Oatnet's Current Prototype
oatnet   10 MW
Post by oatnet » Jan 24 2008 2:58am
I have gone through a few iterations of prototypes, thought I'd post my most recent one. Here it is almost done, with the frame padding etc still in place.
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet   10 MW
Re: Oatnet's Current Prototype
Post by oatnet » Jan 24 2008 3:07am
Image大鸡巴 Motors
oatnet   10 MW
Post by oatnet » Jan 24 2008 3:16am
This shows the Aluminum tray I mad to fit under the rack. It holds the controller (and acts as an extra heatsink), a switchbox with twin paths, circuit breakers, leads for 2 packs, and a 4x weatherproofed anderson plug that servers as a key and allows me to switch the packs between series and parallel. I use it to run two freshly-charged packs in series at 44.4 v until they drop to 40v, and can be run in parrallel at 80v without toasting another xylte controller.
Image大鸡巴 Motors
oatnet   10 MW
Post by oatnet » Jan 24 2008 3:20am
Here you can see my xyster-certified solution to keep the panniers from slapping against the wheel.
Image大鸡巴 Motors
oatnet   10 MW
Post by oatnet » Jan 24 2008 3:22am
Rear shot of the pannier barriers in action.
Image大鸡巴 Motors
oatnet   10 MW
Post by oatnet » Jan 24 2008 3:26am
Here are my 3 daily drivers - although
the ICE doesn't see much use any more :( .
Image大鸡巴 Motors
oatnet   10 MW
Post by oatnet » Jan 24 2008 3:33am
And finally the future...
While this setup is very agile, sometimes it was just too nose happy - with a 5305 just about any bump is an excuse for an unplanned wheelie. The picture below should give a clue as to the direction of my current 5305 prototype... I've run it at 36v but it isn't pretty yet, so no current pictures.
Image大鸡巴 Motors
Ypedal   100 GW
Post by Ypedal » Jan 24 2008 8:16am
Nice builds !! 8)
I have 2 of these red TF frames in my garage with the wrapping on them.. i want to build a set of twins and try to sell them as a set of his and hers bikes.. :wink:
what speeds do you get from the 5305's at 80v ?
ES site status page:
