John in CR's ebikes
John in CR   100 GW
John in CR's ebikes
Post by John in CR » Apr 12 2011 11:22am
My first bike was a tricycle.
John in CR   100 GW
Re: John in CR's ebikes
Post by John in CR » Apr 12 2011 11:23am
My second bike had 2 wheels
John in CR   100 GW
This sucks
John in CR   100 GW
Damn,
I was almost finished with the next one.
John in CR   100 GW
Post by John in CR » Apr 12 2011 11:24am
Reserved for build with monster scooter hub
John in CR   100 GW
Post by John in CR » Apr 12 2011 11:25am
reserved for coast to coaster
John in CR   100 GW
Reserved for monocoque build
dogman dan   100 GW
Post by dogman dan » Apr 12 2011 3:09pm
Now you have crossed into a real quality build with that cannondale.
vanilla ice   100 MW
Post by vanilla ice » Apr 12 2011 4:28pm
So the little guy gets the freeride? Luckeeee! :)
GCinDC   10 GW
Post by GCinDC » Apr 12 2011 8:28pm
Fantastic, John! I love them.
Great to have you on the podcast too! Troy just put it up here.
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
John in CR   100 GW
Post by John in CR » Apr 13 2011 1:09am
Ebike jousting sounds like a cool sport to play against trevor.
dingoEsride   100 kW
Post by dingoEsride » Apr 13 2011 5:43am
Very nice interesting looking builds John especially the canondale, I'm not quite sure about the small wheels but seems to be popular on here
ride like the wind
dogman dan   100 GW
Post by dogman dan » Apr 13 2011 6:14am
I think I understand what you mean John about the frame geometry. Perhaps the seat is in the wrong place for the frame now that it's longer. Further back for the seat makes sense to me too. Perhaps some kind of custom steatpost adapter could be welded, that would exit the existing seatpost from the bottom? A tricky problem to mount a new seatpost tube with alloy frame. Too much leverage, and Crack.
Maybe some kind of mod to a steel seatpost so that the nose of the saddle would just about rest on the top of the seatpost tube. Then an additional strut could be run to the back of the seat, diagonal to the bottom of the seatpost tube?
John in CR   100 GW
Post by John in CR » Apr 13 2011 9:23am
What a frocking waste of my time.
John in CR   100 GW
Post by John in CR » Apr 13 2011 9:33am
hello
John in CR   100 GW
Post by John in CR » Apr 13 2011 9:45am
Dogman,
On the seat extension I don't know yet where I'll end up, maybe a 2 part sleeve that goes over the existing seat tube and support tube with it somehow anchoring in the seat tube for it to take over half the weight. The easy route is to just hack the seat tube off and make an extension. Another route could be to make it a Super Double V and add 2 more seat supports that anchor at the bottom of the existing supports to support the seat extension. Decisions decisions, I just gotta avoid analysis paralysis that often afflicts me.
dogman dan   100 GW
Post by dogman dan » Apr 13 2011 7:16pm
I'd be trying experiments that don't cut the frame first. Wierd custom seatpost type stuff.
grindz145   100 MW
Post by grindz145 » Apr 13 2011 10:56pm
That cannondale is freakin wild! Thanks again for doing the podcast. Too much fun.
John in CR   100 GW
Post by John in CR » Apr 14 2011 3:41am
A couple naked shots of the SuperV to give you guys a better idea of what I'm working without the zip tied controller and test run battery placement clouding the issue.
Super V left front quarter.JPG (32.45 KiB) Viewed 3591 times
Super V first side shot.JPG (28.19 KiB) Viewed 3587 times
Green Machine   100 kW
Post by Green Machine » Apr 14 2011 5:25am
I love the duct tape work on the clown bike...i was contemplating a bmx build with entire bike (as much as possible) wrapped in black duct tape. the clown bikes my favorite.
the super v is obviously beautiful...i would like to follow that build thread if there is one on it. i rode a bike recently with a hub motor like that as the mid drive...rode really nice...heck of a hill climber.
Spacey   100 kW
Post by Spacey » Apr 14 2011 5:42am
I wish I had the time and workshop to build lots of experimental bikes, cheers for posting the pictures.... they look like a lot of hard work paid off.
http://www.custom-ebikes.com is my new Ebike company serving the Uk and Europe
Free Uk shipping over £49.99
Hillhater   100 GW
Post by Hillhater » Apr 14 2011 5:48am
John,
what is the advantage of mounting the hubbie in the swing arm rather than in the wheel.?
..gearing maybe ? .. but you seem to be close to 1:1 ratio ?
John in CR   100 GW
Post by John in CR » Apr 14 2011 9:41am
Hillhater wrote:John,
There are actually quite a few reasons:
The 28t at the motor 48t at the wheel reduction makes the 9C effectively running a 12" wheel so it will be able to climb anything. The lower gearing will also allow me to run the motor at 7-10kw buy going to high voltage, something not really possible without the gearing reduction. You can't just go to a higher turn count motor, because it can't handle the current. The only way is through higher rpms, just like the RC guys. It's a way for me to get the same power as my big hubs for about half the weight. The higher rpms (over 1krpm) will make the ventilation strategy even more effective, so the pretty extreme power will be relatively stress free for the motor, since 70A into a well ventilated 9x7 isn't a big deal.
Once I dial in the gearing I can have hill climbing, 40mph+, and regen braking in a light, low cost, and dependable build that doesn't sound like a cross between a drill and a vacuum cleaner.
14lbs mounted nearer the pivot point vs 24lbs in the wheel is a huge difference in terms of the suspension.
I wanted to find out first hand the noise level of a chain drive with large sprockets, and it's a non-issue. Now I have the potential for the benefits of a non-hub (changeable gearing, easy to change tire, multi-speed, etc.) without giving up any hubmotor advantages other than space savings and ease of installation.
A hub motor at high power enables a build that owns the Hanebrink as a real all terrain bike.
spinningmagnets   100 GW
Post by spinningmagnets » Apr 14 2011 10:01am
Sounds good John. I'd like to do something similar. So you have the 28T:48T chain reduction, a 9X7 hub, plus:
...What volts, what top speed, and what diameter of tire? (20" plus fat tire = 24" size?)
John in CR   100 GW
Post by John in CR » Apr 14 2011 11:27am
spinningmagnets wrote:Sounds good John. I'd like to do something similar. So you have the 28T:48T chain reduction, a 9X7 hub, plus:
The 28/48 reduction is too much with my 21.25 OD wheel. I have a 44t to swap in for the rear, which I hope clears up the off center sprocket problem, and may get to the gearing I want. I hesitate to quote speed and stuff yet, because I'm not happy yet even if sprockets were perfect. I have the pack at 30s, so only room 5s more, and the top speed is way too low. Sure I was getting close to 30mph, and don't want much faster for actual riding on this bike, but typical cruise near max speed won't cut it for me. Taking forever to get the last 5mph typical of ebikes ridden at WOT isn't acceptable to me. I want headroom, just like with every vehicle I've ever owned and almost never cruised at WOT. Boats are the only exception, but that's because water has so much more resistance.
I can't really dial in gearing and power until I move the saddle. I have to get comfortable with the ride before pushing the voltage and current higher.
FWIW, using the Ebikes.ca simulator I came up with 1000-1100 motor rpm under load at the target voltage, which will put max speed in the 40-45mph range with the 28t/44t gearing I'm going to. That should be just about right for a 35mph cruise. Higher power plus lower gearing than I run on my big DD hubs should equate to much better hill climbing. I do 35mph up an 8% grade with my heavier DD bike, so I think being able to maintain 20mph+ up a 15% grade is a reasonable expectation while keeping the drive system out of the danger range, especially with both motor and controller well ventilated.
