GCinDC's Giant DH Comp
GCinDC   10 GW
Re: GCinDC's Giant DH Comp
Post by GCinDC » Mar 29 2014 8:20am
first baby pics are always so precious:
and here showing the live miniE:
axel, you'll want to bookmark this. it's how i rewired the controller for you to add charge port, precharge circuit and phase connectors standard w/ my motors (lol):
and after adding tape:
i'll need to swap the connectors on your bulk charger, so you can't short them like i once did. so bring that whenever you come back. or once i find a throttle, maybe i ride it over! :P
dbaker wrote:150mm axle?
'05 model on has 150mm axle, but it also has smaller triangle. only 03 and 04 have large triangle (and 135mm axle)..
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
Axel   100 mW
Post by Axel » Mar 29 2014 9:56am
Fantastic Greg, thanks you so much ! :D
I can come whenever you can with the charger and maybe the GT's throttle ?
GCinDC   10 GW
Post by GCinDC » Mar 29 2014 11:41am
just tested another magura pot type throttle (like yours) and doesn't seem to work. i'll take my half twist throttle off and we can set yours up with it.
you'll also need two longer screws to attach the miniE to your tapered handlebar:
not sure how much more time i'll have today. your soccer games cancelled cause of rain?
Axel   100 mW
Post by Axel » Mar 29 2014 2:12pm
yes canceled due to the rain (even it's not raining a lot for me )
the GT's throttle is this one
with this molex connector
looks like those one, no ?
http://www.ebikekit.com/kit-components/ ... throttles/
I'll need the TRS connector right ?
Allex   1 GW
1 GW
Post by Allex » Mar 30 2014 5:02pm
GC, that pre-charge resistor, can you please tell me the values of it? I want to buy one to. Those damn sparks make my hair raise!
GCinDC   10 GW
Post by GCinDC » Mar 31 2014 9:18am
Allex wrote:GC, that pre-charge resistor, can you please tell me the values of it? I want to buy one to. Those damn sparks make my hair raise!
the ones i use: http://www.ebay.com/itm/5-Watt-470-ohm- ... 0918425844
throttle mod. nice short cable, connects to display...:
Allex   1 GW
1 GW
Post by Allex » Mar 31 2014 12:23pm
Thx, guys. Yeah, need to do the same with my long throttle wire.
GCinDC   10 GW
Post by GCinDC » Mar 31 2014 12:30pm
allex, did you add a regen hall/brake for the brake? or, you ridethelightening? if anyone else, did, i'd love to see pics. i should have soldered in add'l wires for that!
i think andrey mentioned halls w/ 3v range are better than 5v. anyone have a link to one of them?
Allex   1 GW
1 GW
Post by Allex » Mar 31 2014 6:16pm
Yep! I did connect my regen button, on/off.
Here is the diagram that worked for me.
GCinDC   10 GW
Post by GCinDC » Mar 31 2014 6:49pm
Allex wrote:Here is the diagram that worked for me.
when you say it worked for you, do you mean it triggers regen? or by 'worked for you' do you mean it just made sense to you?
because my understanding is that the miniE (only) has variable regen, which requires three wires going to a hall sensor (same black & red as throttle but instead of throttle blue, the variable wire is white) and that the regen range is configured when a magnet passes by the hall, as in this horrific image from testing:
check out ivanev's thread and go forward a page or two: http://endless-sphere.com/forums/viewto ... 75#p829802
Allex   1 GW
1 GW
Post by Allex » Mar 31 2014 7:19pm
Yes it does work(stops the bike). Andrey insist that I make it variable, but This will be a project for later. The mini should have the same functionality as max. Try to add a button.
melodious   100 kW
Post by melodious » Mar 31 2014 7:57pm
Looks legit. Except one thing. I can't get my mind to solve the mystery that surrounds the zip tie on the brake lever. Perplexing. :?
(Yoda voice) What purpose is it that zip tie? Divulge, you must.
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
Hyena   100 GW
Post by Hyena » Mar 31 2014 8:20pm
haha, I love the ghetto hall set up.
What you really need is to let a bit of air into brake lines so they go spongey / give you more travel before biting, then you'll have more regen range before the rears are actively pulling you up :P
I realise you're just testing at this point but what about if you move the magnet and hall over to the other side of the lever so it's more out of the way of being knocked by your hands ? Have a small band of plastic or rubber or what ever that holds the magnet as shown so it 'rolls' away from the hall ? Might give a little more movement resolution ?
www.HyenaElectricBikes.com
dan974   1 kW
Post by dan974 » Apr 01 2014 12:35am
I know it's not variable but here is my contribution to a good combo , the smallest switch I found, pretty nice to set in tiny places with cyanolite then epoxy , you can even ad the micro cutting switch in line...
(Open when pressed)
http://www.ebay.fr/itm/10-Pcs-4-Pins-Mo ... 484f593f64
http://cgi.ebay.fr/ws/eBayISAPI.dll?Vie ... 1423.l2649
http://www.ebay.fr/itm/SN9F-20pcs-Red-2 ... 5d4652c072
GCinDC   10 GW
Post by GCinDC » Apr 01 2014 7:20am
Allex wrote:Yes it does work(stops the bike). Andrey insist that I make it variable, but This will be a project for later. The mini should have the same functionality as max. Try to add a button.
by golly, it does work.
in pic below, i have a hall wired in for variable regen brake, but am jumping the red and white here (w/ yellow alligator clips in background) and see that it triggers regen (display says 'brake' when regen active):
disregard negative amps - i was charging at the same time.
i've got some old ebrakes that open a switch when the lever is pulled, so might just pull out that switch to attach to my lever, to get full regen whenever i pull the lever, if i can't get variable regen working.
if you recall, i did have variable regen working fine w/ a similar hall, but the controller isn't recognizing the new one when i try to calibrate it.
fyi, i asked andrey, and he said: "And about the hall sensors, there are different hall sensors, some of them have lowest voltage of ~3.2 volts, and some of them have 4.2 volts, the ones with 4.2 could result in errors when using with our controller. so in case of replacement please use the ones with 3.2v lowest voltage."
GCinDC   10 GW
Post by GCinDC » Apr 01 2014 7:23am
Hyena wrote: what about if you move the magnet and hall over to the other side of the lever so it's more out of the way of being knocked by your hands ? Have a small band of plastic or rubber or what ever that holds the magnet as shown so it 'rolls' away from the hall ? Might give a little more movement resolution ?
yes, you're right. i think that side is the one to set it up on..
GCinDC   10 GW
Post by GCinDC » Apr 01 2014 7:25am
melodious wrote:I can't get my mind to solve the mystery that surrounds the zip tie on the brake lever. Perplexing. :?
excellent question. can't remember, but if i had to guess, i may have put it there originally to gauge the range, before finally using the tape to hold it...?
ridethelightning   1 MW
Post by ridethelightning » Apr 01 2014 7:39am
thats some serious frankenstein gaffatape action! :twisted:
youv probably got it sorted by now but yep, the white wire is the regen "wiper", using the same black gnd and brown +5v as the throttle lead.
no need to let air into the brakes, just adjust the sensitivity with the brakelimits graph screen :wink:
junction box on the bike is to keep eveything DRY. the display lead goes into the back. my regen throttle is a cut down wuxing full twist throttle, not ideal as its hard to use while braking on that side aswell. thumb throttle might be better, but it works ok. seriuos braking power with a cro.
btw- anyone using magura throttles- check where the wires join the pot, mine were seriously frayed from assembly, also my friends,almost to the point of shorting. really dangerous potential :shock: .
i resoldered the wires and heatshrinked the legs of the pot.
not too impressed with magura throttles.....just for that reason, but there are others aswell..
dan974   1 kW
Post by dan974 » Apr 01 2014 2:07pm
Hey what is the designation of your 4,2 hall sensor plz...ss41 ? I can remember
madin88   100 MW
Post by madin88 » Apr 01 2014 2:34pm
ridethelightning wrote: btw- anyone using magura throttles- check where the wires join the pot, mine were seriously frayed from assembly, also my friends,almost to the point of shorting. really dangerous potential :shock: .
how is the comfort with the short 2-finger brake lever from the shimano Saint in combination with magura throttle?
It looks like you need very long fingers to reach the lever. Currently i use a thumb throttle and it feels quite comfortable, but i would like to test the magura to have a comparison.
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
GCinDC   10 GW
Post by GCinDC » Apr 01 2014 4:50pm
dan974 wrote:Hey what is the designation of your 4,2 hall sensor plz...ss41 ? I can remember
yep, honeywell, SS41 (Honeywell Board Mount Hall Effect / Magnetic Sensors 20mA Bipolar 5V/9V/ ): a lot of diff numbers can go before ss41, but usually refer to packaging iirc. http://www.mouser.com/ProductDetail/Hon ... cYzrfDo%3d
going 45mph on the highway isn't so exciting, but sure is faster than dealing w/ stoplights. and in Virginia, feels kinda like swimming in shark infested waters! :lol:
problems w/ embed? here's the link: https://www.youtube.com/watch?v=idooxFayl3c
Post by ridethelightning » Apr 01 2014 6:17pm
the magura is ok with the saint brake lever, and the reach adjust on the saints helps too. possibly not ideal though.
the regen throttle on the other side isnt so flash as it rotates fowards which makes it awkward with the brake lever:| its just tempory until i get another option.
the adaptto throttle limits mapping/adjust helps a lot because you can turn the sensitivity up to use minimal throttle rotation for controll.
http://electricmotorsport.com/domino-tw ... witch.html
id definately consider the above pot throttle before considering magura in future. magura assembly quality is so dodgy!
GCinDC   10 GW
Post by GCinDC » Apr 02 2014 3:30pm
watch me ride on water? the path is 4" below the surface there. could be an interesting shot... :mrgreen:
cherry blossoms coming soon.
Hyena   100 GW
Post by Hyena » Apr 02 2014 5:16pm
Greg "Jesus" Crist :o
Is that whole "lake" actually just 4" deep ? That'd make a sweet video! You need a camera on the sidelines though showing the perspective of you apparently riding on water :mrgreen:
