaw wrote:
Jan 02 2020 12:52pm
I have recently purchased a stealth clone ebike. I've been lurking endless sphere for a while but have never posted. I wanted to see if anyone has had any luck registering/titling their stealth or stealth clone or personal build as an actual motorcycle. My bike has a qs hub motor 8000 watt continuous 12000 peak. I was hoping to buy a lighting kit and getting some DOT approved tires. There's also a company online that says it will be able to title and register my bike as long as it passes inspection and has a serial number and bill of sale. They mentioned that they've gotten five Sur Ron light bees registered and titled no issue.
I guess the question is has anybody actually succeeded in this? Thank you
Can't be done in Texas. No VIN#, and no process to get one.
amberwolf   100 GW
Post by amberwolf » Jan 03 2020 1:25pm
Thorsaw wrote:
Jan 02 2020 12:52pm
depends on where you are and the local specific requirements for registering.
its different in different localities for different vehicles, so since you don't give your locality, no one can tell you anything about your particular process or needs.
so you must check with your local dmv and/or local site listing the specific regulations and requirements, then ensure your vehicle meets those specific requirements, then go thru whatever process those requirements list.
if your specific vehicle does not come with a vin of the right type from the manufacturer, and that manufacturer is not on the list (if there is one) of registered manufacturers in your locality and/or federally, it may not be registerable at all.
Thorsaw   10 µW
10 µW
Post by Thorsaw » Jan 03 2020 5:41pm
I've been told by dirtlegal.com (I have no affiliation) that a serial number and bill of sale is required for Maryland and NOT a vin. If I succeed I will post my results. If I Fail I will still post so others can gawk at my misfortune. Brave New world?
Post by Theodore Voltaire » Jan 20 2020 10:11am
Yesterday I was about to suggest that the Sur Ron looks like a good bike for a typical stealth owner, then I remembered that Rix, and Alex has one.
This is what I'm talking about.
Post by Theodore Voltaire » Jan 20 2020 10:20am
I also noticed that Texas has changed their moped statutes making it easier to register a bike that doesn't have a VIN. I think I could register my Stealth in Texas as a moped now if I wanted to bad enough. As it comes limited from the factory it would qualify. There's just a form that needs to be filled out and notarized by the seller that states it has less than 5 hp, and has less than 30 mph top speed. You would need lighting, but mopeds aren't required to meet DOT requirements.
Cowardlyduck   100 MW
Post by Cowardlyduck » Jan 28 2020 7:04am
Finally got my Fighter (mostly) back together and first ride was to check out a massive fire heading my way as Australia burns.
Sorry for the crappy quality photo/video...it was smokey and super windy up there!
The right hand side is the sunset...the middle/left is the fire.
I'm not in much danger where I am as I'm in the middle of the southern suburbs of Canberra, but still scary none the less!
Cheers
ebikegarage.com.au - My website
Cowardlyducks - Videos - Ride videos
Custom made 18650/21700 battery packs - Australia only
FL bomber   100 W
Post by FL bomber » Jan 30 2020 12:32pm
Sad to see what's happening in Australia.
Hope your home stays up wind of the fire.
Stay safe C D
whitebomber   100 mW
Post by whitebomber » Feb 02 2020 3:07am
Can anyone help me out with instructions on how to connect lights directly to the battery and also a great light option for bush work. Anyone using light bars?
Allex   1 GW
1 GW
Post by Allex » Feb 03 2020 8:08am
Theodore Voltaire wrote:
Jan 20 2020 10:11am
Well maybe this one with streamers?
Post by Theodore Voltaire » Feb 03 2020 8:17pm
Allex wrote:
Feb 03 2020 8:08am
Why not?
KarlJ   100 W
Post by KarlJ » Feb 04 2020 12:39am
Stock RST forks have finished leaking out their oil
Is this the correct USD-8 for the Bomber
https://www.ebay.com.au/itm/DNM-USD-8-M ... ctupt=true
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 04 2020 6:17am
Another Stealth is soon to get a monster battery upgrade.
Guess which variant.
Cheers
Post by Theodore Voltaire » Feb 04 2020 9:46am
KarlJ wrote:
Feb 04 2020 12:39am
Yes, those will work.
Rix   100 GW
Post by Rix » Feb 04 2020 12:19pm
Cowardlyduck wrote:
Feb 04 2020 6:17am
Cheers
Whats the numbers for this battery?
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 04 2020 5:53pm
Rix wrote:
Feb 04 2020 12:19pm
It's 20S12P. 3Kwh.
Should be good for over 100km range on the particular Stealth variant it's going in. Any guesses?
Cheers
Allex   1 GW
1 GW
Post by Allex » Feb 05 2020 8:47am
Why not 14p? :wink:
bigbore   10 kW
Post by bigbore » Feb 05 2020 10:52am
This Bomber above now need a V-Boxx service or maybe a new V-Boxx. What's your advice to buy a new V-Boxx? Some time ago I read that Mammuth from Russia may sell it but I contacted them without any reply.
Or does Stealth bike sell replacements for V-Boxx?
Cowardlyduck   100 MW
Post by Cowardlyduck » Feb 05 2020 4:58pm
Allex wrote:
Feb 05 2020 8:47am
Why not 14p? :wink:
I offered, but I think 12p was enough for this guy.
Is there any pictures of the cell layout and dimensions of that pack Alex? I'm fairly sure I know how you did it, as I did similar on my Fighter, but not quite sure how you got the length.
Cheers
KarlJ   100 W
Post by KarlJ » Feb 05 2020 7:04pm
My next battery build will be top and bottom the same ie each of the top and bottom rows have 20S then when you fold the top over they cannot make an internal short even after any movement that may cause the insulating material to fail.
from there i'd add the other 2S ontop flat like your fighter pack for 22S 12P.
unfortunately by my calculations thats 35,000kms away!
On a great note i did 3000kms in 90 days with christmas holidays of 2 weeks with no riding in there too.
now 6500kms on the clock and showing 64 cycles on the battery, for a cycle (according to the CA) of 47kms.
Only charging to 90V and discharging to 80V, 80% of the time with average distance between charge of 32kms
I'm calling it 400 full cycles as per the datasheet for the LGMJ1 to ~80% remaining capcaity hence should do at least 600 given the lower max charge at 4.1V/cell and ~800-1000 or more before I no longer have enough capacity to goto work 1 day.
This gives us somewhere in the vicinity of 37-45,000kms pack life in my case.
Given this is 7+ years at 6000kms / year - choose your battery type and pack size VERY carefully as you'll live with it for a LONG time (and its not a cheap exercise).
My mistake - should have done 12P, should have built top and bottom layers the same ie 20-22S top and bottom so risk of short due to rubbing between the two layers eliminated.
22S with the stock controller produces 6300W under load hot off the charger with my pack, decreasing to 5000W when pack is down at 70V (unloaded) which is as low as i've needed to run it so far.
Post by Theodore Voltaire » Feb 05 2020 8:35pm
bigbore wrote:
Feb 05 2020 10:52am
I think your choices are,
1. take it apart yourself, and order spare parts from Stealth.
2. send Stealth your VBoxx for repair
3. order a new VBoxx from Stealth for about us$1100+
litespeed   100 kW
Post by litespeed » Feb 05 2020 9:04pm
KarlJ wrote:
Feb 05 2020 7:04pm
That is the reason I built a 20s15p 30Q pack.....couldn’t go 22 with a MaxE other wise I probably would have.
Good advice.
Tom
1abv   10 kW
Post by 1abv » Feb 06 2020 7:03pm
bigbore wrote:
Feb 05 2020 10:52am
I've torn mine down 3 times, its not that big of a deal as long as your detailed oriented.. you may be able to get spares from Stealth for your vboxx depending on whats wrong with it. You could always buy a new one and keep this as a spare parts box as well..
If you send it in to Stealth they send it to tawian for repair and the turnaround is at least 3-5 weeks
