E-S Phasor Electric Bike Owners
Rodney64   1 MW
Re: E-S Phasor Electric Bike Owners
Post by Rodney64 » Dec 31 2016 5:44pm
Has anyone tried a cyclone middrive on a Phasor
Microbatman   1 kW
Post by Microbatman » Jan 01 2017 9:46pm
Rix wrote:So did you ever get it running MB? Looks great in flat black. Looks like the front tire was mounted backwards.
Yes she is running!! Running very well.
Great eye. Yes the front tire is mounted wrong direction but still works fine. On my list of things to do.
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Rix   100 GW
Post by Rix » Jan 01 2017 10:51pm
Glad to hear it. Funny thing about mounting the tire backwards is, when you use the front brake off road, it will hook better.
PRW   10 kW
Post by PRW » Jan 07 2017 11:12pm
been busy adding things to the Phasor - both of which have turned out well, so I thought I would post here.
Added mudhugger mudguards - after a trip in the rain, needed something, and I don't really like the rear guards that are attached to the seat post. https://www.themudhugger.us.com/
With the Phasor, they don't line close to the tire at the rear - project out a bit more aggressively. Got standard rear, and long front. The sides of the front mudguard needed to be cut off, as there wasn't enough clearance between the wheel and the fork. Very easy to attach, with zipties
Also added a kickstand - found a cheap kickstand on ebay http://www.ebay.com/itm/401235258500 , so rather than buying the more expensive Moose or similar, got this. Had to pack out both side and bottom with wood to get it to fit - but fits really well
Next up: the front lights doctorbrody advised in another thread, once the clamps arrive. Nice when things actually work out as you had hoped!
litespeed   100 kW
Post by litespeed » Jan 08 2017 10:15am
Fenders look good. Looks like you have 2.75 or 3.00 on the rear, does it look like it's wide enough to catch most water? Same question on the front fender?
Those lights look excellent in that other thread. Let see a picture after you mount them up. I assume you bought the brackets he linked to?
Tom
PRW   10 kW
Post by PRW » Jan 08 2017 11:18am
litespeed wrote:Fenders look good. Looks like you have 2.75 or 3.00 on the rear, does it look like it's wide enough to catch most water? Same question on the front fender?
Tom
Tom,
24 x 3" inch both front and rear. The front fender only just clears the tire, so it catches almost all of the water; the rear not quite as much, but still gets say 80%, with a bit of spray at the side.
the first 3 photos are the front - you can see how close it is to the tire. the 4th photo shows the flare at the rear; the 5th, where I placed it on the swingarm. I could maybe have placed it about 2 to 3 inches further back, which would have put it much closer to the tire and made it more effective - but I prefer the aesthetics of where it is!
Regarding the lights; yes, I bought the same brackets he referenced. Will post once I get them - I think I will hang under the bars, not mount on top.
ohzee   1 MW
Post by ohzee » Jan 08 2017 11:42am
Looks nice PRW. I bought the same kickstand and had a friend cut/weld the clamp portion so it fit better then painted it black. Works well for me very solid.
litespeed   100 kW
Post by litespeed » Jan 08 2017 11:46am
Thanks for the pics.....I have a 19 x2.75 front and 17 x 3.00 rear. I like that look.
Tom
PRW   10 kW
Post by PRW » Jan 08 2017 12:00pm
ohzee wrote:Looks nice PRW. I bought the same kickstand and had a friend cut/weld the clamp portion so it fit better then painted it black. Works well for me very solid.
thanks - I am going to paint (plasti dip) it back. Agree, very sturdy
litespeed wrote:Thanks for the pics.....I have a 19 x2.75 front and 17 x 3.00 rear. I like that look.
Tom
looking forward to seeing photos!
JtHaas   10 W
Post by JtHaas » Feb 01 2017 3:00am
Updates to come in the future for the few still on this thread.
-Front Headlight, something baja style or circle in the front
-New controller
-Reconfiguration of the batteries
-New wiring harness and fuses etc.
-Oil cooling motor to aid with additional power (before and after test to come) Or if somebody would like a BMC V4 in a 26inch rim for a bigger motor? :D??
-Tire liners, stiffer tires, anything to stop flats.
And more vids because I enjoy my camera!
I biffed a bit in this vid.
Rix   100 GW
Post by Rix » Feb 01 2017 11:59am
Right on JT, nice little crash at 3 minutes, liked the video, I would like to see David Pearce get back in the game of ebike frame building. To my knowledge, he is the first of the DIY options. Thanks for making the vid, look forward to seeing more.
PRW   10 kW
Post by PRW » Feb 03 2017 5:37pm
JtHaas wrote:Updates to come in the future for the few still on this thread.
-New controller
nice video - and not the first time you have crashed, I see! :D
nice riding overall!
Rix   100 GW
Post by Rix » Feb 03 2017 10:57pm
I think you could have benefited from a Scotts Steering stabilizer. Long live 2 strokes
PRW   10 kW
Post by PRW » Mar 04 2017 12:42am
Decided I didn't like the tangle of cables from the front headlights and the CA being visible. Found a Kawasaki headlight on EBay http://m.ebay.com/itm/252760287696? , trimmed it down (cut it in half ) and installed it. Much neater.
Rix   100 GW
Post by Rix » Mar 04 2017 10:24am
That came out good.
PRW   10 kW
Post by PRW » Mar 04 2017 12:05pm
Thanks Rix!
Rodney64   1 MW
Post by Rodney64 » Mar 05 2017 7:52am
Good to see the forums still active. How are you liking the Phasor PRW.
PRW   10 kW
Post by PRW » Mar 05 2017 9:44am
Rodney64 wrote:Good to see the forums still active. How are you liking the Phasor PRW.
Hey Rod,
Loving the Phasor, thanks! Very plush, stable ride. For street and high speed trails, it is great, the way it is set up.
PRW   10 kW
Post by PRW » Mar 15 2017 11:58am
I had a minor mishap (accidental wheelie event :D ) which broke the rear fender. Rather than replacing it exactly as it was, using the same type Mudhugger, I cut the base at 45 degrees and re-joined it with glue. Drilled new fixing holes for the zipties which go through and secure both pieces.
New alignment provides much more resistance to mud and water spray - doesn't look quite as good, imho, but more effective.
JtHaas   10 W
Post by JtHaas » Mar 29 2017 6:34pm
PRW wrote:Decided I didn't like the tangle of cables from the front headlights and the CA being visible. Found a Kawasaki headlight on EBay http://m.ebay.com/itm/252760287696? , trimmed it down (cut it in half ) and installed it. Much neater.
That headlight fairing looks a little too big :P I actually found a company that sells headlights with full plastic fairings like you'd find on a dirtbike. (Mountainbike sized)
I've been lazy guys :D i've just been riding my bike. I don't have too much time with college to make videos or post up here and also I'm afraid to run any more power than I currently am through my v4 bmc. I can't afford any other motor though.
Do you guys think it could handle 50-60amps at 55volts? Or 15s. Otherwise I'll stick with my safer side still... Regardless if there's anything you want to see from the phasor let me know. I'm hoping to put it against some 110 kawi's in the future. I'll most certainly video tape that one haha!
JtHaas   10 W
Post by JtHaas » Jun 01 2017 5:00pm
Rodney64 wrote:Has anyone tried a cyclone middrive on a Phasor
I've been thinking about this for a good while now. Noise is definitely a factor to consider and also the idea that it isn't worth it for just 3000 watts of power.
Regardless though it requires a new back wheel and obviously a more substanstial way of mounting which would involve frame drilling or something to prevent the motor from swaying and bucking. If I were to make my phasor I mid drive I personally feel the pedals wouldn't even be worth it at that point. Direct chainlines between the motor and wheel are much stronger. You couldn't run too much power without it falling apart. The lightning rods go through incredible wear and tear at anything over 3000w because the motors function with the pedals. Normal bike chains can't really handle that power either without maintenance (It would have to be a bmx chain as well). Personally I really like the way my bike is balanced right now but if I someone put it all together and found solutions to all those problems (not including noise) I'd be happy to do them to my bike in all honesty :D any input?
the12be   100 W
Post by the12be » Jun 02 2017 3:44pm
yeah why are people using mtb chains on high rpm motor and not motor cross chains or ti ? :pancake:
Rix   100 GW
Post by Rix » Jun 03 2017 2:50pm
the12be wrote:yeah why are people using mtb chains on high rpm motor and not motor cross chains or ti ? :pancake:
Need more cow bell.
PRW   10 kW
Post by PRW » Aug 13 2017 10:07pm
so.... I found that riding the bike on longer trips, my neck would start to hurt after about 20 miles. This seemed to be due to leaning too far forward - so I replaced the handlebars with 5" riser bars, and flat grips at the same time. So much more comfortable!
Rix   100 GW
Post by Rix » Aug 13 2017 10:55pm
Set up nice with your headlight/fairing, looks really good.
