Yea Olde Mutant Trek Bicycle
lawsonuw   1 kW
Post by lawsonuw » Mar 30 2008 12:29pm
Yep, this is my bicycle. And here I'll show what I'm doing to this poor soul.
First, What I started with
last non-E version
P1100324 (Medium).JPG (193.33 KiB) Viewed 6731 times
And now what it looks like with a new battery/brains box + recycled NiCd's + and old BD36
The whole thing. (this also shows why I made my rear rack)
P1100671 (Medium).JPG (129.36 KiB) Viewed 6732 times
other side of the battery box showing my run-off-charge switch, and the watt meter's switch. (also shows my headlight)
P1100672 (Medium).JPG (150.93 KiB) Viewed 6729 times
Instrument cluster showing my old Astro-flight watt meter, and bicycle computer.
P1100674 (Medium).JPG (132.05 KiB) Viewed 6723 times
At this point the bike works, and I've used it for a few rides. The duct tape and cut up zip-lock bag provide basic rain sealing for now. I'll be painting the battery box and properly sealing it once I get a few more switches and a power socket for my headlight installed. Oh yea, 33.6v 7.6Ah battery pack, should give me ~20 mile range while averaging 12-14 mph. (I'm a slow-poke biker, we'll see how long that lasts :D )
Future plans:
finish up the battery box
better head light (so I can blind the car's for a change)
Up my gearing so I can pedal with the motor
make the motor drive the bottom bracket
Marty
P.S. I'll get pics inside the battery box next time I pull it apart.
Mathurin   100 kW
Re: Yea Olde Mutant Trek Bicycle
Post by Mathurin » Mar 30 2008 3:00pm
I like it.
You have to know, not fear, that someday you are going to die. Until you know that and embrace that, you are useless. - Tyler Durden, Fight club. Ditch the fake identity you've created for yourself, walk your own way in a society of mindless drones to become real, you are not your social status.
disadvantage   100 W
Post by disadvantage » Mar 31 2008 1:34am
Those double-legged kickstands are great! It holds a bike upright, so it don't tip over with heavy battery packs.
I like the picture-frame construction of the battery pack; very strong, and probably lightweight also. I'd love to see the inside of it.
That's an agressive list of features to add. I'm interested in how you increase the pedal gearing.
lawsonuw   1 kW
Post by lawsonuw » Apr 13 2008 12:51pm
Just finished a few upgrades.
First up, a used road double chainring from the LBS used parts bin. Bumps my biggest chain ring from 48 tooth to 52 tooth.
"new" gearing!
P1100675 (Small).JPG (86.84 KiB) Viewed 6488 times
Next up, a shot of the inside of my battery/brains box. Since this shot I've added a key switch, and re-done some of the wiring of the red positive power buss. The Watt meter now turns on with the main switch, and the key needs to be turned on to drive. I've also got two open power taps for adding lights or a 12v DC-DC converter in the future. (one on the key switch, one before it) You can see the 4PDT switch I use to parallel the four battery packs when I run, then separately connect them to the integrated trickle charger for charging. Also, not shown is the adhesive backed felt added to the battery compartments so that they don't shift whenever I hit a bump.
P1100676 (Medium).JPG (128.1 KiB) Viewed 6482 times
Marty
TylerDurden   100 GW
Post by TylerDurden » Apr 13 2008 10:37pm
A thing of beauty, indeed.
Plywood + screws + glue = brickshithouse :mrgreen:
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
ngocthach1130   1 kW
Post by ngocthach1130 » Apr 13 2008 10:48pm
Where can i get those double leg kickstand? I found the ESGE one on amazon and they're like 49 bucks. A bit high.
lawsonuw   1 kW
Post by lawsonuw » Apr 14 2008 2:13pm
TD: no glue...YET, that comes after a coat of black paint, which will only happen when the bugs are worked out.
Ngocthach1130: I vaguely remember mine was $43 from the LBS. I then trimmed the legs to fit how I wanted. I think I found them at $41 and up online, so $49 is not far off. From what I can tell the double kick-stand is a tandem bicycle part. (i.e. lower volume than most bike parts, with the associated higher cost) Anywho, the double legged center stand is great! It's 'rock' steady on any paved surface, and quit a bit better on softer surfaces than my old kick-stand.
Speaking of bugs, I did a 13mile ride this weekend 'cause it was nicer out. (sun and 40F) The battery gave out at around mile 8 and 3.5Ah. After that it sill provided some power, but was clearly dying. (pack voltages went as low as 18v) Me thinks my NiCd's didn't all survive the two years of neglect since they were last used. Time to pull the sub-packs out one at a time and start cycling the cells one by one.
Marty
lawsonuw   1 kW
Post by lawsonuw » Apr 23 2008 3:10pm
I've tested 10 cells on one of my sub-packs and already found a cell that only holds ~680mAh. If I've got a cell like that in the rest of my sub-packs that would certainly explain the whole pack dumping early. (cells list 1900mAh capacity, ~2.5years old)
My plan right now is to pull all the batteries out and test them. (including some other random sub-c packs I've got) Then reassemble matched sub-packs using two 14-cell [urlhttp://www.modelelectronicscorp.com/browse_product.php?pid=30]Power Tubes[/url] with a fuse holder in the middle. While this is happening I'll revert the bike to pedal only. Once I've assembled at least 3.0Ah of tested cells I'll the rearrange my battery box, and re-install everything else.
Marty
lawsonuw   1 kW
Post by lawsonuw » May 21 2008 12:26am
Battery testing is progressing slowly. I've got 28 cells tested right now. Most of the cells are testing out at ~1400mAh. I think I'll be rolling my own powertube style battery packs. McMaster has some thin wall tubing with a 7/8th inch Internal diameter, this should be a good fit for a nekid sub-C cell.
Also, I'm planning on switching back to drop handle bars. The old set of steel drops shown in my first picture have a 7/8th inch outer diameter. Standard throttles will fit this, so I'm thinking of adding a full twist throttle to the strait section of the right drop. I'll also switch out my handlebar stem for one thats one to two inches longer so I can put the handlebars at the height I like. (even with my seat tipped forward, low handlebars bust my nuts) (Pics of these bars to follow)
Marty
lawsonuw   1 kW
Post by lawsonuw » May 23 2008 12:07pm
yet more spamming of the forum :lol:
Pic of my plan to restore drop handlebars to my e-bike. This is the same set of handle bars my bike initially had. Also need to find a handlebar stem that's about 1-2 inches taller to get the bars safely up to where I liked them.
e-bike drop bars.JPG (298.13 KiB) Viewed 6053 times
lawsonuw   1 kW
Post by lawsonuw » Aug 09 2008 8:12pm
Right, anybody know the pin-out of a Crystlyte twist throttle? I got a triangle battery from e-bikes.ca installed in this beast with a slightly modified full twist throttle from them on the drop bars. Now to get it wired in...
Done a couple test rides with the old throttle, it's nice and stable with the battery up front in the triangle. Steering is HEAVY though, a lot more responsive to steering with the hips though.
Anywho, HELP!
Marty
nutsandvolts
Post by nutsandvolts » Aug 09 2008 8:21pm
lawsonuw   1 kW
Post by lawsonuw » Aug 09 2008 8:27pm
Good that matches what I dug up on the bottom of e-bike.ca's "Troubleshooting" page... oh GOD I'm blind. I totally missed those pictures of the pin-outs in the store :oops:
Now to probe the Wilderness energy's connector.
Marty
lawsonuw   1 kW
Post by lawsonuw » Aug 10 2008 7:23pm
Ok, got it working last night. Did a test ride today. Still steers like the titanic. I DO like the new throttle position. And I need to get a left handed full-twist throttle for safety reasons. On to the Pictures. Oh yea, the seat and handlebars need adjusting. Since I've been riding mostly my Linear 'bent the position feels funny.
latest
Latest e-trek (Small).JPG (86.96 KiB) Viewed 6419 times
