recumbent build with homemade triple stator AF motor
Lebowski   1 GW
1 GW
Post by Lebowski » Jun 04 2013 7:21am
time to build something again :D
Over the winter I build a 2 kW triple stator axial flux motor for my recumbent. The goal is a bike where the motor
goes through the transmission so that it will climb the hills around here (which can be up to 15% incline).
The original idea was something like this:
but the motor hit my legs :cry: So: new idea and how it'll be (still has 9 to 10 cm of groundclearance):
The idea is that you can either cycle, run on the motor alone or both. Both the motor and the jackshaft are based on a Deore rear wheel bike
axle with a freewheel. From the motor (12T sprocket on the freewheel) the chain will go to the jackshaft (52T sprocket fixed to hub).
A steel 22T sprocket (also fixed to the hub of the jackshaft) will then go with a chain to the rear, where a derailleur will provide 7 or 8 ratio's.
From the pedal (55T) a chain will go to a sprocket (about 22T) on the freewheel part of the jackshaft.
As far as rpm's go: with 90rpm at the pedals the jackshaft will rotate at 225 rpms and the motor at 975 rpms.
From above:
I typically build quite rudimentary as I'm lacking in the skills departement. Also, I build in my spare bedroom so I cannot weld or anything.
I'll use lots of 15x15 mm aluminium square tubing (2mm wall thickness), lots of 6mm thread which can be bent to make U-bolts, and
flat 3mm aluminium sheet.
John in CR   100 GW
Re: recumbent build with homemade triple stator AF motor
Post by John in CR » Jun 04 2013 9:52am
Legos and zip ties, I love it, though a lack of duct tape is disappointing. I can wait for video of rides in the Alps. :mrgreen:
Lebowski   1 GW
1 GW
Post by Lebowski » Jul 18 2013 12:29am
It's summer so progress is slow, but I'm slowly getting there
Lebowski   1 GW
1 GW
Post by Lebowski » Jul 22 2013 10:24am
jackshaft finished :D
with a 2kW motor at 1000 rpm, the force exorted on the chain by the black 22T gearwheel will be 200 kg :shock:
jag   10 kW
Post by jag » Jul 22 2013 12:27pm
I'm amazed and impressed what you can do with basic tools and materials!
(My own attempts tend to have +-0.5mm error and assembled results end up distorted :(
I have a recumbent with a similar jackshaft and chainring setup under the seat. One problem I have is that the jackshaft flexes a bit too much when power is applied.
You mention you will put 200kg (2000N !!) on the jackshaft. With the chainrings off centre your motor and jackshaft frame might also flex. You can test this by loading and unloading either the motor or crank chain while looking at your assembly. (Easiest is to mount the chains, sitting stationary on the bike and pump the crank/pedal with a few good pushes while looking at the jackshaft and frame parts.) My guess is that a first point of weakness will be the frame corners below. Maybe stiffen with a triangular brace from 5mm aluminum?
PS: If you like to see some places nearby where work=fun try visit the Micro Air Vehicle group at ETHZ or the Robotics instistute at DLR (Nearby Munchen)
Lebowski   1 GW
1 GW
Post by Lebowski » Jul 23 2013 1:11am
Well it's the motors job to keep the subframe square...I hope this is enough else I will try
to bolt a flat square of aluminium to the subframe. But I plan to use my own torque (FOC) based
controller on this bike, so I'll just start with a low max torque and slowly work my way up.
Most of the accuracy comes down to the holes... I drill with a drill column and pre-punch the
hole locations with a sharp hardened nail. Then I pre-drill with a thin 2mm drill, this will
automatically center on the pre-punched impression. After that I go to the drill size required...
Lebowski   1 GW
1 GW
Post by Lebowski » Aug 28 2013 11:08am
transmission coming along nicely, one last chain to go :D
nicobie   10 MW
Post by nicobie » Aug 28 2013 12:02pm
Nice work! I like how you used off the shelf parts and modified where necessary.
Looks like a lot of work. Bet you feel that you are married to your drill press by now. :mrgreen:
Take it easy... but take it. (Woody Guthrie)
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
Magazine article https://www.electricbike.com/nicks-etownie/
Lebowski   1 GW
1 GW
Post by Lebowski » Sep 23 2013 11:59am
cable operated throttle based on a slide potentiometer
I took the ratchet mechanism out of the shifter to get a nice smooth (torque) throttle. If you have a speed type throttle, keeping the ratcheting gives you an easy cruise control
my new, eh, brake adapter :-)
room for 30S lipo, 30A fuse :-)
hose clamps to hold the battery compartement in the frame
I got chicken so I decided to add a bracing plate to keep the sub-frame square
chain tensioner in the motor chain
spinningmagnets   100 GW
Post by spinningmagnets » Sep 23 2013 12:36pm
Wonderful work! to the untrained eye, this entire project might seem a bit "cluttered", but as a test mule, you are on the cutting edge of the next gen of a truly wonderful system.
FOC (AKA "sinewave") control of a brushless motor is smoother, more efficient, and most importantly, quieter than the common square-wave controller.
Giving the motor some gears? this provides a wider range of performance from smaller and more affordable motors. By shifting gears and keeping the motor in the efficient motor-RPM range, you produce less heat in the first place, and...shedding heat is less of an issue.
As to it being axial-flux (instead of the common radial flux), it allows a modular motor design. A single stator/rotor pair is light and affordable, a triple stator/dual rotor is slightly wider, but can take triple the amps, while using the same assembly-line parts!. A quad-stator/triple rotor (again using more of the same parts), can accept even more amps.
Need a different kV? swap-in different stators, no rewind necessary. The widest possible version could be mounted just in front of the rear wheel of a longtail cargobike.
The fact you are developing this on a more efficient and more comfortable recumbent shows that you are a free-thinking radical, and...if you end up adding a front fairing with an aero tail-sock...I'm afraid I will simply have to throw my hand up and walk away...
The public is not ready to accept this kind of advanced "common sense" design...
Harold in CR   1 MW
Post by Harold in CR » Sep 23 2013 12:52pm
+1, what HE said. :lol: :lol: REALLY nice layout. 8) 8)
Thanks to Justin, the forum is open source and NON-commercialized.
Lebowski   1 GW
1 GW
Post by Lebowski » Sep 27 2013 11:26am
Lebowski   1 GW
1 GW
Post by Lebowski » Oct 01 2013 12:53pm
just made the first test ride
bloody hell !
:mrgreen:
Everything held together fine, no problem with the subframe twisting or the gearwheels sheering of the jackshaft.
Top speed was, well, fast, will put a speedo on it to have a measurement. It pulled up a 13% slope without any
pedalling no problem, the motor ran at full speed (in first gear) so was not bogged down due to lack of torque.
And I was only at 80 V ! 100 or 120 V is gonna be so cool :mrgreen:
beast775   100 kW
Post by beast775 » Oct 01 2013 2:18pm
That looks like a whole bunch of work :shock: .but dang is that sweet!
2 FINGER SALUTE TO ESSO.no buying gasoline for 14 years now.
I spent all my money on bicycles women and beer the rest i just wasted.
Jolly Jumper   100 W
Post by Jolly Jumper » Oct 01 2013 2:41pm
Congratulation for the finish :mrgreen:
Amazing work.
I know the feeling riding on a self made ebike is giving. But with a selfbuild motor + transmission + throttle it must be something in ² of it :mrgreen:
How much efficient is this form of motor ?
Lebowski   1 GW
1 GW
Post by Lebowski » Oct 01 2013 2:51pm
Don't forget the home made and self developed FOC controller :D
At max torque losses are 500 W. But at 100V supply by then it's delivering 2300 W, so taking 2800 W from battery.
madin88   1 GW
1 GW
Post by madin88 » Oct 01 2013 3:04pm
Great job. Selfmade motor and FOC controller deserves lots of respect!
the whole transmission does look very complex as well
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
docnjoj   100 GW
Post by docnjoj » Oct 01 2013 3:06pm
Simply beautiful hand-machine work. When I used to do that kind of stuff for trike frames it looked like beavers chewed it! Great stuff!
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
Lebowski   1 GW
1 GW
Post by Lebowski » Oct 08 2013 1:43am
After going up and down the neighbourhood all day yesterday I finished testing of my recumbent and took it back
inside for the winter (there'll be snow at the end of the week, but I don't care as I'll leave for Malorca the coming
weekend :mrgreen: ).
Speedwise it's just too fast for its own good. I didn't measure speed but at a certain point you can feel that the
frame start weaving a bit, it starts to oscillate slightly. But I think this is unavoidable seeing as that the bike
is basically a big ladder on its side. The more than 2000W on the street (so after elec. losses) is very nice, I
don't even need the lowest gear to go up a 13% slope :D Basically it has nothing to do with a bicycle anymore,
to me it feels like a souped up moped. Especially when you start racing cars from the lights, going up a 5% slope :D
Things I will change over the winter:
- tacho with speed limiting function (for safety but also legal reasons). Bought me a nice (single color) 128x32 OLED display
and will build a tacho mimicing the one from an old Citroen car (which has a tacho with a fixed need and a drum with
numbers rotating behind it)
- build a new 6 FET (150V 32A phase) controller, use proper 50A current sensors and not the 150A from the test controller
(and have proper power at startup (sensorless) by using high frequency signal injection to measure magnet positions)
- make a cover for the battery department
- change to a rotary grip shifter on the left handlebars
Lebowski   1 GW
1 GW
Post by Lebowski » Feb 25 2014 1:09pm
busy with the last metalwork and other things before I start building the controller.
I made a battery bag with a wooden backplate for carrying 30s LiPo:
the bag is made from 1mm thick PVC sheeting, sold here for the purpose of lining the garden
pond (I still have a few square meters of the stuff as I used it for lining my folding kayak). The
stuff ir very easy to glue.
Big zipper sewn in with the sowing machine:
one 5s brick:
for the controller:carrier for the 6 FETs with holes for the phase wires and threads for mounting
some cooling fins (only 3 to 3.5 kW controller):
the controller is in a 1550G box from Hammond, as sold by Digikey. Here the lid is mounted to the rear fork of the recumbent:
how it will be sitting, wiring and throttle cable coming from underneath:
already got the PCB, still have to order parts !
r3volved   100 kW
Post by r3volved » Feb 25 2014 2:01pm
Lebowski wrote:
Daaaaamn...how long are your arms!?
Lebowski   1 GW
1 GW
Post by Lebowski » Mar 24 2014 2:59pm
basically finished :D build time about 16 months
Skalabala   1 kW
Post by Skalabala » May 18 2014 4:31am
Awesome!! :D :D
Thanks for the link bud!
A video of you ripping in the street will be so cool! Please :mrgreen:
The 500W loss, how does that compare to other motors from the shelf? That means you have 82% +- efficiency?
Boosted cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world! Born a Jap raised as a boer!
cwah   10 GW
Post by cwah » May 18 2014 6:46pm
video at max torque pleaaase
