FL bomber   100 W
Re: E-S Stealth Electric Bike Owners
Post by FL bomber » Jul 11 2018 3:42pm
EMP... Ebike Marketplace in Nevada is making bomber battery packs out of 21700 cell's. Anyone seen these yet?
bigbore   1 kW
Post by bigbore » Jul 12 2018 7:56am
Brand and type of cells? How many cells in series and how many in parallel? Do you have some more info?
FL bomber   100 W
Post by FL bomber » Jul 12 2018 10:52am
EMP is using Samsung 48g.. LG M50.. also cell the call RPE sourced from China. They said the 48G and M50 are 3C the RPE is 9C. There packs are 72v
20ah up to 40ah. Don't know how many
Cells in parallel.
bigbore   1 kW
Post by bigbore » Jul 12 2018 12:40pm
From the info I guess 20S8P that is about 11Kg battery if made with Samsung and LG cells because there I read: "Samsung and LG cell only available for 40Ah battery"
I guess it's a good stock Bomber replacement battery at 2.5K USD for the 40Ah type.
Here is a review of the Samsung INR21700-48G
https://lygte-info.dk/review/batteries2 ... %20UK.html
Then with these data:
Maximum Instantaneous discharging current Amperage of BMS (A): 160
Maximum continuous discharging current Amperage of BMS(A): 80
We have 20A peak current and 10A continuous current for each single cell and it seems they can leave with 10A continuous:
Interesting is the voltage drop compared to Samsung 30Q:
But now we need some experts to find out if 21700 is better than 18650 in Wh/Kg :)
Here is the thread of these new battery: viewtopic.php?f=14&t=90515
Theodore Voltaire   1 MW
Post by Theodore Voltaire » Jul 12 2018 2:01pm
40 amp hours would really be something. That would basically turn my bike into a motorcycle.
1abv   1 kW
Post by 1abv » Jul 15 2018 5:04pm
Where is waldo?????
Rix   100 GW
Post by Rix » Jul 16 2018 12:24am
1abv wrote:
Jul 15 2018 5:04pm
Where is waldo?????
This actually took me a few seconds, but I found the mean green machine! 8) :D :lol:
1abv   1 kW
Post by 1abv » Jul 16 2018 1:10am
That was in a pretty cool riding area out in so cal near simi valley... now all I need is more range!
bigbore   1 kW
Post by bigbore » Jul 16 2018 7:21am
Beautiful :D All I need instead is to rebuild my V-Boxx ..... after 1st, 2nd and 4th now 8th gear start going bad :cry:
1abv   1 kW
Post by 1abv » Jul 16 2018 1:22pm
Sounds like its the center sprocket on the center shaft. the sprockets are sandwiched in place with 2 Allen screws.. May be that assembly got loose.
FL bomber   100 W
Post by FL bomber » Jul 17 2018 8:42am
Mammoth ebike sells vbox $900 plus shipping.. I was thinking of ordering one since mine leaks where the sprocket is.
bigbore   1 kW
Post by bigbore » Jul 17 2018 10:07am
Is this one the website?
https://www.mammothbikes.com/
FL bomber   100 W
Post by FL bomber » Jul 17 2018 12:51pm
Mammothebike.com I emailed them last night they got back to me today with price of $900 plus shipping
bigbore   1 kW
Post by bigbore » Jul 17 2018 2:43pm
Great find! If I remember well from Stealth it costs $1200 ??
1abv   1 kW
Post by 1abv » Jul 21 2018 12:30am
Hey all,
Was thinking about using a plug with a countdown timer on it for charging the bike ..Have any of you done this? figure i set it for 3 hours so it automatically turns off and I don't forget it..
Thanks fellas
Rix   100 GW
Post by Rix » Jul 21 2018 5:26pm
1abv wrote:
Jul 21 2018 12:30am
Hey all,
Thanks fellas
Definitely a good idea if you dont' want to worry about remembering to unplug the power to charger.
bigbore   1 kW
Post by bigbore » Jul 22 2018 3:26am
I’ve been doing it also.
1abv   1 kW
Post by 1abv » Jul 22 2018 1:46pm
Hey fellas with crazy batteries...
I want to upgrade my battery, get as much power as possible with good reliability and lifespan in the frame using stock charger, controller,and cav 3.. I'm in the US and wanted to know if you all know of any battery builders that could make me something that I can either get built in USA or shipped to the USA?
Thanks!
Rix   100 GW
Post by Rix » Jul 22 2018 5:22pm
1abv wrote:
Jul 22 2018 1:46pm
Thanks!
Allex, hey Allex, hook this guy up!
PRW   10 kW
Post by PRW » Jul 22 2018 6:39pm
1abv wrote:
Jul 21 2018 12:30am
Hey all,
Thanks fellas
I do this for all my bikes.... means I can sleep at night!
1abv   1 kW
Post by 1abv » Jul 23 2018 10:17pm
How long do u set it for?
djjoonie   1 W
1 W
Post by djjoonie » Jul 28 2018 12:25pm
Hello all stealth owners!
does anyone have the same problem as my fighter?
My 2 speed internal gearbox outer rim is too close or touching the swingarm nut :oops: :oops:
Rix   100 GW
Post by Rix » Jul 28 2018 2:28pm
djjoonie wrote:
Jul 28 2018 12:25pm
That cover is there to protect the gears from dirt and crap getting in there. From the looks of your pics, you need to get a new cover that covers those gears. Then it wont be near your swingarm pivot nut
djjoonie   1 W
1 W
Post by djjoonie » Jul 28 2018 2:54pm
Thank you so much for your input, i think the cover is torn apart because of the pivot is too close to the 2 speed gearbox.
do you know if the cover spins together with the gear or in fixed position? im asking because my cover doesnt move at all like its stuck on the bottom bracket. so even if i replace the gear cover, it will have the same prob. i might have to grind off the bottom of the nut to have more clearance b4 installing new cover..
Has anyone took out the 2 speed gearbox and just put a single speed? i will lose high speed pedaling but 1 less prob for the future.
Thanks!!
