Show off your Ebike creation here.
Theodore Voltaire   10 GW
Re: E-S Stealth Electric Bike Owners
Post by Theodore Voltaire » Aug 09 2022 8:55am
Turbomatic wrote:
Aug 09 2022 1:58am
Theodore Voltaire wrote:
Aug 05 2022 11:36am
Since then I haven't heard anything. Maybe you can find out if this is normal?
Hello! I'm from Nucular, can you send me in pm your email, I'll check.
Also, please check your spam folder.
Thank you for reaching out to me Turbomatic. I double checked my spam folder and found the reply I was I was waiting for. Looks like my pre order is in the queue. This is good news.
1abv   1 MW
Post by 1abv » Aug 09 2022 7:55pm
Good day sunshine
Post by Theodore Voltaire » Aug 11 2022 2:40pm
uh oh, I think I many have blew out one of my halls playing around with my diagnostic tool. Is that even possible? All I know is one of my halls seems bad now. The first time I checked them the other day, all the halls checked good, but now one of them checks bad. The controller still checks bad, same as before.
I may have shorted one of the hall signal wires to 5v. Suspiciously the one that now test bad is the black wire, which is in between the positive, and minus, probably the easiest one for me to short.
Female Hall Plug controller side.png (339.89 KiB) Viewed 376 times
Rix   100 GW
Post by Rix » Aug 12 2022 12:55pm
Aug 11 2022 2:40pm
Can't you like rig it with some streamers and get it running? :wink:
Post by Theodore Voltaire » Aug 12 2022 2:52pm
Rix wrote:
Aug 12 2022 12:55pm
Aug 11 2022 2:40pm
I wish, but no, my streamer technology only works for cloaking. When I get my bike running again I'll probably need longer streamers.
Post by Theodore Voltaire » Aug 12 2022 7:04pm
I'm trying to buy one of these motors, but he seller seems reluctant to sell me one because they're afraid it won't fit my bike. Its for 150mm drop outs, but it says the axle is 225mm, which should be able to work, don't you think?
https://www.amazon.com/gp/product/B086G ... UTF8&psc=1
Post by Theodore Voltaire » Aug 13 2022 4:28pm
Aug 12 2022 7:04pm
Since everyone is in agreement, I told them to ship it.
1abv   1 MW
Post by 1abv » Aug 13 2022 4:39pm
More of that damn sunshine…
Allex   10 GW
Post by Allex » Aug 13 2022 6:07pm
Aug 13 2022 4:28pm
Aug 12 2022 7:04pm
viewtopic.php?f=6&t=62650&start=225#p1165502
Post by Theodore Voltaire » Aug 13 2022 10:22pm
Allex wrote:
Aug 13 2022 6:07pm
Aug 13 2022 4:28pm
Aug 12 2022 7:04pm
Thank you so much Alex, this is exactly what I need to see. You're the best.
Post by Theodore Voltaire » Aug 14 2022 9:23am
I actually made 3 posts in that thread, but I forgot about Bigbore installing a QS 205.
1abv   1 MW
Post by 1abv » Aug 14 2022 5:27pm
Power lines and ebikes.. I like the tingly feeling I get in my handlebars… that’s safe right?
Post by Theodore Voltaire » Aug 15 2022 11:23am
This is the plug from the Kelly controller that works the throttle which uses 4,20, and 3.
My question is what does 8 do? It doesn't appear anywhere on the wiring diagram.
throttle connection.JPG (30.91 KiB) Viewed 401 times
Rix   100 GW
Post by Rix » Aug 15 2022 2:52pm
1abv wrote:
Aug 14 2022 5:27pm
If you are unlike me and have hair, it may stand up. All good though. I bet you felt charged after that ride.
Rix   100 GW
Post by Rix » Aug 15 2022 2:53pm
Aug 15 2022 11:23am
Do some research, it may be an ebrake sensor or PAS wire of something like that.
Rix   100 GW
Post by Rix » Aug 15 2022 2:54pm
Aug 12 2022 7:04pm
Our dropouts are 162mm just get some 10mm X 14mm spacers and it will be fine.
Rix   100 GW
Post by Rix » Aug 15 2022 2:55pm
Aug 12 2022 2:52pm
Rix wrote:
Aug 12 2022 12:55pm
Aug 11 2022 2:40pm
:lol: :lol:
Post by Theodore Voltaire » Aug 15 2022 4:31pm
Rix wrote:
Aug 15 2022 2:54pm
Aug 12 2022 7:04pm
Thanks Rix, 162 is even less than I thought. That should make it a piece of cake.
Rix   100 GW
Post by Rix » Aug 15 2022 5:33pm
Aug 15 2022 4:31pm
Rix wrote:
Aug 15 2022 2:54pm
Aug 12 2022 7:04pm
and you got a little wiggle room for perfect chain alignment or disk brake alignment.
1abv   1 MW
Post by 1abv » Aug 16 2022 9:21am
The stealth bomber is like an ebike on crack…
Crack??? Get it?? Visual humor? Crack? Anyone?
Rix   100 GW
Post by Rix » Aug 17 2022 2:53pm
Be careful, crack can kill, and if you die face down you are crack up.
Post by Theodore Voltaire » Aug 18 2022 12:34am
1abv wrote:
Aug 16 2022 9:21am
Are those gold nuggets on the ground, or am I on crack?
1abv   1 MW
Post by 1abv » Aug 18 2022 9:22pm
More cows…
Post by Theodore Voltaire » Aug 18 2022 9:48pm
1abv, I've been studying up on connecting a Kelly controller to a ca, these are my thoughts. The Kelly controller renders the ca kind of redundunt for a lot of it's features. The ca will really only be useful as a speedo/odo/trip meter, a volt meter, and checking your current, and ah used. All the connection points to hook it up will already be located up inside the frame, except the hall wire. The hall wire is the only wire that will need to be run from the controller to the ca. I wouldn't want the ca to be able to overide the Kelly, so I don't see any reason to hook the throttle to the ca. In my case since I already have what now days they call a eco mode switch, I guess I might run one more wire from the controller to activate it, even though I never use it. I'm not planning to hook up the regen automtic axle bolt unscrewer either.
Here's a link for a shunt that's not to enormus. I'm thinking 150 amp, 50mv
http://www.cshunt.com/pdf/la.pdf
1abv   1 MW
Post by 1abv » Aug 19 2022 9:37pm
Thats why I would like to try and find another solution not involving the CA at all so no shunt needed ideally.. I only use the CA for
speed trip odo volt current ah usage anyway. So if I can find a display that would do that w/o a shunt then im all good. Seeing as how onyx has a display w/o a shunt im wondering if that display would work.. but really ive been riding too much to move quickly with it. I extended part of the wiring harness to work. Still have to build the battery extension and breaker.
