Giant DH Comp Drop Out adapters and conversion
binlagin   100 W
Re: Giant DH Comp Drop Out adapters and conversion
Post by binlagin » Jun 18 2012 9:31am
I will PayPal you the total tonight when I get home from work.
Thanks!
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
Kiwi   1 kW
Post by Kiwi » Jun 26 2012 7:57pm
Parts Update, shipping today
O. Simon Morse NZ-Original
1. Waynebergman
2. Crusoe
3. Kristoffer
4. GCin DC
5. binlagin
6.moonshine -paid -shipped
7.shorza -paid-shipped
8.Steevetooke -Paid -shipped
9.Duc998 -Paid - shipped
10.pchen92 -paid -shipped
11. Elektryczne Motocykle - paid- shipped
12. az-crusin - paid - shipped
13. Max Banks-NZ - paid-shipped
14. Alan-c -paid - shipped
15. crookedtree -
16. Airtime - Paid - shipped
17. Foolspeed - Paid - shipped
18. Philistine - Paid - shipped
19. Sacko - Paid - Shipped
20. Kiwi (me, one day I will have my bike running!)- not paid!
Fork lifts
1.binlagin - paid - shipped
2. stevetooke - paid - shipped
Kiwi   1 kW
Giant DH Comp Drop Out adapters 20th Set sold.
Post by Kiwi » Aug 23 2012 10:13pm
Just sold my 20th Adapter set!
Thanks to everyone who bought one, glad to see axles break before the adapter.
I will make another 20, hope there are still plenty of DH comps kicking about.
Kiwi.
gensem   100 kW
Post by gensem » Aug 24 2012 11:42pm
binlagin im hoping you really know what you doing
Justin we really appreciate what you did!
darkone040   10 W
Post by darkone040 » Nov 13 2012 5:32am
Ive started to attach the dropouts to the frame, they look excellent but i am in need of some advice..
the rear derailleur is giving me some grief trying to get it on, its got the adjusting screw with a tab on one side but then
the derailleur doesn't quite clear the part of the dropouts that hold in the long bolt to secure the axle on the other side
so i have to rest the tab on one side rotate it to where the derailleur clears on the other side and then somehow angle it right
to not cross thread the bolt, and then with my non existent 4th hand i have to screw in the bolt..
any tips on that would be much appreciated..
another thing the brakes were slightly out, not sure if its the magic pie or the dropouts but i had to put washers under the disc to
bring it out a mm so it would sit nicely between the brake pads, probably the magic pie at fault as the bolts i had for the disc brake were
a mm too long and needed washers anyway.. hmm
less weight means more fast
waynebergman   10 kW
Post by waynebergman » Nov 13 2012 11:24am
HI Darkone. Its been a while since I put my adapter set on but I do seem to remember its a lot easier to break the chain and feed the chain back through the derailer after the the derailer is fastened in place. Way less twisting and stress on the placement of your derailer before you start the fastening of it. Also you may need to file things down a bit here and there and add washers etc for chain stay spacing and all things in this busy area to work drag and rub free. One thing that worked for me was to place a few stainless hose clamps on my chain stay so the chain did not rub the aluminum chain stay when in 7th gear. The chain still rubs a bit of course but the stainless hose clamp is so low profile and strong that it protects the aluminum chain stay from getting damages. I run 3 stainless hose clamps right next to each other on the right stay to the chain kind of rides on it when in 7th gear. Hope this helps. A little patience at the time of install and a bit of filing here and there goes a long way. These adapters are awesome and so worth the money. Rock solid and they look good too! I have also used these adapters for fitting my trailer Bob Nuts on for pulling the single wheeled BOB trailer.
Screen Shot 2012-11-13 at 3.38.20 PM.jpg (107.13 KiB) Viewed 3804 times
darkone040   10 W
Post by darkone040 » Nov 14 2012 12:58am
cheers for the hints Wayne, i think my chain is one of them 1 use pin chains and i didn't have a new pin for it so i dismantled the rear derailleur
which helped a bit but i still ended up having to get the Dremel out and grinding down the offending part a bit, but its all together and going now yay..
i think a little hint for others out there that might be as dumb as me in putting a bike together..
attach the brake calipers last, from all the pulling the wheel in and out ive managed to bend the disc just a little bit..
but that probably goes for all installs so no fault from these dropouts
i think kiwi has done an amazing job with these and i hope he manages to sell enough for him to want to design more products for the masses here at ES
cheers adrian.
Kiwi   1 kW
Post by Kiwi » Nov 14 2012 4:52pm
cheers.
I have 10 more sets of adapters being assembled now.
Also have 9 sets of V2 fork lifts available now.
Kiwi   1 kW
Post by Kiwi » Nov 28 2012 6:57pm
9 Sets of DH Comp /Team adapters ready to go. $185usd Shipped
9 Sets of Fork Lift racks to mount battery packs to triple clamp forks. $160USD shipped.
shorza   1 kW
Post by shorza » Nov 29 2012 2:18am
Looks good Kiwi. What sort of weight can it hold?
tricky43   1 mW
Post by tricky43 » Nov 29 2012 6:52pm
Hi Kiwi
Please can I have a set of dropout adaptors for my 2003 dh team (135mm dropouts) and a forklift for a set of 2008 Fox 40s (they haven't arrived yet so I can't give you dimensions, should be here tomorrow or Saturday though) please pm me with total cost to Uk and your PayPal details. Many thanks..... Rick
Giant DH Pro 2003 Xlite 5306 Lyen 4115 Build thread http://endless-sphere.com/forums/viewto ... =6&t=45909
Kiwi   1 kW
Post by Kiwi » Nov 29 2012 7:05pm
Dont know how much it will hold, but have been using with 7.5kg battery. But really you dont want more than about 5kg for handling reasons. While I am sure it could support a 20kg child, that was not the intention of the belt.
rodgah   10 kW
Post by rodgah » Dec 13 2012 5:39pm
hey Kiwi,
nice idea.....dont know how I missed this thread, much better solution than glue/weld IMHO.
A bit of a hijack, if anyone has any of the older 135mm x 12mm axles and/or rear hub/wheels in Australia they are willing to part with PM me please, not in here dont want to mess up Kiwis thread.
Cheers
Common Sense isn't so common........
Specialized BigHit
Electrapunk
Stinky
tricky43   1 mW
Post by tricky43 » Dec 27 2012 3:47pm
My parts just arrived all present and correct in Stockport UK.
Got a few days left before I have to go back to work so the timing couldn't have been more perfect.
Now I can get in the garage and start putting the bike together, I got a bike workstand to begin the assembly, I doubt its going to able to take the weight of a completed ebike so its going to be like a giant game of Buckaroo adding parts until the workstand collapses :o
Anyway just wanted to post up and say THANKS KIWI YOU DA MAN!!
Scott   100 W
Post by Scott » Jan 11 2013 11:59pm
Would the Crystalyte 5403 hub motor which is 150mm fit in a 2003 giant dh comp’s 135mm drop outs if you stretch it? Or can it be stretched 15 mm?
Thanks
Trek Liquid 10 9c 48v 10ah, top speed 28.5 mph. 55.2 mph down a steep hill. - sold
Giant DH Team build http://endless-sphere.com/forums/viewto ... =6&t=51106 top speed 70 mph
Kiwi   1 kW
Post by Kiwi » Jan 13 2013 10:46pm
no, unless you ran a single speed and had the shoulder on the axle machined back 15mm.
Or find 150mm swingarm.
bose   100 W
Post by bose » Mar 07 2013 4:04am
I got My kiwi adapters on my 135ish swing arm but my cell man Mac did not fit very well. The rim was not centered in the swing arm. Now I need to know what spoke lengths you guys are running for your Mac geared hubs in the kiwi dropouts so that I can rebuild my wheel? Can it be so that my wheel was dished to the wrong side of the motor when I got it? Because it was way out of center..
Thanks!
GCinDC   10 GW
Post by GCinDC » Mar 07 2013 5:41am
bose wrote:Can it be so that my wheel was dished to the wrong side of the motor when I got it?
yes. it's been a cruel lesson for all of us with the 02-04 dh comps/teams. the 05 rear triangle seems to be centered, but the earlier ones are dished so that a centered wheel fits like this:
because my motor itself was dished the opposite way, i was able to take it apart and flip the stator, so the wheel lined up perfectly, but then it's untrue for some reason because the sidecovers are mounted differently..
brand new motor and wheel after just flipping the stator:
does the mac have a side that is more extruded than the other?
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
bose   100 W
Post by bose » Mar 07 2013 6:18am
Wish I knew that before I bought the bike :-)
Yeah, the side covers are different. But the wheel was dished from the beginning with one side spokes a little shorter than the other sides. I will try to spoke it up so the dish comes to my favor then have my lbs to true the wheel for me. I have so much money into electric bikes but have not yet ridden any...
Thanks,
bose
Obiwan007   1 kW
Post by Obiwan007 » Mar 07 2013 12:09pm
On the subject of DH comps, is your new bike an 05 GCinDC? Does anyone know how many years after the 05 until they started sloping the top tube and reducing the triangle space? My next project is going to be a DH comp for sure but I will have the luxury of waiting for just the right donor.
GCinDC   10 GW
Post by GCinDC » Mar 07 2013 12:21pm
no, mine's 03 i think. 05 has 150 mm between dropouts and centered triangle. prior years are 135mm and dished.
moonshine put an 05 rear triangle on his 04 dh team. fits fine. i think he also shaved some nobbies. lol
easy to check models w/ some searches.. bikepediasometimes good.
bose   100 W
Post by bose » Mar 07 2013 3:00pm
Managed to relace the Mac hub so the dish got right. The motor originally came with spokes that were 1-2mm shorter on one flange, swithed those over to the other flange and now it is possible to center the rim on the 135mm triangle.
Off to my LBS tomorrow to get it trued :D
Btw, Kiwi has made an excellent job with the dropouts and they arrived shortly after payment to the other side of the globe (Sweden).
Obiwan007   1 kW
Post by Obiwan007 » Mar 07 2013 7:15pm
Ok so after GCinDC pointed me in the right direction I worked out the skinny on the Giant DH comp history (probably been done before). So it looks like the 2002, 2003, and 2004 models of the DH comp and Team are the only models with the straight top tube that provides the maximum amount of triangle space. Bikepedia did not list the drop-out width but according to others it is 135mm. In 2005 the upgraded model of both the comp and the team had the new swept down top tube seriously limiting the triangle space. This model also does not have a drop-out width listed but, also according to others, it sported a 150mm drop-out rear end (with no off-set) that can reputedly be bolted right onto the older style frame. Here is the hitch they discontinued the DH comp and Team frames in 2006 so apparently the 2005s are the only ones that have the 150mm drop-outs but also have the ruined triangle feature. So a hybrid would be the only way to get where I and others want to go. Well, no time like the present to start looking. Anybody got a 2005 Giant DH comp or team rear end they would like to sell? I won't hold my breath.
Obiwan007   1 kW
Post by Obiwan007 » Mar 08 2013 3:03am
I may be all wet on my last post. I have just been looking at some bikes on pinkbike and have found several listed as 2005, 2006 and even a 2007 giant DH comps/teams with the straight top tube. None of them list their drop-out width though so now I am wondering if all of the 2005 or later are 150mm or maybe just some of them. Perhaps just the ones with the swept down top tube were the 150s. I'm confused now.
H.I.M   10 µW
10 µW
Post by H.I.M » Mar 30 2013 4:29pm
Kiwi wrote:Hi,
I have finished my "no cut" drop out adapters for the Giant DH comp.
They turned out great, everything fitted perfect, which for a first shot I was pretty happy about.
I drew it all up in solidworks, then had the profiles lazer cut and turned the bosses and tig welded them together.
With the 150mm drop outs, there is heaps of room, the 9 speed cluster goes in fine, had to space the disk 6mm.
Motor dropped in, have retainer pins in case the nut loosens during riding. New disk and dérailleur mounts worked sweet.
Took like 5 minutes to swap the original wheel out for the electric.
Will finish the bike up in the next couple of days and show you the results.
I made 3 sets and sold em all allready. Will make some more. Not cheap. About $250US delivered.
Hello I want to buy these dropouts. Is there any available? What is the price?
