1abv   10 kW
Re: E-S Stealth Electric Bike Owners
Post by 1abv » Jun 05 2020 6:11pm
wee hew...
Theodore Voltaire   10 MW
Post by Theodore Voltaire » Jun 06 2020 9:57am
That's a cool one 1abv
1abv   10 kW
Post by 1abv » Jun 06 2020 11:40pm
Thx fella...
KarlJ   100 W
Post by KarlJ » Jun 07 2020 6:52am
[/quote] From Theo!
My 24 ah pack is about the same as the 35, but the stock 18 ah used to get pretty warm. More than either on my 18650 packs. That makes sense to me, it's the smallest capacity pack, so it works the hardest.
[/quote]
TV Apologies I'm a couple of months late here..... I've now done 5800kms as of today on my MJ1 3500MAH pack.
Mine is 22S not 20S = bike is 10% faster -spewing you didnt follow my lead :(
my average distance between charges has increased as lost my job (COVID), got another (4hrs later ) that comes with a car hence riding is not so much of a commute but for mental/physical health.
As for pack Temps 135deg F is only 57degC. I can tell you you can easily get to that, go do 20-25Miles Flat out in a 50mph zone!
As for rating at 100A for 10P..... Sorry Whilst this is the theoretical max discharge rate the cells get about a 30degC (86F) rise after said 25Mile thrashing - whilst my bike runs 65-75A or so according to the CA......thats enough as the cell heating is wasting the stored energy as heat vs useful work.
I did a 103km ride today, 45kms each way to the bottom of a F'n big hill as "training support" for a friend on a non ebike. so 13kms of said hill made up of 6.5kms round trip up down.
I had the opportunity to steal 30mins charge with my 11A charger, giving me an additional 5.5Ah whilst i had a coffee (and a sneaky beer)
When i got home avg speed is 40km/hr 30WH/km and 40AH which is about right as a little bit left and I'm only charging to 90V.
Hence 5800kms and 0% measurable loss from the pack.
VERY VERY HAPPY - so happy i again considered upgrading it to 22S12P today. Answer from the missus "CUT YOUR DRINKING FROM 8beers to 6 beers a day" this would save me about 1 cell per day and in a couple of months i will have the cash BUT i will be much fitter and not needing the extra kWh anyway.
As it turns out, as the way the pack is constructed its not as simple an exercise as adding another couple of cells down one side and i'm in the - Build the next pack as 22S 12P from the start.
KarlJ   100 W
Post by KarlJ » Jun 07 2020 7:32am
Is the bloke that posted a couple of months back for a charger in ADELAIDE get sorted?
poor mans charger https://www.ebay.com.au/itm/BST-900W-Bo ... SwUg5e13Qy
plug in an old laptop power supply ~18V 100W
gets about 80W out the other side with some tweaking
whilst thats only 1A into the pack, the original pack likely an overnight scenario and OK.
for $35 its an OK solution - cant feed it with 2 laptop chargers (im not sure why) as doesnt work so great.
can buy two and run the Higher voltage side in parallel or use a PC power supply at 12V and ~350W (make sure its not getting smoking hot of course)
KarlJ   100 W
Post by KarlJ » Jun 07 2020 7:39am
Rix wrote:
May 27 2020 9:44am
Pete de Vries wrote:
May 27 2020 5:47am
Rix wrote:
May 26 2020 11:16am
May 23 2020 6:09pm
Wow Rix thats a heavily modified P7 !! My bike is serial number 41. I remember when i ordered it that they said mine came with the latest upgraded battery pack. I just looked at the motor. Cant see a brand name on it but it does have a part number (M20171-0036) . Hope that helps mate. Im afraid im a real novice on the ebike scene, so would really appreciate advice on what motor etc to buy to get me up these hills ! I specialise in machining, tig welding and fabrication but ive always stayed out of the electronics game. Cheers mate.
I have to P7, the first P7 has a serial number of 000, and the P7 I have in the picture is 096. Anyway, lets see what you go, can you take a picture of your hubmotor on your bike and post it, I can tell by looking at it if you have a MAC or Bafang.
Hey Rix thanks for the assistance. Hopefully my pics attach ok. My first go on here. I am thinking its a MAC motor going by quick internet search. Do you know the specs of the factory motor vs a 12 turn MAC motor ? I am hoping all going well that i can buy a 12 turn MAC and lace it into the spare 27.5" rim i have and it will work with the factory controller etc ? Would you also know the plug on the motor side that i will need to purchase so that it will plug into the Stealth plug on the swingarm. Oh and i guess do i purchase a motor direct from MAC in china ? I am in Australia but so far i haven't found an Australian seller of these. Apologies for the basic questions . Ive always been into motorbikes and quadbikes. This ebike thing is all very new to me ( and great fun to ride)
You have the Mac motor. The Stealth Spec'd Mac motor is a 9T wind. I don't know if you can buy a 12T set up to directly plug into the stock controller, you may have to set that up your self. That said, you wont notice much of an increase in acceleration if you use Stealth's stock controller, they have it programmed to not start off quick, but to add power gradually, thats why your bike is faster at accelerating above 5-10 km/H than it is from dead stop. Getting a 12T in a 27.5 rim is no problem though.
You can buy a complete MAC motor from Paul at www.em3-ev.com simply undo the side plate, pull the motor assy out the side and drop the 12T into the wheel you have, sorted -they say they are matched etc etc but i've swapped a few being too lazy to repair all the wiring after a stack and much cheaper than freighting a whole wheel assy.
get a 12 FET controller to push 40A to it and you have a ripper bike. If thats not enough, unfortunately there are some $$ to spend. My bomber got a birthday UFO5565 from stealth at $1400 or so for use with my bike as I'm getting the original motor relaced into a 19" moto rim so i can use some motorcycle rubber.
I'm sure there are shit loads of options with MIXUS, QS motors etc. Ultimately if you want to go FAST and have heaps of off the line stonk there is no getting past it, its a bloody expensive exercise which is why CD got ~$10K for his fighter - he'd probably bought the bike twice by the time he sold it.
I met a guy who pulled a set of FOX forks off his brand new downhill bike to use the next model FOX up at about $2.5K!
sure sure i get it but.... the bike was sparkling dont think he'd ever actually ridden it!
1abv   10 kW
Post by 1abv » Jun 07 2020 11:27am
Just did a fresh rebuild on my Marzochhi 888 with the Avalanche Downhill Racing internals in them... Good god are these forks good.. Better than any other MTB/Downhill forks I've ridden so far. Avalanche custom set them up to my specs and riding style..
Square edge??? whats that?? no chatter, no harshness, ability to hit jumps no prob...and the front is very predictable... I can put it where ever I want.....Super comfy very plush.... The rissie racing clamps def help as well to get more weight over the front fo sho..
It crazy going from the stock DNM forks BLAH...... to the stock zocchis. ok better.....To the avalanche set up which are on another planet.. They ride better than my friggin modded Dol Soggio KTM WP forks!....WTF????
The Avalanche Kit is all custom milled metal parts and not cheap ass plastic "we are saving weight" bullshit sotck MTB fork internals..
OK so going toe to toe with my tuned CRF/Showa well maybe not but damn they are really good...If I can get the rear to get close to this I will be very happy....
In the rear I modded the DNM shock, trying a few different weight springs I used canon racecraft to make them for me... ( I have recently read that FOX springs will fit.. may have to confirm this..) and also revalved the shims to a 3 stage and adjusted the nitrogen level which made the shock much better than stock but still not nearly where I want it to be.
Im thinking im going to get Avalanche to build me a shock for the rear and get rid of that DNM....
Im rambling....
1abv   10 kW
Post by 1abv » Jun 08 2020 10:44am
My bombers unsuccessful attempt at tree climbing....
Ben Purdy   1 µW
Post by Ben Purdy » Jun 09 2020 1:21pm
Hi I’m in need of a charger for my b52 I’m in England and don’t want to have to order one from China as it is going to take a long time at the moment
1abv   10 kW
Post by 1abv » Jun 09 2020 10:06pm
Rims....
Post by Theodore Voltaire » Jun 10 2020 9:38am
Watch out for the trolls
1abv   10 kW
Post by 1abv » Jun 10 2020 5:12pm
I F!@#$#@ just cleaned this G#@!!@# D@Q# THING!! every time I go riding its get dirty all over again...WTF??? why can they make clean dirt???
Trolls must be throwing dirt at me while I ride past...
1abv   10 kW
Post by 1abv » Jun 12 2020 9:29pm
Damn! no really a Dam..
KarlJ   100 W
Post by KarlJ » Jun 13 2020 9:42am
Had these motorcycle tubes recommended, they fit in the crazy bobs well.
The super heavy duty tube I was running was a little small for the tyre and I copped a snake bite flat.
Anyhow with 80km rides common for me I have everything on board to swap for a normal tube for the trip home.
1abv   10 kW
Post by 1abv » Jun 13 2020 10:57am
Moto tubes are the way to go!!!
1abv   10 kW
Post by 1abv » Jun 13 2020 9:16pm
Soo I've lowered my rear pressure from 15 to 12 psi with the Bridgestone, the sidewalls on that tire are crazy stiff.Ideally Ide like to find another moto tire with a softer sidewall.. lowering the pressure did help a lot with the ride. and at some points I was going at full clip through fist sized rock gardens... That and backing out the compression.. im going to get my shock rebuilt soon anyway may play again with the shims and see whats what..Really looking for as much compliance on small and fist sized rocks don't really care about bottoming resistance and big hits.
Post by Theodore Voltaire » Jun 14 2020 4:35pm
Rix   100 GW
Post by Rix » Jun 14 2020 6:54pm
1abv wrote:
Jun 13 2020 9:16pm
Try to find a shim combo that gives you high speed compression and slow rebound options. On our bikes, we really don't need dual circuits for compression, infact, with hub motors, its more important to precisely control the speed of the rebound over everything else.
1abv   10 kW
Post by 1abv » Jun 14 2020 10:34pm
Rix wrote:
Jun 14 2020 6:54pm
1abv wrote:
Jun 13 2020 9:16pm
Makes sense.. the faster compression works better and trying to knock down the rebound would help with the "donkey kick"
1abv   10 kW
Post by 1abv » Jun 15 2020 1:07pm
run to the hills!!!
Rix   100 GW
Post by Rix » Jun 16 2020 9:56am
:bigthumb: :bigthumb:
1abv wrote:
Jun 15 2020 1:07pm
run to the hills!!!
1abv   10 kW
Post by 1abv » Jun 16 2020 11:56am
Gone Fishin!
Rix   100 GW
Post by Rix » Jun 16 2020 3:01pm
Thats awesome!
Post by Theodore Voltaire » Jun 16 2020 10:30pm
The germs were everywhere. Germs flying through the air. In our eyes. In our ears. Up out nose. We don't care. We didn't even have a mask. Four 10.0s later we're laughing at germs. Only a pussy is scared of germs.
Post by Theodore Voltaire » Jun 17 2020 9:01am
I got to remember not to do that.
