Toms build thread - poor mans stealth
nonlineartom   1 kW
Post by nonlineartom » Jun 07 2012 6:11am
Another build! maybe I'll get round to actually finishing this one. Managed to get hold of a Carrera Banshee frame for £40 on eBay, it's based on a 2004 Kona Stinky and that's no bad thing, the frame was brand new, it seemed a shame to start tearing it to bits.
I'd love a stealth fighter but when it costs the same as a small car, it's out of reach for mere mortals such as I. I recently reclaimed my 5306 motor from the KMX which was sold so it needed a new home, cue this build.
Making a battery box, 1mm sheet aluminium cut and bent to form a 112mm wide channel
photo 1.JPG (143.61 KiB) Viewed 2934 times
3mm plexiglass side cover, note the cable guides getting in the way of a good fit
photo 2.JPG (137.37 KiB) Viewed 2934 times
fixed, which means she's going to need a respray now
photo 3.JPG (113.01 KiB) Viewed 2934 times
Enough room for 8 packs of 6s 5ah with lots of spare room for padding / switches / DCDC converter / cell logs / fuses e.t.c despite constant jiggling I just can't get any more packs in there, a few mm more in each direction and I'd probably be able to get 12 packs in there. Shame, this is a 19" frame, several sizes larger than I would normally ride. Box is mounted on the bottle cage mounts with a big steel washer to spread the load on the sheet ali to stop it bending. two U bolts clamp it to the down tube and top tube for a very very rigid fit.
photo 4.JPG (124.31 KiB) Viewed 2934 times
Getting there, steel torque arm is nearly done. Next up I've got to find some suitably sized gland nuts for a weather proof cable exit solution for the box, and find a way to securely mount the 18 fet controller
photo 5.JPG (175.44 KiB) Viewed 2934 times
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
sanford   1 W
1 W
Re: Toms build thread - poor mans stealth
Post by sanford » Jun 07 2012 7:36am
Looks great so far Tom!
Carrera Banshee's can be a bit of a bargin if you get lucky.....I bought a tatty one (full bike) last year from Gumtree for 60 quid!! It was a 17" but there was sod all space inside the frame, had planned to mount under the down tube in plastic pipes. Ended up selling it the other month for 170 quid when the greyborg came up.
nonlineartom   1 kW
Post by nonlineartom » Jun 07 2012 8:04am
Nicely done, the 19" frame has loads of room, As I say you could get 12 in if you really stretched the limits of the box size. It's a lot of bike for the money, there seems to be a lot of complaints online about the swing arms breaking on them but fingers crossed that won't happen to mine. I also need to get it properly set up as it has pneumatic front and rear suspension it's a bit like riding a trampoline at the moment. At least with the greyborg everything isn't a hack to make it fit
nonlineartom   1 kW
Post by nonlineartom » Sep 18 2012 2:36pm
photo 4.JPG (114.68 KiB) Viewed 2588 times
tada, powder coated pearlescent white. it was a dam cheap job so a little rough around the edges but I'm sure I will bash the hell out of this frame as it's designed for trail riding.
nonlineartom   1 kW
Post by nonlineartom » Oct 06 2012 10:32am
slow progress. Chipping away all the paint in the bearing mounts because I didn't cover them, idiot. Also wish I had made a note of where all the bushings went, there are hundreds of them!
frame 2.jpeg (163.9 KiB) Viewed 698 times
pendragon8000   1 MW
Post by pendragon8000 » Dec 01 2012 6:21pm
How's it coming along. I'm keen to see it going. Battery box looks nice.
Poor mans stealth is pretty much what I was thinking when I built my ebike. Still cost a lot though.
8)HYENA high power ebike kits
My builds
scott 29er + Hyena kit, mon-goose to MON-STER 6KW, Free Agent RC Mid Drive, videos
my bike goes so fast 'cos it charges the battery while I pedal
nonlineartom   1 kW
Post by nonlineartom » Dec 04 2012 2:57pm
Still got the frame, got a bit caught up re-assembling it, the swing arms don't rotate freeley and I think I got the bushings / bearings wrong, really wish I had made better note of how it went together, idiot. The 5306 has since been sold due to low funds but I'm hoping to re-start this build, maybe with a GNG 450W mid drive kit in the spring who knows. Or if someone in the UK wants this frame complete with battery box then they are welcome to make me an offer.
pendragon8000   1 MW
Post by pendragon8000 » Dec 05 2012 2:52am
oh well i would have love to see you get it going hub or mid drive. would have been i sik ride by the looks.. dont give up.
My builds
rui_fujino   1 kW
Post by rui_fujino » Dec 05 2012 4:50am
if you want to get it going then I dont mind selling my GM rear hub motor (48v kit motor without wheel)
It has damaged wires and dead halls but other than that, its actually in quite good shape.
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
EV miles: 3000miles (2015/06/26)
liamcaff   1 kW
Post by liamcaff » Feb 01 2014 11:44am
I know this thread is old... but still have the frame with box for sale?
