Show off your Ebike creation here.
Rix   100 GW
Re: E-S Stealth Electric Bike Owners
Post by Rix » Sep 13 2022 9:36am
1abv wrote:
Sep 13 2022 9:04am
Looking good man! Hey did you trim the phase wires or did they come that length?
Got to be trimmed and cut to the perfect length by TV.
Theodore Voltaire   10 GW
Post by Theodore Voltaire » Sep 13 2022 10:56am
1abv wrote:
Sep 13 2022 9:04am
The motor cable was almost 4 feet long, so it needed to be trimmed. I cut the phase wires down to stock length, but I made the hall cable longer than stock to get it up to a place that's easy to deal with. I think I'm going to run the hall cable from the controller through the frame so I can stick any extra cable length back into the frame and out of sight.
When I started working in air conditioning my mentor told me you can cut it shorter, but you can't cut it longer. :o
Dunlop   100 mW
Post by Dunlop » Sep 13 2022 5:07pm
Hi TV,
What exactly are those connectors you used for the phase wires..... I need some like that!!!
Thanks,
Keith
Post by Theodore Voltaire » Sep 13 2022 6:16pm
Dunlop wrote:
Sep 13 2022 5:07pm
Hi TV,
Thanks,
Keith
They're called XT150, supposedly good for 150 amps.
https://www.ebay.com/itm/125424931903
Post by Theodore Voltaire » Sep 13 2022 6:31pm
It only took me 3 trys, and about 3 youtube video refreashers to get this far. Almost no cussing. Make mental note, next time do all the inside spokes on both sides first, then the outside spokes last. I did remember not to cross the schrader valve hole like I did last time. Looks like I guessed pretty good on the spoke length. That chickens life was not in vein. Next I need to tighten all the spokes,and true the rim.
Post by Theodore Voltaire » Sep 13 2022 10:47pm
I've never had success using this spoke torque wrench before, but after getting frustrated using that little round spoke wrench I decided to give it another try, and it seems to be helping a lot this time. I got my truing stand set up in the living room so I can watch TV while I work on my wheel, which helps a lot, because it's still pretty warm in the garage. I guess I'm going to have to call it a night though, because Donkey wants to go to bed.
1abv   1 MW
Post by 1abv » Sep 13 2022 10:50pm
Theodore Voltaire wrote:
Sep 13 2022 6:16pm
Dunlop wrote:
Sep 13 2022 5:07pm
Hi TV,
Thanks,
Keith
They are the business. I use them as well.
Rix   100 GW
Post by Rix » Sep 14 2022 2:30pm
Sep 13 2022 6:31pm
So when I laced up this wheel for my Alpha build, I started off with a 2x, and then went spoke every 4 holes around the wheel. I found this to be the easiest way to lace a rim as the distance and centering of the rim was set from the get go and I didn't run into a situation where I couldn't either get a spoke to reach the nipple, or its was too long to center into the spoke hole due to the offset of the rim. I see your way worked as well. :bigthumb:
1abv   1 MW
Post by 1abv » Sep 14 2022 5:43pm
I’m sure y’all know this already but make sure to check the spokes after the first few rides.. they will stretch a bit.
A kill of crows?
Post by Theodore Voltaire » Sep 15 2022 2:55pm
After getting the rim pretty close on the truing stand, I like to fine tune it on the bike. I guess it's about as close as it's going to get now. I'm waiting on a new rim strip, and then I'll mount a tire, and call it good. Then I guess it's time to remove the controller.
Post by Theodore Voltaire » Sep 16 2022 5:20pm
I'm considering this shunt.
And then we adjust the ca for, 50mV/150A = 0.33 mOhm
And then wala, the Kelly should work with a ca.
ebuilder   10 kW
Post by ebuilder » Sep 16 2022 6:50pm
Note to self:
Buy nice hub motor
Buy nice rim
Study spoke gage and select proper spoke length and buy spokes.
Call local bike shop and ask who their go to guy is for building wheels.
Drop parts off at bike wheel builder guy's crib.
Wait for phone call that the wheel is done.
Meanwhile, live longer, be happier, pet the family dog and take the wife out to dinner.
:D
P.S. congrats on the build. Looks nice.
Dunlop   100 mW
Post by Dunlop » Sep 17 2022 8:01pm
by 1abv » Sep 13 2022 8:50pm
Theodore Voltaire wrote: ↑
Sep 13 2022 4:16pm
Dunlop wrote: ↑
Sep 13 2022 3:07pm
Hi TV,
Thanks,
Keith
Thank you both for the reply.... Since I am using a smaller Leafmotor (1500w) I assume they will take the occasional 250W, 20 second burst??
Thanks,
Keith
Cowardlyduck   1.21 GW
1.21 GW
Post by Cowardlyduck » Sep 17 2022 10:40pm
Dunlop wrote:
Sep 17 2022 8:01pm
Myself and others pushed our Leaf motors up to 8Kw peak in the past. They can take it, just deal with the heat somehow and your fine. :D
I recommend upgrading phase wires, adding Ferro fluid and hubsinks at a minimum.
Cheers
1abv   1 MW
Post by 1abv » Sep 18 2022 10:50pm
Baby powder….. it’s not just for babies anymore.babies….
Post by Theodore Voltaire » Sep 18 2022 10:59pm
Looks flabby
Post by Theodore Voltaire » Sep 19 2022 6:24pm
My shunt came today. I think the only part that I'm waiting for now is the circuit breaker.
1abv   1 MW
Post by 1abv » Sep 20 2022 12:36pm
Sooo I’ve been playing w the controller from time to time between riding. Kelly is stingy w the leads off their controller. I would up removing the bolt down contacts they had for xt150s. If you want the phase wires to be in the stock location ya gottta make a jumper because the kelly phase wires are not long enough. I’m also using 8 gauge wires from my motor to the controller. Gotta get that shunt soon. I was playing w where to mount the circuit breaker and there is not a lot of space in front of the battery. W a shunt and breaker it will work but it starts to get a little crowded.
Post by Theodore Voltaire » Sep 21 2022 10:27am
I've been thinking about how to extend the phase wires 1abv. I'm leaning toward just soldering extra wire on, but having an extra xt150 doesn't seem too bad.
Now that I have one, I go back and forth on the shunt. It kind of seems like it's not worth the trouble of stuffing it in there, for little benefit. The Kelly already allows you to set all the power perimeters, so we don't need the ca to be able to do that. I feel like I can get by with just a voltmeter, and speedometer/odo. I wasn't planning to have a throttle overide either.
1abv   1 MW
Post by 1abv » Sep 22 2022 12:01pm
Tv you mentioned that your hall sensor wires were all ready set up for a kelly. Can you take a cu pic of the wires going in to your connector? Love to see the colors and location of where the wires go into the plug
Post by Theodore Voltaire » Sep 22 2022 8:51pm
The picture didn't come out too good.
This is a diagram of the kelly hall plug. For some reason Kelly calls orange, raddle
Kelly plug left to right
Black ground, Orange temp wire, purple + 5v
Yellow, Green, Blue
the wires on the motor side are a little different
Black ground, Clear temp wire, Red + 5v
Blue, Green, Yellow
Kelly controller plugs.JPG (60.36 KiB) Viewed 87 times
Post by Theodore Voltaire » Sep 22 2022 9:01pm
This is interesting. My stock 9 year old controller. 50 amp?
Dunlop   100 mW
Post by Dunlop » Sep 23 2022 4:14pm
by Cowardlyduck » Sep 17 2022 8:40pm
Dunlop wrote: ↑
Sep 17 2022 6:01pm
Hi Cowardlyduck, I am planning on Ferro fluid and hub sinks for sure :thumb: .... Not sure if you've looked at the Leafmotor specs lately....
https://www.leafbike.com/products/e-bik ... tsId=10683
This part: -- Update “3mm phase wires” & "Newest version hub" makes me feel as though they have already increased the size of the phase wires??? But then again, I am New, so maybe they have been advertising it that way for years??? I think they may already have the axle stuffed full!!!! I was just planning to run the next size larger wires coming down to the axle??
I am planning to split open the motor (which just arrived today) to add the fluid and possibly change out the thermister... The big decision I think is to get a thermister that works for the KLS7230S controller, or for the CA V3!!!! I just don't know which one I really want to be running the show!! They both seem to have about the settings and functions :confused:
Keith
1.21 GW
Post by Cowardlyduck » Sep 23 2022 5:53pm
Dunlop wrote:
Sep 23 2022 4:14pm
Keith
I'm pretty sure they were saying the same thing back in 2016 when I got mine. 3mm2 is around 13awg. Good for around 4-5KW peaks IMO.
I upgraded mine to 10Awg fine stranded silicone. To get it to fit I changed the halls and temp sensor wires to super thin 36awg teflon wires, drilled the axle hole slightly bigger, and replaced the thick silicone insulation on the 10AWG with heatshrink. To get it through the hole requires heatshrink around all of it, a bunch of lube and patience. I also increased the phase wires to 8awg just outside the axle which helps pull excess heat away.
I should also add, in my case I was running 12 internal cooling fans with vents on the side covers, custom heat sinks and FF so not quite the same as FF + hub sinks sealed.
Anyway, all that is a lot of work and not really worth it unless your chasing every last drop of performance. Easiest, most reasonable option is as you say, FF + hubsinks + upgraded phase wires from just outside the axle.
Cheers
amberwolf   100 GW
Post by amberwolf » Sep 23 2022 10:25pm
1abv wrote:
Sep 14 2022 5:43pm
<snip>
Those are the stickiest tires I've ever seen, holding a bike onto an upside-down hill like that. ;)
If you found this advice helpful, supporting contributions are accepted here.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental)
