KarlJ   100 W
Re: E-S Stealth Electric Bike Owners
Post by KarlJ » Aug 01 2020 9:15am
KarlJ   100 W
Post by KarlJ » Aug 01 2020 9:28am
Out today, cracking weather here in Melbourne.
Looks like stage 4 corona restrictions so not more than 5kms from home will kick in this week. Hence gave it a good workout today 85km ride
Rix   100 GW
Post by Rix » Aug 01 2020 11:30am
KarlJ wrote:
Jul 31 2020 3:47am
selvator wrote:
Jul 27 2020 8:43pm
So can I upgrade the battery and that's it? Do I need a new controller? I don't know where to start.
To summarize, I want more low end power, would be ok sacrificing top end speed, want to go farther on a charge and want it to not shit the bed. Fast, Cheap, Reliable... I know I only get two so I'll choose fast and reliable if given the choice.
Thank you!
Start with the battery - its an expensive and time consuming exercise, build photos of some excellent options are here on this thread. Personally I think 22S13P will fit (6 cells may need to sit ontop) but many controllers are tapped out at 90V and you should limit the charge to this anyway IMHO as you can potentially increase the pack life alot.
If building your own (recommended) you can spot weld or use solar panel tinned copper bus tape which is ~2.5x more conductive than nickel which is more commonly used and you can use a big iron an simply solder them. (people say you shouldnt but my pack came out > than its nominal capacity anyway and ~60+deg battery temps after ride/charge/ride cycle are flogging the ^%&$ out of them anyway.
Take the max continuous ratings with a grain of salt as >70% of that rating and they get HOT FAST = cant be good so aim for this if you want to pull big grunt you need 15-20A rated continuous cells and 12P giving you a realistic 100-120A continuous discharge rate . I run mine at max 80A which is more like 65-70A at full throttle after it settles. At this I get ~30decC temp rise over the course of a discharge. If I charge at 0.5C I get a 8-9 deg temp rise from 10% to 90%.
Charge the day before you ride, allow the battery to rest 60mins at end of ride before charging it again. and dont think for a second that charge/ride/charge/ride will not cause damaging cell temps in the 60-80deg range. (at least on my pack)
TRY and not flatten the bike to BMS cutout on every ride and leave say 5kms range left when you get home. I get 60kms quite reliably when going hard and i get right out of the power when I get down to 70V (unloaded) and creep home if thats the case.
@Selvator, this is excellent advice. Karl went into alot more detail than I did.
Rix   100 GW
Post by Rix » Aug 01 2020 11:45am
Nice ride with Pops up in Tahoe on the Nevada side.
1abv   10 kW
Post by 1abv » Aug 02 2020 8:04pm
Sure looks Purdy up there
Rix   100 GW
Post by Rix » Aug 03 2020 11:03am
1abv wrote:
Aug 02 2020 8:04pm
It is beautiful, can't let you be the only one posting pics from rides.
1abv   10 kW
Post by 1abv » Aug 03 2020 11:44am
Rix,
Are you running the 5565 UFO motor? Im still on the OG motor on my bike. I know you have run a ton of motors and wanted to see what you think. I've read that its slower but has more torque (perfect for me), is a bit louder and has a new hall-sensor harness which means I would need to either run an adapter or rewire the controller with to the new plug since im running the CAV3.
I wanted specifically to know a couple of things..
-how does it deal with heat compared to the OG motor? I do a crap load of really long hill climbs that eventually get my motor pretty hot. even with statoraide and hubsinks.
-Can you feel a difference in suspension / handling? (reading that its quite a bit lighter)
-Where did you get yours from? Directly from stealth?
Thanks in advance! and keep the pics coming!!
Rix   100 GW
Post by Rix » Aug 03 2020 2:52pm
1abv wrote:
Aug 03 2020 11:44am
Rix,
I have tried the 5580 but no the 5565, the 5580 has noticeably more thrust over the older 5403 motor, so yah the 5565 may have more yet at the price of less top speed. Here is a pic of of my buddies Bomber with the new 5580 on it.
1abv   10 kW
Post by 1abv » Aug 04 2020 2:30am
how does it affect the suspension? do you notice a difference between the UFO and the OG?
Rix   100 GW
Post by Rix » Aug 04 2020 9:29am
1abv wrote:
Aug 04 2020 2:30am
No, not really, yah its 6-7 pounds less of suspended mass, but because the weight is so low, I can't tell. And because of where the weight is, to get these bikes to handle good, the rebound needs to be slowed down alot more than if it I was setting up a regular bike, or dirtbike for that matter. The 55xx accelerates better than the 54xx given same amps volts input is the noticeable difference.
Longshot   100 W
Post by Longshot » Aug 04 2020 10:49am
Is there a source in China where I can buy crystalyte motors like QS?
Rix   100 GW
Post by Rix » Aug 04 2020 5:42pm
Longshot wrote:
Aug 04 2020 10:49am
http://www.crystalyte.com/
I used to deal with Kenny back when I was importing motors to the US, because I worked with Electric Rider in Texas, I could get away with ordering as little as 5 units at a time. I have been told if one deals with Crystalyte directly, the minimum order is 50 units, however, I haven't confirmed if thats the case.
1abv   10 kW
Post by 1abv » Aug 06 2020 1:24pm
Rix,
Do you know where to get a UFO motor if I only wanted the one? I checked with stealth, they have them as I recall they were asking 6675 plus shipping from Australia... Love to see if there is anything closer to cut down on shipping and cost.
thanks!
Theodore Voltaire   10 MW
Post by Theodore Voltaire » Aug 06 2020 8:32pm
1abv wrote:
Aug 06 2020 1:24pm
Rix,
thanks!
Six thousand dollars for a electric motor? It better have gold windings
1abv   10 kW
Post by 1abv » Aug 06 2020 11:49pm
Theodore Voltaire wrote:
Aug 06 2020 8:32pm
1abv wrote:
Aug 06 2020 1:24pm
Rix,
thanks!
Ok so typing..... yeahhh...
back to reality... Stealth price is 630 plus 118 shipping...
Rix   100 GW
Post by Rix » Aug 07 2020 11:37am
1abv wrote:
Aug 06 2020 1:24pm
Rix,
thanks!
Not anymore, Mike from Electric Rider shut down business a few years back, and now Electroride has picked up their line. I had a bad experience with Electroride many years ago, I ended up driving from Fallon to Palo Alto to recover the motors and rims I had shipped there. I had talked to the owner by phone, he was in crisis, but tried to do right by me after I had already retrieved my motors. This was back in 2012, maybe Electroride is under new management/ownership now. They don't have the HS55xx or UFO55xx in their inventory, but because of the volume they do, they could get motor in on one of their sea freight shipments, but they probably only order 2-3 times a year and in volumes of 100-200 units per order. Anyway, if you contact Electroride and come up with an arrangement, its at your own risk, I think you would be okay now as it looks like they have grown and expanded, but its not my money were talking about here. .
Longshot   100 W
Post by Longshot » Aug 07 2020 11:46am
Kenny says there's no 55100s available. I'm not sure if I want an H5580. I want my back wheel to be 12 pounds lighter, though. Rix, will I be happy with the power? How many phase amps are you giving it?
Rix   100 GW
Post by Rix » Aug 07 2020 3:26pm
Longshot wrote:
Aug 07 2020 11:46am
Yah, the 5580 will be better than the 5403, maybe a few MPH slower, but a bit more accleration/thrust. I ran my Bomber with the stock controller, it was good for about 70 amps DC, so maybe 175-180 phase. I'm not sure what the programmed ratio is from the factory. 2.5:1 is your typical Phase to DC amps ratio.
