Excelsior/Strong GTS Cromotor Build
pucksterpete   1 kW
Re: Excelsior/Strong GTS Cromotor Build
Post by pucksterpete » May 07 2013 7:50am
hjns wrote: It is, but only if you keep amps low. If you start pulling more than 40A at 20S, you are pushing the limits of a 12FET 4110 controller. If you regularly pull higher amps, consider an 18FET or 24FET controller.
True, Rated amps is set for 40A & Phase at 80A, 45mph isn't too bad! Paul (cellmans) 24fet with Jpegy to possibly be fixed, Lyen 24fet shipped back to him to be fixed, Zombiess 4115 on its way to me. Will see what happens.
Tnx
Optim Alp Hardtail with MXUS Motor
20S 2P Turnigy 5.0 Hard Case
Top speed 38mph tops :)
Hyena Special
http://endless-sphere.com/forums/viewto ... 97#p585997
Excelsior/Strong GTS with Cromotor
24S 3P Turnigy 5.0 Hard Case
Top speed so far 53mph
http://endless-sphere.com/forums/viewto ... =6&t=46993
pucksterpete   1 kW
Post by pucksterpete » May 29 2013 6:37pm
I recently picked up a 24fet 4115 infineon controller from Zombiesss I ran it for the first time today at 24S 100V. What a difference between the 4110 & 4115 with heat. She run much cooler as so does the cromotor. I was able to hit a new top speed of 50mph. With Zombiess's help, I was able to add cruise control to my current throttle setup.
So thumbs up to Zombiess's 4115. I will keep Lyen's 24fet 4110 for 20S riding.
Pete
Hyena Special
pucksterpete   1 kW
Post by pucksterpete » Jun 28 2013 8:29am
Not a speed run
Hyena Special
pucksterpete   1 kW
Post by pucksterpete » Feb 01 2014 2:11pm
Its been a while, but the bike has been holding up at 24s & a Cromotor until I noticed this the other day :shock:
So after a a few PM's to Doc, we came up with this
So took the bike over to a local body shop and picked her up 2 days later, here is the result :D
Around spring time I will be stripping down this bike and having it painted.
Hyena Special
samoloh   10 W
Post by samoloh » Feb 02 2014 6:17pm
Good thing you caught those cracks on time
30mph Rebook 26" Hardtail, 9C hub motor, 48v 10Ah Lifepo4 12Fet Lyen controller
pucksterpete   1 kW
Post by pucksterpete » Feb 02 2014 6:25pm
True, would have been disastrous at the speeds I hit on the road. :shock:
Hyena Special
pucksterpete   1 kW
Post by pucksterpete » Apr 05 2014 4:35am
Well, its been over a year now with this bike. With the troubles I had at the beginning with blown controllers, the only other problems I had was with part of the frame being cracked & flats! The frame has been repaired & other support bars have been added. The 18 Turnigy 5.0 lipos have been great, not much drifting in the cells. Zombiess's modified 2115 controller has been champ.
Recently I took her apart & she got a paint job. I was going to have a powercoat done, but opted out on that because Docs's torque arms were epoxied in with DP420 and it was possible they would have came off in the oven at such a high temp. I did not want to realign & put them back on. They have held up to this day. So, automotive primer, paint & clear was what I used.
Too many rear flats, its time to go MC rim & wheel. With the help from Rix, 17" rim is on its way.
Hyena Special
cwah   10 GW
Post by cwah » Apr 05 2014 6:50am
I love the millitary pack on your bike ahah!!
I'll go back to paris next month, any chance I can try the bike?
You should get proper 18650 cells rather than HK Lipo :p
pucksterpete   1 kW
Post by pucksterpete » Apr 05 2014 9:06am
Thanks! Sure, give me heads up before your over here.
Hyena Special
cwah   10 GW
Post by cwah » Apr 06 2014 4:44am
I'll be here in mid may. Are you also interested in a group buy for 18650 cells? they are way simpler to make than lipo, they hold vibration better too. The only issue compared to lipo is that they have much higher sag
pucksterpete   1 kW
Post by pucksterpete » Apr 07 2014 2:27am
I'll pass on the cells. I use to have a 52V pack made up of those cells a few years ago on my first bike. I paid a lot for that pack & it took a shit on me within 1/2 year. For this latest build I needed 100V & high discharge rate. I can't complain about the hard case lipos, they have done what I asked them to do. I'll be gone for 10 days starting May 20th. Pete
Hyena Special
pucksterpete   1 kW
Post by pucksterpete » Apr 27 2014 6:20am
The 17" mx rim is here, more than enough clearance for a larger tire on this frame, 2.75 topps Currently 2.25 Sava road tire. 26" wheel still on front, now will order another 17" rim for the front. A very BIG THANKS to Rix, for helping with this switch over. I probably would have delayed or not done it at all. Hopefully NO more FLATS!!!
Rear Wheel Spokes
12G(2.6mm).straight gauge.stainless , 106mm Length 16mm nipple length
Front Wheel Spokes
204mm 13/14G, 14ga 16mm silver nipples
Have to lower the rear mud guard & maybe make it shorter
Hyena Special
pucksterpete   1 kW
Post by pucksterpete » Jun 19 2014 3:48am
Well, the front rim has been down sized from a 26" to a 17". Feels more stable, responsiveness is a little slower, geometry feels fine. But I have a question, I have noticed an increase in temperature on the motor. Before with a 26" upfront & 17" in the rear, she ran cool, but now after riding today for the first time with the 17" front & rear, she has ran hotter; is the 17" front the reason?
Oh by the way the spokes I ordered for the front ended up being 4mm too long, that's my fault, so had some grinding to do.
Also, with the dropping both the front & rear, I got pedal strike!!!!, So it's either cut and re-tap or buy a smaller crank arms. Will see. Never finished!!!! Here some today pics.
Hyena Special
pucksterpete   1 kW
Post by pucksterpete » Jun 19 2014 3:49am
Fixed the pedal strike, changed out the 170mm crank to a 140mm, came from one my young daughter's bike. It only has 2 chaingrings 28t & 38t, good enough if I run out of juice to pedal home with.
Pete
Hyena Special
pucksterpete   1 kW
Post by pucksterpete » Jun 19 2014 4:04am
Came a cross a small crack right at the seat tube clamp going almost all the way around the tube. I did see where you could get some thinner gauge metal and overlap it over the area & weld it. But instead of that I just had a garage patch it up. I also plan on just applying some DP420 all around the area for some added strength and one more thing, I added a 2nd seat tube clamp just above the first one, but on the seat stem, not the tube, to handle my weight (see pic below). Idea came from here http://www.tokyocycle.com/bbs/threads/c ... 024/page-3
All fixed for now...
Hyena Special
macribs   1 GW
1 GW
Post by macribs » Aug 01 2014 8:34am
Brentis wrote:
pucksterpete wrote:
I wish I knew of a simulator that was for the Cromotor, haven't found it yet.
The Cromotor has been modeled on the ebikes.ca simulator. It is listed as noname 5004
I too wish there was a simulator for the cromotor. Seems that the "noname 5004" is gone from the simulator.
Anyone know if there is a simulator for the cromotor? Or have ebikes.ca maybe changed name on the cromotor to something different?
Brentis   10 kW
Post by Brentis » Aug 01 2014 9:08pm
Hey Macribs.
Don't quote me on this, but if iirc (couldn't find the thread) there is a blank entry at the very top of the list of motors.
That blank spot is what the no name used to be. Running some battery and amp combos at it, makes me believe that is the cromotor. Not sure which version of the cro it is, nor if it is.
Maybe you can shoot ebikes.ca an email and ask them to clarify.
Brentis   10 kW
Post by Brentis » Aug 12 2014 8:02pm
Hey Pete,
Sorry I missed out on all the drama with the cracking frame. Your triangulation mod looks like a good upgrade for my frame as well. No cracking, but what you did looks fairly simple and effective. I'd like to powder coat my frame, so will get that done. Bugger the cheese steel these frames are made from. Hope I got a better batch.
The paint job and upgrade wheels look great, congrats.
Keep us updated on impressions.
Enjoy.
:mrgreen:
pucksterpete   1 kW
Post by pucksterpete » Aug 14 2014 3:50pm
Brentis wrote:Hey Pete,
Enjoy.
:mrgreen:
Whats up Brentis, how have you been? Yeah it was kind of a bummer to see the cracks in the frame & seat tube, the triangulation mod was docs idea and it came out good, haven't had any other issues with the frame, but always keeping an eye out. thanks to Rix & the greg's post http://endless-sphere.com/forums/viewto ... =2&t=55458on the 19" rim switch over. I have 17's on both and the handling is much better and no more stupid flats. Have you been working on your bike? Pete
Hyena Special
Brentis   10 kW
Post by Brentis » Aug 29 2014 3:46pm
Hey Pete,
I'm doing alright. I had some life happen over the last year and am slowly picking up and putting together the pieces.
No biking this entire year :cry: but I have or am gathering the pieces for a new build over the winter.
Stay tuned.
Hope your well
Talk to ya soon.
pucksterpete   1 kW
Post by pucksterpete » Sep 04 2014 10:04am
Well....another weak spot, after riding on some dirt trails, no jumps and then hitting the street, going around a corner not too fast, boom, bike drops down, I didn't wipe, I thought I had a flat, nope this
so, decided to cut out the mount for the shock off the broken tube and dp420 it further back and then have it welded
I guess it came out okay, we will see, she does ride a little stiffer in the back, now lets see what else fails
Pete
Hyena Special
Tommy L   100 kW
Post by Tommy L » Sep 25 2014 5:21pm
Awesome builds!
I've got this to start with:
I ran into forum member Brentis and now I have this to bring alive!
I'm thinking of 17" or 18" or 19" wheels.
I need to pick a Rim size that will fit the Shinko SR714 or Pirelli ML75.
How do you like the 17's?
Tommy L sends.... \m/ . . \m/
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
http://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
pucksterpete   1 kW
Post by pucksterpete » Sep 26 2014 3:04am
Hey Tommy, so you got Brentis's Strong, very nice, you will have fun with that build. If you can add some extra support in the frame and keep an eye out on the welds, as you can see I had a few frame failures. The 17's are working out great, a little bit heavy, but the cromotor is doing its job. Switching over to a moped tire has been really nice, no more flats, tire wear is a lot slower, softer ride. The only bitch is if you have to pedal this bike home its a bear. Here is a link to another member on here LSBW, he did a great job on his Strong build
http://extronebike.ca/
Good luck, post up some pics & video of your build
Pete
Hyena Special
Tommy L   100 kW
Post by Tommy L » Sep 26 2014 6:23am
Thanks Pete! :)
Tommy L sends..... \m/ . . \m/
pucksterpete   1 kW
Post by pucksterpete » Sep 26 2014 8:26am
Since April 2013 on 24s 3P I have put 11,514km on this pack, 329 cycles, 4.18v charged 3.6v discharged per cell. The Turnigy 5000mAh 4S1P 14.8v 20C hardcase packs have done fine.
Hyena Special
