GCinDC's Giant DH Comp
Show off your Ebike creation here.
GCinDC   10 GW
10 GW
Re: GCinDC's Giant DH Comp
Post by GCinDC » Oct 24 2013 8:56pm
55F in the garage overnight. and interesting, the pack was fully charged up to 83V but only to 93% capacity because of the cold!
it wasn't nearly as cold the morning before but i'd noticed that the full charge only put it to 98%. so good to know the adaptto is calculating true capacity, not just a voltage based level.
unless of course something's wrong! :mrgreen:
in case you're not following the raptor thread, moonshine came over yesterday to borrow tools and i got to test it at 3/10 throttle response (but it still needs more!)
and early yesterday on the inbound commute, there were more cops than you could shake a stick at!:
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
moonshine   1 kW
Post by moonshine » Oct 24 2013 11:32pm
i'm on it greg. i'm gonna try "balanced" mode and see what upping the motor current will do...just bought a cromo v3 and a 19"x1.85 prowheel
http://www.prowheelracing.com/big-bike- ... x-19-blue/ GOT IT FOR $35 on ebay!!!! WOOHOO!!!!
Current Build: Vector, MXUS 4T in 19" moto, Max-E, 20s8p Samsung 25R http://endless-sphere.com/forums/viewto ... =6&t=67752
Torque Raptor, Cromo V3 in 19" prowheel, Kelly KBL96251, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =9&t=56342
Giant DH Comp, X5404/Cromo V2 in 26" rim, Kelly KBL96251/Lyen 18fet, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =6&t=40031
dan974   1 kW
Post by dan974 » Oct 24 2013 11:59pm
...i first used torque but top speed is less as it stop pulling @ max amp and @top speed the amps dicreased...speed : your throttle position give the speed and the controller try to maintain balanced was the best for me : torque and speed signal with throttle, mak a lot of difference...try put 150A into it :D (you can adjut the zero/max range throttle too, usefull to have a bigger 0 zone and not having to fully twist your wrist :wink:
Trackman417   10 kW
Post by Trackman417 » Oct 25 2013 7:59am
moonshine wrote:i'm on it greg. i'm gonna try "balanced" mode and see what upping the motor current will do...just bought a cromo v3 and a 19"x1.85 prowheel
If that doesn't work, use Zombiess throttle tamer. That thing is like magic in a box and works exactly as advertised. Once you get it dialed in, you won't have anymore problems. I have a throttle tamer on my bike and I can't imagine riding my bike without it anymore. It takes some getting used to but it's so worth it.
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
GCinDC   10 GW
10 GW
Post by GCinDC » Oct 25 2013 10:57am
[youtube][/youtube]
moonshine wrote:just bought a cromo v3 and a 19"x1.85 prowheel
blue, huh? hmm. i'm probably going to for the black for $75... . :mrgreen:
same old, same old here
GCinDC   10 GW
10 GW
Post by GCinDC » Oct 26 2013 11:33am
nippy this morning:
i'd charged it up like normal, and while the voltage reached 83V, the capacity is only at 81%!:
i know the display shows 51F, that's why i showed the outdoor temp...
so anyway, my guess is that the adatto measures the amps in, and now that the cells are cold, the batts accept only 81% of the amps. sound right?
i've always experienced decreased capacity in the winter, greater voltage sag, etc, but had no idea by how much. now i do!
here are my total stats, fwiw:
148 cycles, but only 63 full. interesting.. still not sure what full means. 60% or more?
almost 1k miles. when did i start riding it? july, right before WI i think, so about 3 mo.
something tells me the zippies are not going to last long... not the way i ride...
sardini   100 W
Post by sardini » Oct 26 2013 11:51am
http://www.apple.com/batteries/
Charge Cycle.JPG (17.04 KiB) Viewed 2995 times
Bill Nye the science guy   100 W
Post by Bill Nye the science guy » Oct 29 2013 10:53pm
passing a cop, lol , that is balls man!
they really need to get this controller on the market. looks amazing.
1997 Norco Bomber down hill frame
motor- 9C 2808
Controller- Ku120@45amp x 70volts + cycle analyst
Battery- 10ah nimh sub-c(53s x2) 55 kms top speed
http://endless-sphere.com/forums/viewto ... =6&t=48541
GCinDC   10 GW
10 GW
Post by GCinDC » Oct 29 2013 11:38pm
capacity plummeting! yesterday, after morning commute, i could charge it only up 71%:
and 'fully charged' this morning, only 67%:
and tonight, fully charged at only 59%!:
it can't just be the cold. the temp readings are higher than ambient because the controller is on an working..
the pack IR has risen quite a bit, shown here over a trip (not too fast either):
charged, the cells seem balanced, here after sitting for some hours, but normally at 0.020V delta..:
i'll have to check under load obviously...
andrey, if you have any ideas, please email me! :mrgreen:
here's total stats after full charge:
xenodius   10 kW
Post by xenodius » Oct 29 2013 11:43pm
Bill Nye the science guy wrote:passing a cop, lol , that is balls man!
I think ****** is expecting his any day now... don't think it's officially released in the USA but velomastera.ru finally marked it as in stock. I want mine...! And a Cromotor.
GCinDC   10 GW
10 GW
Post by GCinDC » Oct 29 2013 11:53pm
fyi:
andreym wrote:Controllers will be available in US within next month or so..
from here.
andreym   100 W
Post by andreym » Oct 30 2013 8:43am
It looks like you can reset it to Full Charge via reset statistics menu.
should help.
btw some controllers are going to US right now,
for those who want it ASAP please contact me in PM.
Avanti D8 CroMo frame, CroMotor :) + MAX-E controller. 18s10p zippy compact in Pelican 1300 case. 1.8kwhrs total usable capacity. - Deseased.
New bike will be posted soon here.
fast 1.2kw charger old GT iDrive e-bike
GCinDC   10 GW
10 GW
Post by GCinDC » Oct 30 2013 12:24pm
andreym wrote:It looks like you can reset it to Full Charge via reset statistics menu.
should help.
Even if the pack has reached full charge voltage (83v)? I'll try it now. I meant to ask you when I should use that... Always? or occasionally?
in other news, i'm not sure why i keep doing these...
i keep wanting to stop... lol
melodious   100 kW
Post by melodious » Oct 30 2013 1:38pm
It's so odd to see the flow from the rear. We're so programmed to never look back. Make your move and keep going. :twisted:
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
GCinDC   10 GW
10 GW
Post by GCinDC » Oct 30 2013 4:23pm
melodious wrote:It's so odd to see the flow from the rear. We're so programmed to never look back. Make your move and keep going. :twisted:
never look back? not sure what you mean... is this better?
:P
GCinDC   10 GW
10 GW
Post by GCinDC » Oct 30 2013 5:06pm
my battery is back!
i don't understand the BAH tho... after full charge reset, it reads:
andreym   100 W
Post by andreym » Oct 31 2013 3:53am
GCinDC wrote: :?:
set the correct value in BMS setup
Post by Bill Nye the science guy » Oct 31 2013 7:26pm
BAH might be the history of Ahs before the battery dropped off in voltage. 5.8 Ah of actual usable capacity.
motor- 9C 2808
GCinDC   10 GW
10 GW
Post by GCinDC » Nov 02 2013 8:32pm
this sound track is hilarious. so moody. grab some kleenex.
like riding home after a breakup or something! ah, me....
GCinDC   10 GW
10 GW
Post by GCinDC » Nov 03 2013 8:35pm
crezzy2k1   1 W
Post by crezzy2k1 » Nov 03 2013 8:55pm
Awesome Videos Greg. I've just spent the last couple of days reading your entire thread. Fantastic man :-)
What kind of temps are you getting with the 3540 with that new controller setup?
2004 Giant DH Comp: 24s4p, HS3540, Lyen 18fet
2010 Giant Boulder SE: 36V 20AH, MAC 7t, Lyen 12fet
GCinDC   10 GW
10 GW
Post by GCinDC » Nov 04 2013 4:20pm
crezzy2k1 wrote:I've just spent the last couple of days reading your entire thread. Fantastic man :-)
that's cool. thanks!
crezzy2k1 wrote:What kind of temps are you getting with the 3540 with that new controller setup?
memories getting fuzzy now, but i think the motor heating is much the same as w/ infineon controller.
heat is just something that has to be managed.... certainly the weakest link in my setup.
recently i think i commented how much cooler the 9C ran for similar power levels.
riding trails heats it up fast. i think i recently mentioned that on one trail ride, the motor was at 200F. i decided to go up a steep hill pedaling in low gear but in 10 seconds, the motor temp quickly rose to 300F, at which point the controller saved it by killing power to the motor.
i can cruise on a flat for a long time at high speed, with the air sliding through the motor vents, cooling it, but up steep hills, the temp rises...
just heard that my 4080 is shipping out soon. just bought a 19x1.85 pro wheel too. after failing to get a reply from volt riders after 3 attempts, (and to save myself from having to measure the dish, lol) i guess i'll lace it...
sardini   100 W
Post by sardini » Nov 04 2013 4:53pm
GCinDC wrote: riding trails heats it up fast. i think i recently mentioned that on one trail ride, the motor was at 200F. i decided to go up a steep hill pedaling in low gear but in 10 seconds, the motor temp quickly rose to 300F, at which point the controller saved it by killing power to the motor.
Greg i was fed up with the "heating problem " Now i have i little bottle with me, pouring little water inside the motor i do few meters with the controller off(to avoid sort the hall sensors),temp goes down really fast, and then WOT again!!
P.S i have painted the motor and move the temp sensor in the stator
GCinDC   10 GW
10 GW
Post by GCinDC » Nov 06 2013 9:58pm
sardini wrote:pouring little water inside the motor i do few meters with the controller off(to avoid sort the hall sensors)
my only concern is that the hall legs will corrode and eventually break. i used to seal my halls in jb weld if i'm going to expose the inside of the motor to water, but now think permatex sealant is best - certainly if they need to be replaced again!
just posted this in the torque raptor thread:
moonshine was downtown and gave me a call at quitting time. so we met up and rode a bit, before i had to drop off:
his raptor's looking great and can leave me in the dust!
Trackman417   10 kW
Post by Trackman417 » Nov 06 2013 10:39pm
That's an awesome video man. That raptor looks pretty sick in black. Do you(or moonshine) think it's worth the price?
You guys picked some good weather to go riding in. A bit scary because of how warm it is in November, though :shock: . I was sweating in my jacket all the way up in Rochester. Strange, the mornings are pretty brutal and misleading to what the day will turn out to be.
I'm liking the balancer solution though. Do you have a link for them?
K2 Sidewinder
H4065 36 mph
