Specialized Big Hit FSR
rodgah   10 kW
Post by rodgah » Feb 10 2012 3:02am
This frame was made by a certain forum member....most people know who he is.
Specs:
2005 Big Hit FSR Cut and changed
2011 Rockshox Totem Solo Air
Fox Vanilla RC Shock
Hayes Stroker Trail
FSA Gravity Cranks
Blackspire Downhill 32t Chainring
MRP mini G2 Chain Guide
Wellgo Bear Trap Pedals
24" Fireeye Rims
3.0" Halo Contra tyres
Carbon fiber quick release battery cover
HT3525
12 gauge spokes
12fet with 3 speed switch
CA-DP
Magura throttle
24S 10AH Lipo
4 x 6mm torque arms
Frame
Where it started
Things left to do on the frame:
Done
Electrics
Seal removed and zip tie
First attempt at lacing a rim....what a bitch :shock: with 12Gauge spokes
Torque arm (has been changed to fit a bit better). Will be laser cut from 6mm Stainless steel.....4 of them, 2 on each side. M9 Bolt holding it to the frame.
Torque arms done.
Decided to put a M8 bolt right thru and a nyloc nut on the other side.....plenty of room even with the disc on :mrgreen:
Things left to do on the electrics:
-Redo pack for more protection
Cheers
Common Sense isn't so common........
Specialized BigHit
Electrapunk
Stinky
rodgah   10 kW
Re: Specialized Big Hit FSR
Finished bike....
Specialized BigHit
Electrapunk
Stinky
rodgah   10 kW
Specialized BigHit
Electrapunk
Stinky
Timma2500   1 kW
Post by Timma2500 » Feb 11 2012 5:47am
Looking forward to seeing this up n running :)
What sort of amps are you planning on running through it?
Geez that garage looks familiar lol
Paul :D
Norco Aline / carbon fibre frame mod / 12t Mac / 12fet / 23kg
Justtoby   1 kW
Post by Justtoby » Feb 12 2012 2:52pm
Wow, someone can tig weld and fabricate really well. This is the best I have seen to date....I love it.
Well done,you got skilz and some really nice design flair.
ecowheelz   100 W
Post by ecowheelz » Feb 15 2012 2:30pm
Sweet frame! Look forward to following this build ;)
Jeremy P
eCo Wheelz - Electric Bikes & Scooters
Clean, Green, No Gasoline!
briangv99   100 W
Post by briangv99 » Feb 15 2012 5:54pm
Great work :D can't wait to see progress on this one.
See you are going with 24s10ah, looks like the enclosure could hold much a heap more. Would another 10ah fit in there?
teklektik   10 GW
Post by teklektik » Feb 15 2012 6:26pm
Very nice work, but also a really clever means to leverage an existing alloy frame as major components to simplify a custom frame build.
Can you relate how you aligned the original sectioned frame components (head tube, BB, etc ) to the battery box? Did you tack up a jig based on the original frame, section the frame, then assemble in the batt box using the jig for alignment, or was it done by measurement, etc? Any alignment issues or gotchas in the technique you used?
rodgah   10 kW
Post by rodgah » Feb 20 2012 12:41am
update....posted pics of the torque arms and wheel mounted :mrgreen:
Timma2500 wrote:What sort of amps are you planning on running through it?
um 50? so 5000w.....but i have a 3 speed switch so i guess i will likely use the 2nd speed for most riding
Justtoby wrote:you got skilz
cough paul....got skilz
briangv99 wrote:Would another 10ah fit in there?
I want to use the long 6s packs, so no, but I think another 5AH would....will re-evaluate once I work out how much range it has with ~1000wh
teklektik wrote:Can you relate how you aligned the original sectioned frame components
I think it was all done by eye/measurement, No idea mate sorry, frame looks straight whichever method was used.
cheers
Specialized BigHit
Electrapunk
Stinky
Timma2500   1 kW
Post by Timma2500 » Feb 23 2012 1:07am
rodgah wrote:teklektik wrote:Can you relate how you aligned the original sectioned frame components
Yeah just as Roger said, just by eye and measuring. Basically i cut out all the flat sheet parts, bend where needed, tack weld it together as per pics, check alignment then weld the box up. Next is cutting the original frame to suit the box shape, tack weld it to the box, check alignment and start welding it up while re-checking alignment as i go. If it moves slightly, i'll weld it accordingly to help pull it in the direction i need. No real gotcha's in the technique used, just keeping the seat tube/BB and head tube straight can be tricky. My 1st bike (the Norco) was out of alignment but it wasn't noticable while riding.
rodgah wrote:Justtoby wrote:you got skilzcough paul....got skilz
Cough, cheers Toby.
rodgah wrote:um 50? so 5000w.....but i have a 3 speed switch so i guess i will likely use the 2nd speed for most riding
Sweet, you going to drill the side covers?
rodgah wrote:update....posted pics of the torque arms and wheel mounted
The torque arms turned out nicely, that thing won't be twisting at all :)
Paul :D
teklektik   10 GW
Post by teklektik » Feb 23 2012 3:54am
Timma2500 wrote:... just by eye and measuring. Basically I cut out ...
Thanks for the technique details - appreciated :)
sico   100 W
Post by sico » Feb 23 2012 6:25am
Frock man approves of this build ... Oh Yeah!
Seriously, well done guys. :D
I can only assume that AJ has **unsubscribed** from this build :wink: :lol:
Simon
billsy   10 W
Post by billsy » Mar 05 2012 5:04pm
Very nice work guys. I'll be watching with interest
ROG130   100 W
Post by ROG130 » May 28 2012 7:38am
hi love your frame i haver a big hit i am working on and i see your Torque arms i am looking for a set for my big hit where did you get them or did you do them your self .how much would you charge to do a set for us you should do some and sell them for other big hit users :mrgreen:
iovaykind   10 kW
Post by iovaykind » May 29 2012 8:15pm
Awesome craftsmanship. I really wish I had access to a tig welder when I see these kinds of builds. Why'd you extend the headtube?
briangv99   100 W
Post by briangv99 » Aug 06 2012 6:07am
Hi Rodgah,
Did you get the BH up and running?
rodgah   10 kW
Post by rodgah » Aug 06 2012 6:17am
nah all my builds have been on pause, moved city's, new house etc etc....no time and no money at the moment. Still have it and have plans to finish it, just bigger fish frying at the moment.
Specialized BigHit
Electrapunk
Stinky
rodgah   10 kW
Post by rodgah » Feb 07 2013 9:14pm
just a bit of progress, BIG order from chain reaction came in......
starting to look the part!
nearly finished, I just have to wire up the pack/controller/motor, and get a CA and its done :)
Specialized BigHit
Electrapunk
Stinky
kudos   10 kW
Post by kudos » Feb 08 2013 3:47am
WOW :shock:
That is how an electric bike should look IMHO.
Just gorgeous.
Can't wait to see her finished.
EDIT: Just noticed your in Townsville. I have fond memories of the place and Maggie Island, came through their twice on my travels.
Kudos
Build 1A Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 49V
Build 1B Gary Fisher Wahoo Hardtail : Mac 10T 30A 49V
Build 1C Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 82V
Build 2 Mountain Cycle Fury FS : Mac 8T 40A 57V : Scrapped
Build 3 GT LTS FS : Mac 10T 30A 49V
Build 4 EEB Frame: Mac 8T 40A 49V 32Ah
Kepler   1 GW
1 GW
Post by Kepler » Feb 08 2013 4:43am
Superb looking bike. Great work.
Noticed you have a small chain ring fitted so high speed pedal assist is out as it stands. Have you considered fitting a schlumpf to this bike so that you could pedal at higher speeds?
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
Timma2500   1 kW
Post by Timma2500 » Feb 08 2013 6:21am
Looks great mate, are you happy with the head angle? Looks close to the mark. I think i might try to find a pair of those forks, they're a bit stealthier than the 888 Bombers...
Kepler wrote: Noticed you have a small chain ring fitted so high speed pedal assist is out as it stands.
Bugger, sorry Rodger, thats my fault. I haven't allowed you enough room where the box tapers out :(
Paul :D
rodgah   10 kW
Post by rodgah » Feb 08 2013 6:38am
kudos wrote:WOW :shock:
cheers, actually I live on the sunshine coast now....might have to change that
Kepler wrote:small chain ring
Im not really into pedaling if im 100% honest, but my idea of gearing it this way is for just a slow cruise speed ~25km/h....I should be able to cruise all day with a bit of pedal assistance, and not impossible to pedal without assistance. The cluster confuses the matter, I actually intended on running a single speed freewheel but the chain line was horrible so the cluster solved it and you can see the fixed position derailleur.
Timma2500 wrote:happy with the head angle?
definitely looks right, doesnt feel wrong though I doubt I would know, thing feels like a dirtbike with pedals with the 3" tyres, stuff the missus its mine hahahaha. Definitely a sweet pair of forks, so plush, makes peddling hard a bit ridiculous though.
Timma2500 wrote:thats my fault
doesnt matter, the only times I would try to pedal would be up a steep hill or cruising along slowly(along the esplanade :wink: ) if I was more serious I could put a proper derailleur on it.
Specialized BigHit
Electrapunk
Stinky
Trackman417   10 kW
Post by Trackman417 » Feb 08 2013 9:00am
Wow :shock:
That's a great looking bike man. Do you plan on keeping it the same color as the original frame? Could you post some pics of the batteries inside the frame?
You and Timma should start some sort of business up. It would be killer to have people send in there bike frames and you just tack a box into it.
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
kudos   10 kW
Post by kudos » Feb 08 2013 9:11am
Trackman417 wrote:Wow :shock:
Agreed and seconded.
I'm sure you'd have a queue of buyers for these.
Kudos
Nancy   10 mW
Post by Nancy » Feb 08 2013 9:17am
Amazing! I always love seeing examples like this of highly functional engineering combined with artistic beauty.
