20 inch full suspension twin 3220 build begins!
speedmd   100 MW
Re: 20 inch full suspension twin 3220 build begins!
Post by speedmd » Aug 21 2013 4:16pm
Holy shit batman! I'll come down and try it if you won't. :P :mrgreen:
Seriously cool supermoto bike!
Head does look steep. Should flat track well. With it on level ground, a bubble level with a protractor will get well under a degree resolution eyeballing it from the side.
What does the final ratio work out to. Looks fantastic. Great job. Please post vids when your customer rides it so we can hear what it sounds like.
thanks for sharing.
Byte   1 kW
Post by Byte » Sep 04 2013 10:38am
Very nice! Isn't that 2 or 3 (?)mm carbon fiber very very very expensive? :P
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » Sep 04 2013 2:09pm
That is 4mm carbon fiber.
Yes, VERY expensive. Of course the forks were expensive, the wheels were expensive, the motors were expensive, the shock was expensive, the brakes were expensive, etc, etc, etc.
This is a "Cost be damned" build. :D
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
Byte   1 kW
Post by Byte » Sep 04 2013 2:23pm
Hehehe :lol: May I ask what the total cost price was?
Oh, and Recumpence... comparing this bike to your PK Ripper (although this one has a lot more power), which one handles better and which one is more fun? (If they would have about the same power)
izeman   10 GW
Post by izeman » Sep 05 2013 6:25am
did you calculate range? can't be much more than a cafe racer distance. :)
if i read correctly it's 15ah and 20kW power. 75v hoc and 15ah gives slightly above 1kWh energy saved. let's assume 10kW average than it's emtpy within 6min. even at a mere 5kW it's only (really immense) 10min of fun.
or did i miss something?
btw: a REALLY impressive piece of craftmanship. may i ask for a high-res jpg (>1920x1080) of bike5.jpg and lipo2.jpg. i'd like to use them as wallpaper and inspiration.
recumpence   100 GW
Post by recumpence » Sep 05 2013 9:04pm
It is 25ah of Lipo.
Nope, not going to share the price. I do not have the client's permission to do so. :)
Matt
jansevr   1 kW
Post by jansevr » Sep 05 2013 10:30pm
i would guess between 5-6k in parts plus probably around 1-200 hours worth of time planning and machining all of the custom parts.
the one thing that i don't understand is why zippy? i would have thought something with a higher discharge rate like the 50c nano tech would have been a better option especially considering the high quality of all the other components.
recumpence   100 GW
Post by recumpence » Sep 06 2013 6:56am
The pack is 25C at 25amphour. That gives a discharge rate of around 600 amps. The system will pull 400 amps (and that for only a 1/2 second at a time while the front wheel shoots upward). :)
Here are some prices of a few of the components;
Twin motor drive with controllers, frame mounts, etc $3,000
Forks $1,100
Brakes $700
Shock $300
Carbon Fiber $400 (and that is a discounted price)
Wheels $1,100
Bike? (I bough it used and stripped and powdercoated it) I have about $600 in the frame alone.
Those are just some of the more obvious parts. You are correct about the labor time. I put about 6 hours per week into the bike to finish it.
Matt
jansevr   1 kW
Post by jansevr » Sep 06 2013 4:56pm
yea i suppose with 25ah its not a problem. i've just had bad experience with zippy in the past. for whatever reason they seem less quality than even the regular turnigy (overheating - under their rating discharge rate - low cycles before reduced capicity and puffing). nano tech just seems that it would mach the price of the bike more. and you wouldn't be running the packs so close to their rated limit (which shouldn't be a problem but it wouldn't hurt to be doing 20c on a 50c rated pack).
any chance you could get some video of this beast in action?
flathill   100 kW
Post by flathill » Sep 06 2013 5:44pm
video or it did not did happen not
the beast :D
MattyCiii   100 kW
Post by MattyCiii » Sep 07 2013 6:47pm
GREAT bike, Matt.
Thanks for sharing!
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 32mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 39mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike. Based on a common power module using a NuVinci left side freewheel.
Brentis   10 kW
Post by Brentis » Sep 07 2013 8:26pm
recumpence wrote:Latest work;
Today I installed the correct brakes on the bike, fabricated the center console, and did a bunch of chain clearance/component interference corrections.
Here are the latest pictures.
The bike is 52 pounds as it sits without batteries or controllers. It will gain 20 to 21 pounds when the packs and other bits are installed. So, the bike will weigh in at under 75 pounds with 24 horsepower. That is a 3 to 1 weight to power ratio. This is the most powerful bike at that weight I have ever built. Honestly, at this point, this thing is beginning to frighten me, seriously frighten me........ It is far more light weight motorcycle than bicycle.
It is far wilder than I initially envisioned.
Matt
I bow before greatness. Which is rare.
You make mechanical look artistic.
Function beating on form.
I love it.
Consider me bowed.
Your skills deserve mass production.
What can one say, but GREAT job.
Brentis   10 kW
Post by Brentis » Sep 07 2013 8:36pm
recumpence wrote:The pack is 25C at 25amphour. That gives a discharge rate of around 600 amps. The system will pull 400 amps (and that for only a 1/2 second at a time while the front wheel shoots upward). :)
Forks $1,100
Brakes $700
Shock $300
Wheels $1,100
Matt
Less than 10k! Deal. Sure as hell beat the ass off a Stealth.
recumpence   100 GW
Post by recumpence » Sep 08 2013 7:08am
Well, I have less than $10K invested in it. But, my labor pushes that number up higher.
Man, I am so close to finishing this thing.
At the beginning I was puting every extra minute of my time into this bike. After a while I began burning out and rushing it. Now, near the end, I am puting a calculated amount of time into the bike. That keeps me from rushing it and cheapening the bike by cutting corners.
I am so close, though. I need to stop by a car audio shop and pick up some fine strand 12 gauge wire and get the CA and it is on to soldering wire. After that the bike will be tested and disassembled for anodizing.
I have developed a high degree of respect for those building street-rods and other custom vehicles. This is just a bicycle and it is really an involved project.
Matt
izeman   10 GW
Post by izeman » Sep 08 2013 1:40pm
matt could you please post some close up pics of the rear disc caliper and how you mounted the rear disc and the gear wheel next to each other? the chain must be really close to the tire, isn't it?
could you please send me some high res pics? i'd really love to have those as wallpaper :)
izeman   10 GW
Post by izeman » Sep 22 2013 10:46am
izeman wrote:matt could you please post some close up pics of the rear disc caliper and how you mounted the rear disc and the gear wheel next to each other? the chain must be really close to the tire, isn't it?
recumpence   100 GW
Post by recumpence » Oct 08 2013 6:32pm
The controllers are mounted and all batteries are installed. I am waiting on the V3 CA and a new twist grip shifter.
Once those are in, the wiring will be done and the bike will be finished!
Matt
litespeed   100 kW
Post by litespeed » Oct 08 2013 8:05pm
Looks pretty fast.....
recumpence   100 GW
Post by recumpence » Oct 13 2013 3:56pm
Hey Guys,
A new development has arisen. The client has decided to take this project to the next level. He has requested a few things and I would like your input on them;
#1 Brake lights (I have never dealt with brake lights before for hydraulic brakes).
#2 Dual headlights with a small nose fairing.
#3 Decorative gold plating.
#4 "Whatever I think would be cool." :mrgreen:
So, what are your thoughts? I am open to suggestions!
Matt
AussieJester   100 GW
Post by AussieJester » Oct 13 2013 8:36pm
Lovely build Matt, as always :wink:
're: nose fairing, I want the same and looked to eBay for a solution there are many
Available for motorcycles that could very simply be adapted to the e-bike you have
The are street fighter fairing, can't seem to add the pic I downloaded, I'm using th atm.
Google street fighter fairing, hit images...
Hope this helps look forward to seeing the new upgrades mate
KiM
spinningmagnets   100 GW
Post by spinningmagnets » Oct 13 2013 10:44pm
There are so many great builds here, many of which have great electrical systems. But...when it comes to a comprehensive electrical system with lights front and rear, I can't imagine a more professional system than Teklektiks Yuba Mundo (6 pages). No surprise he used to work full time in the electrical industry.
“2WD Electric Yuba Mundo Build”
http://endless-sphere.com/forums/viewto ... =6&t=36959
xenodius   1 kW
Post by xenodius » Oct 14 2013 10:03pm
recumpence wrote:Hey Guys,
Matt
I'm pretty sure the brake lights will need to be custom fabbed. You could use a simple tactile switch, and some GRIN potted lights.
For the nose fairing, low density foam can be stacked, glued together, and cut to shape with a thin element like a saran cutter. Then you can use it for a carbon/glass fiber mold.
You could use a pattern to cut gold leaf foil and lay it on the bodywork, then clear coat over it. Carbon fiber + gold would look good together.
-mobile
recumpence   100 GW
Post by recumpence » Oct 25 2013 7:13am
I have parts out for anodizing right now. I also had to reorder the CA.
A few of the parts have come back and looks PHENOMINAL! The chain tensioner is red as well as the three pulleys. The motor plate and drive mount parts are black.
This bike may be taking time, but it looks incredible.......
Matt
Ypedal   100 GW
Post by Ypedal » Oct 25 2013 7:40am
i would love to see a video of it running !!.. even if just a quick vid of a slow run around the yard.... 8)
ES site status page:
Tommy L   100 kW
Post by Tommy L » Oct 28 2013 7:25am
Awesome Matt!
Here is a LED Parking/Brake light I put on my Catrike 700..... very bright!
Tommy L sends......Image
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
http://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
