Giant DH Comp Drop Out adapters and conversion
Metallover   10 kW
Re: Giant DH Comp Drop Out adapters and conversion
Post by Metallover » Oct 02 2014 1:51pm
I was Scott's first customer.
We did a lot of back and forth, and he got me my adapters just in the nick of time!
The adapters were exactly the same as I've seen picture of Kiwis.
This is what I got from Scott :)
There are pinch bolts too, just not in this picture. They are working great! :)
Thank you to Kiwi and Scott!
Add your bike to the Unofficial E-Bike Garage! - http://spreadsheets2.google.com/ccc?key ... OWcg&hl=en
My Build - Vector Frame, 20s 25Ah LiPo, Max-E, Cromotor - 10.89HP on the Dyno
MAGICPIE3FOCUSPOWER   10 kW
Post by MAGICPIE3FOCUSPOWER » Oct 02 2014 2:07pm
I am not good at English technical terms, but what is pinch bolt?
Thanks 8)
Ps thanks for the pictures, yeah they look exactly the same as Kiwi's ones.
8)
Nothing is perfect until I touch it...
Metallover   10 kW
Post by Metallover » Oct 02 2014 2:48pm
The pinch bolts pinch the axle into the dropout :)
(Not my picture, original Kiwi's I believe)
Post by MAGICPIE3FOCUSPOWER » Oct 03 2014 11:02am
Thanks for your clearing up.
8)
millzy555   100 W
Post by millzy555 » Mar 24 2016 2:11am
Can someone tell me if these are still being made?, Have my eye on a DH comp
Obiwan007   1 kW
Post by Obiwan007 » Mar 24 2016 11:10am
Yes these are available from ES member "Scott" got mine a few months back.
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 08 2016 11:58pm
Bump,
Anyone in the U.S. making these, and/or making some for other through axle frames ?
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
Scott   100 W
Post by Scott » Oct 09 2016 12:33am
Hi ScooterMan,
I am currently working on making some more. As we speak, I am making some slight adjustments to them so they will drop right into the frame without any filing needed!
Trek Liquid 10 9c 48v 10ah, top speed 28.5 mph. 55.2 mph down a steep hill. - sold
Giant DH Team build http://endless-sphere.com/forums/viewto ... =6&t=51106 top speed 70 mph
Scott   100 W
Post by Scott » Dec 31 2016 8:38pm
Hi all,
Below are some slight changes I have made to the adaptors. First, they don’t need to be filed down anymore to fit into the frame so they will just slide into the frame smoothly.
Here is a picture showing the diffrence, the top layer is how the new dropouts look and the middle part is the old version. This adjustment was made to both sides. The adaptors were 3D printed numerous times to insure a perfect fit!
The other change is to make a few of the brake side adaptors with a longer dropout. For motors that have the wires come out underneath the axle, the pinch bolt can’t be used. Here is a picture of a Cromotor for example:
This is what the extended dropout version will look like:
Brake side longer dropout v2.png (98.75 KiB) Viewed 1277 times
Below where the motor axle sits, the dropout is spaced out 3mm on each side so the motor will drop in easily and to make room for the wires.
With that said, if anyone has any comments, let me know.
For those interested in buying these adaptors please post below and state if you would like the extended dropout version for the brake side adaptor or not.
Obiwan007   1 kW
Post by Obiwan007 » Jan 01 2017 2:52am
Of course, I say yes for the new version with the extended drop-outs :wink:
madmaxNZ   10 mW
Post by madmaxNZ » Nov 26 2017 5:40pm
Hi,
Are you still selling the dropout adapters for the Giant DH?
If so, the non-extended version will do.
Please reply to max.banks@scorch.co.nz.
Kind Regards
Max
"The Rib Breaker": Giant DH Comp, Crystalyte H4080 & 50A controller, 24s LiPo 15AH.
cheeko   10 mW
Post by cheeko » Apr 19 2018 12:31am
Id be up to pay someone to draw up some for my Giant Ac, im sure i could get them machined
Cheers
GCinDC   10 GW
10 GW
Post by GCinDC » May 05 2018 11:29am
i have two 04 giant dh comp frames, one medium one large, with the kiwi adaptors attached, that i'm thinking of selling. pm me if interested...
g
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
mrk182gt   1 µW
Post by mrk182gt » Nov 09 2018 8:33am
SCOTT Genius DH Comp Drop Out adapters and conversion
Dears,
i saw your fantastics adapters to mount electric motor on full axle bike.
is it possible made an adapter for Scott Genius 930 ( 2014 ) ?
https://altitudebicycles.com/products/2 ... 3065654739
bike mount RWS 142 12mm through axle standards
https://r2-bike.com/SCOTT-Spare-Parts-D ... ius-Rahmen
i wait some kindly reply 8)
Best regards
Marco
