Animalector's Ebike Builds
Animalector   10 kW
Re: Animalector's Ebike Builds
Post by Animalector » Sep 24 2016 7:32pm
FIRST RIDE!!!!..
On level 9, it's awesome, this is just riding around the back yard in thick grass..
CUrrent photos
DSC_0955 (Custom).JPG (149.7 KiB) Viewed 2110 times
DSC_0956 (Custom).JPG (191.41 KiB) Viewed 2110 times
DSC_0959 (Custom).JPG (121.04 KiB) Viewed 2110 times
c_saayman   1 mW
Post by c_saayman » Sep 24 2016 8:53pm
That's one mean looking beast,nice!
drew12345   10 kW
Post by drew12345 » Sep 24 2016 9:29pm
Nice clean build!
Animalector   10 kW
Post by Animalector » Sep 24 2016 10:49pm
Yeah that was the idea. Somewhat stealth, light weight, and fun.
Should I mount the display?
c_saayman   1 mW
Post by c_saayman » Sep 24 2016 11:01pm
Are the info on the display useful or is it just nice to have? If you drop the bike on it's side or just laying it on it's side in your car during transport, you always risk the change of cracking the lcd screen. Keep It Simple
izeman   10 GW
Post by izeman » Sep 25 2016 5:13am
you could integrate the display inside the side cover. that would keep it scratch safe, and would still be useable.
and now i understand your clearance concerns. "normally" the motor is more or less horizontal, so the motor center is on the same height as the bottom bracket.
Animalector   10 kW
Post by Animalector » Sep 25 2016 5:49am
Yeah I'll see how bad it is in real life when I'm on the trail. Might not be a problem. it's really only going to be a problem if I'm slowly going over logs or rocks, and hopefully I won't be slowly going over anything. Hahaha.
izeman   10 GW
Post by izeman » Sep 25 2016 6:36am
Animalector wrote:Yeah I'll see how bad it is in real life when I'm on the trail. Might not be a problem. it's really only going to be a problem if I'm slowly going over logs or rocks, and hopefully I won't be slowly going over anything. Hahaha.
i really love the bbs motor because of it's clean looks and quietness. you can still tune the controller's pas parameters to make it fit your needs. normally you touch any obstacles with your gears first. you may even build a bracket over the motor to save it from any impacts. it will reduce your clearance even further, but i don't think that you'll really need it during daily use.
just use some 8mm solid steel rod and bent it around the motor to form some kind of cage maybe?
litespeed   100 kW
Post by litespeed » Sep 25 2016 8:30am
I'll bet you will be fine. I went over quite a few big logs yesterday on my vector framed bike with 17 rear and 19 front and was completely surprised that I didn't crush my 44 t chainring. My bike bottom bracket sits lower than the average bike since I have motorcycle tires. For the record I didn't bomb them.....was about 10 miles from home and didn't want to take a chance on having to walk back! :oops:
By the way mine is a pig.....20s15p and a QS205 motor in the 110 lbs (guessing!) range. Yours should float over everything.
Tom
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 26 2016 3:30am
Guys that is awesome. Loving the update. Chris I am feeling awful about your battery issues. Cant wait to get home and get it up to you. You both should be hitting the trails this break!!!
http://ballaratebikes.com/
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 26 2016 3:33am
Oh and Andy i usually mount that gauge on my bars / stem with some neodymium magnets hotglued into the back of a 3d printed case, and run wires down and plug it in. My printer is down atm but i can send the file if you want.
Animalector   10 kW
Post by Animalector » Sep 26 2016 7:12am
Nice case. Yeah. I could also do that. The bafang display has battery level, so it's probably adequate.
If I had a 3d printer I'd take you up on the offer but unfortunately I don't... One day.
Animalector   10 kW
Post by Animalector » Sep 29 2016 5:29pm
First of all....
Absolutely awesome.
BUT....
I definitely need a chain guide, I dropped the chain a few times, and twice the chain skipped to the inside and got jammed between the CHain ring adapter and the BBS02. Bent the chain, damaged the motor covers (not critically)
I am using a standard chain ring, not a narrow wide which would help, but I think I should just bit the bullet and mount up a chain guide.
I am now considering converting to an 8-speed and an 8-speed chain, this 10sp chain is super flimsy and bends very easily. This is the first chain I've had on any bike that has bent.
LOOKING FOR 3D PRINTING SERVICE PLEASE. I need to knock up an adapter so I can mount my guide. I will supply CAD, just need the thing printed.
Animalector   10 kW
Post by Animalector » Sep 30 2016 12:35am
see how this holds up..
DSC_0969 (Custom).JPG (117.16 KiB) Viewed 2015 times
DSC_0970 (Custom).JPG (105.78 KiB) Viewed 2015 times
Animalector   10 kW
Post by Animalector » Oct 02 2016 2:57am
rather than zip ties. i decided to make a screw clamp to make it stronger, with less movement. looks good I think
DSC_0990 (Custom).JPG (76.88 KiB) Viewed 1987 times
c_saayman   1 mW
Post by c_saayman » Oct 02 2016 4:26am
Looks good. Tested it yet?
Animalector   10 kW
Post by Animalector » Oct 02 2016 5:34am
Not yet. Maybe Davies Creek tomorrow... Just for a quick run maybe.
Sean9002   1 kW
Post by Sean9002 » Oct 02 2016 10:07pm
Animalector wrote:First of all....
Jump on to 3DHUBS and find a printer near you. There will be someone in Cairns with a decent printer and fillament choice for you. :D
OSET 20+ - Custom frame and swingarm, Motorims - 66V
Ruff Cycles Porucho - MXUS 3000w - whitewalls - Gloss black/Pearl blue/copper leaf - custom tanks - bobber saddle
Giant Glory 00 - Clyte X5404 - Hubsinks - 18FET Sinewave
Fuji Nevada S - MXUS 35mm- Hubsinks - 12FET Sinewave
39inch longboard Dual 50mm, 12s lipo
Animalector   10 kW
Post by Animalector » Oct 03 2016 5:57am
c_saayman   1 mW
Post by c_saayman » Oct 03 2016 6:32am
Mate, you were flying! Awesome
Animalector   10 kW
Post by Animalector » Oct 03 2016 7:04am
Cheers Chris, yeah I gave the chain guide a good work out. Not a single chain drop, and I was going over some fairly rough stuff at speed. Very happy.
The motor was pretty warm at the end, I think a temp sensor is my next mod..
aCeMadMod   100 W
Post by aCeMadMod » Oct 07 2016 12:41pm
great ebike now we can have a race up world cup track and down, if we can hold on the bike, for your life,
last jump look like smith fleld for cx
i can give a chian things, stop droping it i have alots or make you one, i have a mill
look like you had fun, 8)
Animalector   10 kW
Post by Animalector » Oct 07 2016 5:16pm
yeah first ride was smithfield (with the drop), the most recent video was Davies Creek, between Cairns and Mareeba.
It's excellent - finally a bike that I can ride without worrying about bumps, jumps, roots. I love it.
750 W is enough, I'm not really looking to roost the bike up the hills I'm happy to pedal up in number 1 assist level, then just rid it down like a downhill bike. The Numbers 2 and 3 I keep for flat single track .
Andy
Animalector   10 kW
Post by Animalector » Nov 04 2016 6:58pm
Bought myself a 5AH 56V pack from Masters at 40% off, $250 for battery and 10A charger which I think is a great deal.
I plan to put this onto the scooter, but need some sort of bracket, so this is what I want someone to 3d Print for me.
Ego Holder 1 (Custom).png (64.98 KiB) Viewed 1833 times
Ego Holder 2 (Custom).png (76.3 KiB) Viewed 1833 times
egoBattery (Custom).jpg (50.42 KiB) Viewed 1833 times
:roll: :mrgreen: :oops:
c_saayman   1 mW
Post by c_saayman » Nov 05 2016 1:59am
Very nice battery and charger. Looks like a space ship with a mother ship charger. Will have to upgrade the scooter to match the cool look.
