Topic was started to avoid a discussion in the "Before and After" thread.
Box is made from cabinet 3(?) mm plywood and covered with 3M carbon fiber look covering. If I were to do it again, I would varnish the wood several times prior to covering to get better adhesion. It the sun, the covering heats up and bubbles slightly as the adhesion to plywood is less than stellar. Also, this light shows the overlap of the layer of covering on the front of the box. If I had known it would show up so well I would have cut the covering more precisely. The batteries (Turnigy 20C 5 Ah) are wired 3p then 6s/2s/6s =14s to allow balance charging via the 1420 Hyperion. 14s is a royal pain for wiring but just right on the HS3548. The batteries are taped/zip tied into two bricks then zip tied to the frame crossbar. The box is purely asthetic and gives zero structure allowing for the lightweight build. My DB15 balancing harness could have been made 5 cm longer too but I really don't want to do that job again.
I am still waiting on a keyswitch so the the jumper ignition wire going to the dedicated charging Andersons is temporary.
