Show off your Ebike creation here.
Rix   100 GW
Re: E-S Stealth Electric Bike Owners
Post by Rix » Jul 27 2021 1:37pm
bigbore wrote:
Jul 24 2021 9:16am
Nucular controller installation done. :D
These are some pics of what I think interesting.
The nucular controller allows for a clean installation and having more space I could mount the bracker in a better way.
Using this stuff I attached the bracker to the frame
New skid plate installed.
Display relocation. I don't like the mounting position above the handlebar stem, so I made this bracket to have the display a little further on
This is a tight fit of the ANT BMS on top of the battery a few mm more and could not fit.
I hope that when Nucular has its own BMS it is no more than 15mm thick.
That came out really good, I like how you mounted the breaker fuse switch. That is clean. Also, the skid plate is perfect, you going to offer that up for sale?
Rix   100 GW
Post by Rix » Jul 27 2021 1:39pm
Billy.A wrote:
Jul 24 2021 2:28am
Decided to change the color of the B52 logo to white, had to pull the side covers off and they are 2 piece with silicon holding them together.pulled them apart, cleaned them, flipped them to the silver side and put a fresh cover of carbon fiber and added some white contact and stuck them all back together again..
i like the results, now the red pedals are removed and the logo is in white, looks much better, even have the old red bars which will look a whole lot better now that most of the red is removed, ill keep them for future change out.
Even decided to flip the banjo bolt location from the inside of the caliper to the outside,
Thats how bored i was during this lockdown :roll:
The white logos came out great on the covers. :bigthumb:
1abv   100 kW
Post by 1abv » Jul 28 2021 12:39pm
Nursing tree....
Billy.A   10 mW
Post by Billy.A » Jul 29 2021 5:49am
Rix wrote:
Jul 27 2021 1:39pm
Billy.A wrote:
Jul 24 2021 2:28am
Cheers Rix
Brakes have arrived today guys, ill fit them this weekend and let you know how they go.
Went with-
Magura 220mm rotors with adaptor for the front..
Magura 203mm rotors for the rear
and Magura sport brake pads.
i went with the 203 for the rear because the rears already have an adapter and you cannot stack adapters one on top of the other.
its easier to just stay with the 203 rather than trying every adapter Magura make to see which one will fit.
On a different note,
im thinking of fitting a motorcycle horn to the Bomber, the bell is just not cutting it.
ill have to see if it is possible but im thinking to buy another re-gen button and mount it to the top bracket mount-(see pic)
and mount the horn on the top control box bolt.
bell pic_LI.jpg (4.88 MiB) Viewed 481 times
any info, suggestions or criticisms will be greatly appreciated :)
Cheers Guys
1abv   100 kW
Post by 1abv » Jul 29 2021 2:14pm
I don't know it the hole spacing would fit but check out these guys. I have a few of their switches on my dirbikes. They are fantastic..
https://www.highwaydirtbikes.com/index. ... ef=HDB-400
Cozen89   100 mW
Post by Cozen89 » Jul 30 2021 2:33am
I have these Same 220mm rotors in a box in my garage. I’m waiting to install them but I feel like I want to put some more wear and tear on the stock ones first. The looks are definitely killer. Hopefully the performance matches the looks.
Billy.A wrote:
Jul 24 2021 6:38pm
Brake Disc rotor Upgrade
Hi Everyone
im looking to upgrade the stock, Storm 203mm disc rotors front and rear,
i find they struggle with the weight of the Bomber let alone the extra 92kg of the rider,
they were not designed for such forces :flame:
they are glazing and warping under load.
im looking into maybe getting this option, its a 220mm 2 piece disc rotor Magura make especially for E bikes in mind,
there is also a Magura adaptor from 203mm to 220mm
Being 2 piece and 220mm, its got to be a lot better than the 203mm rotor with less flex and better heat dissipation,
plus the rotors look sexy too :D !
There are also Magura Sport pads which are made for Ebikes
Has anyone used these or know someone who has or perhaps might know a better solution?
would be interesting to get some feed back, If i buy them ill fit them on my next tyre change and let you guys know what i think.
Have a great day everyone :thumb:
Cozen89   100 mW
Post by Cozen89 » Jul 30 2021 2:38am
Finally installed the 2nd prototype for my headlight plate for the fisher Fabhouse light. A much more slim design, and now the headlight is powered off the main bike battery. There’s a few imperfections on this print but that’s ok for now.
I forgot to take better pics of it when I was out riding because I was enjoying myself too much. More to come soon!
Billy.A   10 mW
Post by Billy.A » Jul 30 2021 3:13am
Cozen89 wrote:
Jul 30 2021 2:38am
looks really good mate, top job, nice and streamline too :thumb:
i fitted the brakes today, just managed a quick bed in before it got dark, ill see how they go on tomorrow's ride.
Theodore Voltaire   10 GW
Post by Theodore Voltaire » Jul 30 2021 8:37am
Looks good Cozen89, kind of has an Ironman look.
Post by Theodore Voltaire » Jul 30 2021 8:50am
Billy.A wrote:
Jul 30 2021 3:13am
I'll be surprised if you notice a huge difference in braking power since the MT5s would already lock up the front brake, but there should be a big improvement in heat management. I doubt you'll be overheating those brakes now.
1abv   100 kW
Post by 1abv » Jul 30 2021 12:46pm
Cozen sweet man!! that's pretty cool! shadowy flight into the dangerous world of a man who does not exist!!! Night rider!!!!
New brakes are always fun to see the difference if there is any... I have gone back and forth between pads on my bike Shimano oem vs aftermarket... The Truckerco Sintered Metallic Disc Brake Pads are not as good as the Shimano they don't last as long and don't quite have the same feel but... they are $13.00 vs $44.00 and the difference between them is not that much. I would say they are about 80 percent the pad that the shimanos are. I use them in the rear and they are fine. Only on long, like 1/2-1mile long downhills do I notice the difference..
bigbore   10 kW
Post by bigbore » Jul 30 2021 4:20pm
Rix wrote:
Jul 27 2021 1:37pm
bigbore wrote:
Jul 24 2021 9:16am
The skid plate is built around the controller I have now, before I had made one for Adaptto. Who could want it the same?
In the end it is a 2mm lexan sheet shaped, perforated and cold bent.
Cozen89   100 mW
Post by Cozen89 » Jul 31 2021 1:54am
Theodore Voltaire wrote:
Jul 30 2021 8:37am
Ha, I never thought about that. Thanks!
Billy.A   10 mW
Post by Billy.A » Jul 31 2021 6:24am
Confucius say:-
Man who leaves ignition on, whilst his bike is indoors is asking for trouble!....oops! :( :oops:
Jul 30 2021 8:50am
[quote=Billy.A post_id=1668493 time=1627632829 user_id=79767
spot on Theodore, the braking difference between the 2 is minimal but they are a lot quieter and the s pads have got great bite
there is a difference but nothing crazy.
im very happy with the brakes now.
i have also noticed that my front rim is the same as the rear in terms of thickness, other Stealth's ive seen have a thinner, lighter front rim??
this is my front rim
HK12K   100 kW
Post by HK12K » Jul 31 2021 10:21am
Billy.A wrote:
Jul 31 2021 6:24am
Confucius say:-
Lmfao. I almost launched my bike onto the roof of my work building a couple weeks ago. Forgot to switch off the controller before manuvering it into position by the bike rack. Grabbed a handful of throttle while standing next to it and looked a fool to my coworkers as it immediately went from horizontal to vertical.
Post by Theodore Voltaire » Jul 31 2021 9:08pm
Billy.A wrote:
Jul 31 2021 6:24am
Both of my stock skinny ass rims were the same size on my 2013, only the spoke holes were different sizes. The rims are strong enough though, they just don't fit the proportions of the rest of the bike. Not that I don't think Stealth is great though, they are, but after all these years it's time for a little styling update. And BTW I'm available for a work from home position. As soon as they hire me, my first order of business will be to make an all street model which will instantly outsell the entire lineup many times over. Well at least 3 or 4 times over.
Cozen89   100 mW
Post by Cozen89 » Aug 03 2021 3:49am
I know most of you own bombers, but for us little guys, has anyone gone to a 72v Battery on their F37? Stealth says the stock controller and motor can handle it. Can anyone share their experience or details on the process? Thanks!!
1abv   100 kW
Post by 1abv » Aug 03 2021 11:10am
It's high 80's that fateful early morning.... The motor just hit around 120 degrees and im 10 miles from my starting point when all of a sudden I hear the dreaded noise... pssshhhhhhhhhhhh.. I hop off the bike and check the rear tire.. yup flat... soo what do ya do... cool down for a minute next to a tree let the motor cool to about 100 and find the nearest fire road and ride it back..... As long as I didnt hit any sharp rocks and traveled around 15-20 mph the tire felt low but rideable.. if it was a bicycle tire on the rear I would be typing this from the trail and there would be A LOOTTTTTT of cussing...... BTW another old school offroad trick. Bring a few big ass zip ties and wrap them around the rim and the tire in a few places and the tire wont fall off the rim. another nother note.. use rubber tubes not the synthetic. they form better to the tire which allow lower pressures and last longer. How do I know this??? hmmmm......
part 2
I set up the bomber now so that I can swap a tube without unplugging the hall/ temp wires I could have not unplugged the phase as well but old habits....everytime I do unplug them I put on a dab of dielectric grease.
Post by Theodore Voltaire » Aug 03 2021 2:03pm
This is what I use. The biggest problem is most people don't know how much to put in their tire. It comes in a gallon jug so obviously you put a gallon in each tire.
Rix   100 GW
Post by Rix » Aug 04 2021 9:58am
Cozen89 wrote:
Aug 03 2021 3:49am
Go back to pages 100-300, you will see several Fighters with 72 volt packs. Specifically Hyena's Fighter was modded to 10+kw back when 5kw was the powerhouse standard.
Rix   100 GW
Post by Rix » Aug 04 2021 10:00am
ABV1 and Cozen, awesome pics guys!
1abv   100 kW
Post by 1abv » Aug 04 2021 3:07pm
Billy,
I looped my bike the first day I had it adjusting the suspension while holding on to the throttle that I didn't realize was on! My rims are the same size front to back. I thought at some point that stealth was offering moto rims on the rear or am I on crack?
Cozen
Nice pics w the golden gate behind you!
TV
Does that stuff make a mess for you when a puncture occurs then after you want to change the tube/tire?
Post by Theodore Voltaire » Aug 04 2021 5:33pm
1abv wrote:
Aug 04 2021 3:07pm
TV
Not always, but often it does. It's not a big deal though, because slime is highly water soluble so the mess is easily washed away. I used to think slime wasn't worth a crap, but then I learned 3 things about it. 1. Buy the kind for tubeless tires. Even though we have tubes, it works better in a tube than the kind they market for bicycles which is slightly different. 2. Use about twice as much as they recommend in your tire. 3. If you happen to get a flat, fill the tire back up with air immediately. This happened to me on several occasions, where my tire went flat, and I filled it back up, and weeks went by with no loss of pressure.
Post by Theodore Voltaire » Aug 06 2021 11:56am
I'm afraid Stealth is wasting their money on Castaglione. The American street market is where it's at, and he probably doesn't know squat about it. Stealth doesn't need to reinvent the wheel to dominate the American market.
Almost all of the new fast eBikes suddenly coming out in the last 3 or 4 years, which are all the rage, have bench style seats. Stealth should build a longer seat sub frame for a somewhat longer seat than the one I adapted to my bike. I don't want to make mine longer because I'm afraid the stock sub frame might break off if I put my weight further back. Next add fenders and lights, and a more street oriented display that's higher in the line of sight. My 24" x 65mm rims make my bike look bad ass compared to the stinky little wheels on an Onyx, or Sur Ron, or the stubby fat 20 inchers on Super 73s. Besides that, they also have superior function on the street. No changes are needed to the rest of the frame, but something that would be hard for me to do, but easy if I was a factory is, I would experiment with adding a little shape to the side covers. This could have two added benefits. 1. add a little extra styling, and 2. allow the battery to extend outward a little past the edge of the main frame for increased battery capacity.
Most of the young new riders I meet now have never heard of Stealth. They love my bikes looks, but they don't know it didn't come that way from the factory. When I tell them my bike is a 2013 model they're absolutely, and universally blown away. Stealth truly has always been light years ahead of their time, but the time is now. Build it and they will come.
1abv   100 kW
Post by 1abv » Aug 06 2021 12:12pm
good day sunshine....
