#1 The long road
beast775   100 kW
Re: #1 The long road
Post by beast775 » Oct 18 2013 3:03pm
That swingarm is PHAT! 8) ,gonna be interesting to see the dropouts.
2 FINGER SALUTE TO ESSO.no buying gasoline for 14 years now.
I spent all my money on bicycles women and beer the rest i just wasted.
Emoto   10 kW
Post by Emoto » Nov 26 2013 2:45pm
Stage 1 welding done , forks arrived with 3 different springs soft/ med/ hard,
beast775 wrote:That swingarm is PHAT! 8) ,gonna be interesting to see the dropouts.
droupouts milled , clamping of course :) with brake caliper bracket, now back to the welder.
soaresdacosta   1 kW
Post by soaresdacosta » Nov 26 2013 4:38pm
This is why, I came here, almost every day... to see building skills like this one.
Beautiful.
Luis Costa.
Emoto   10 kW
Post by Emoto » Dec 14 2013 10:00am
Thanks soaresdacosta very kind.
Still waiting on the welder with the swingarm, it will be ready in 2 day's has stretched Into three weeks.
Im keeping busy though, opened up the other side of the main frame and fitted the forks and the tube looks straight, "thank fork :D " seat structure just needs tube welding on now iv'e worked out the height / angle, blah blah
Cutting out the the center shapes and cleaning all edges by hand filling took a total of 4 hours, the term "think of a time and double it" is sooo true on some jobs.
deffx   100 W
Post by deffx » Dec 15 2013 5:01am
Wow, awesome work. Surprised you're not using the big hits four bar rear suspension or copying it at least.
charleyhaze   1 W
Post by charleyhaze » Dec 15 2013 6:57am
wow man, this is pro! :) What else can I say? :P
Emoto   10 kW
Post by Emoto » Dec 16 2013 8:31am
deffx wrote:Wow, awesome work. Surprised you're not using the big hits four bar rear suspension or copying it at least.
This is a great question, i got to the batt mounting stage , and thought bugger it... ill nearly do a frame in the time it would take to make a batt enclosure [ ali frame and carbon surround/fairing] on the big hit.
But this new frame had a lot more design / fab implications than i anticipated ,[iv'e found most of the design work in the swing arm] but always better to look at it optimistically to start with.
I sold my supermoto to fund this journey,but am looking forward to no valve clearances/oil changes blah blah. just plug it in and watch the lipos charge :mrgreen:
Charleyhaze if i can motivate you thats why were all here.
deffx   100 W
Post by deffx » Dec 16 2013 11:26am
Nice husky. Shame you sold that. But yes they are a bit high maintenance. Sold my trail bike and road bike last year to. Just wasn't using them enough to justify maintenance, insurance, registration. Plus I'm getting on a bit and noticed the ground hurts more now. An e bike doesn't really replace them exactly but almost for shorter trips. In fact I beat my son on his moped sometimes just with the shortcuts I can take. Were he has to follow the road rules.
beast775   100 kW
Post by beast775 » Dec 16 2013 12:47pm
Swingarm looks great! theres some tricky angles to weld,i know I would make a mess of it. :lol: ,forks are awesome,what steering rake are you figuring on? the battery frame box might look good with relaxed geometry? cool build,this one has piqued my interest ... you made me miss my KTM 520 supermoto damn I liked riding that bike!
Emoto   10 kW
Post by Emoto » Dec 20 2013 10:08am
deffx wrote:Nice husky. Shame you sold that. But yes they are a bit high maintenance. Sold my trail bike and road bike last year to. Just wasn't using them enough to justify maintenance, insurance, registration. Plus I'm getting on a bit and noticed the ground hurts more now. An e bike doesn't really replace them exactly but almost for shorter trips. In fact I beat my son on his moped sometimes just with the shortcuts I can take. Were he has to follow the road rules.
I use to ride MX i was made of rubber then. now it takes longer to heal, i plan on having 2 ebikes, no rego therefore i hope no guilt if im no using it as much... but i cant see that :) .
my welder is dragging his feet on the swingarm hopefully get it before chrissy then ill do a pre- assembly then start painting so iv'e sourced another welder for seat tube it's done , now im just trimming it .
Beast a friend of mine had a 520 i would miss it two. one day well have esupermoto's
Dlogic   1 kW
Post by Dlogic » Dec 20 2013 3:19pm
Both thumbs up on your magnificent mechanical work so far. :-)
That´s what bike building is all about.
Think, sketch, draw, think again, cut, grind, weld, put all the cool stuff onto the frame and yes, don´t forget to make it electric!
-Subscribed-
Emoto   10 kW
Post by Emoto » Dec 21 2013 10:41am
Dlogic wrote:Both thumbs up on your magnificent mechanical work so far. :-)
-Subscribed-
Wow thanks Dolgic and yes Totally i know you know the drill :D , dont forget dream=motivation +education, time,more tools,stare at it a bit :idea: idea,
Just bought a V3 CA-DPS and have moded it to a DP to get speed from controler halls http://endless-sphere.com/forums/viewto ... =2&t=56052 not to hard, but it was a few mm to wide to fit in the frame so i measured the v3 case internally /externally and carefully hand sanded the sides leaving 1mm to spare ,fits snugg now, it felt strange to take a sander two a new CA, next is pulling up the button's and pack them so they are flush with the frame for good access.
Dlogic   1 kW
Post by Dlogic » Dec 21 2013 12:55pm
That´s what customizing is all about. :mrgreen:
Don´t stick with the stock stuff.
It cost you a fortune, you´re unsure if the mod will work, it might end up broken?
Great, let´s open it up end get going.
I have to be honest, some things did die under my influence. Sometimes half my monthly salary was spent for stuff that ended up busted. The positive side of this method is discovering what better not to do.
Burned motors, fried controllers, puffed batteries and lot´s of steel and aluminum shaped into all kinds of things that later on just didn´t do the trick and ended up as junk.
But as long as there´s hope and new ideas you just keep pushing it. More and more until if finally drives like magic, with no noise, or smelly exhaust.
Love your wheel building posts.
1.How do the Michelin tires handle?
2.Are they a lot harder to pedal around then for example the Maxxis Hookworms at 24 inches?
3.Did you drill the flange holes in the front hub to fit those 12 AWG spokes?
I might get my hands on an X5405 soon and would just love to build a wheel like yours using a good motorcycle rim.
Emoto   10 kW
Post by Emoto » Dec 22 2013 9:08am
I kept the wheel building part short the main thing i learn't was getting the out of round under control first then concentrating getting it straight, the tape idea really helped.
Sadly i havent used the m45's yet but they have a good rep though, my guess is yeah they would be harder to pedal. rear od is 560mm /22 inch'.
No didnt drill the flange's , your method is very pro i think you have set the standard there, my rear spoke's have some deflection but im not that concerned my rear are 10g front 11g, next time i might go 11g rear 12g front.
Im sure once you have the x5404 in your hands and feel the weight the decision will be easy + as you know better puncture resistance , better tyre wear,looks right, i choose 17" for max exceleration :)
Just got some automotive 2pac paint gloss black of course $60 for half a litre.
Emoto   10 kW
Post by Emoto » Jan 15 2014 9:06am
After waiting a month for the swingarm to be welded , the brake calipir bracket has been welded on back to front :roll: , as this was also a brace for the droupout weld i am now machining a fix.
Seat post finished, cycle analyst cutouts done by hand.
Things to do
crank pod and tube fabricated and welded
rear shock top and bottom mounts machined/ welded.
new rear brake calipir spacer.
Then frame is close to finished. im sure one or two more things will pop up, but close.
Emoto   10 kW
Post by Emoto » Jan 20 2014 10:51am
Swing arm back at the welder's to fix caliper bracket probs and iv'e fabricated the bottom bracket tube pod and made sure it wont get welded on backwards, lesson learned :| . .
Some goodies have arrived so thats cheered up the build, im rapped with the direct mount .
trevc2   100 W
Post by trevc2 » Feb 12 2014 5:28am
Awesome thread, subscribed.
Do you happen to know what the width of the 2.75" M45 ends up at once mounted and inflated? Is is much larger than 2.75?
Cheers
litespeed   100 kW
Post by litespeed » Feb 12 2014 6:59am
Very nice work!
Tom
Emoto   10 kW
Post by Emoto » Feb 13 2014 9:56am
trevc2 wrote:Awesome thread, subscribed.
Cheers
Trev Iv'e got a 2.5" m45 on the rear and measured it for ya ,inflated its 68mm/ 2.6" so we can guess the 2.75" will end up 2.85"
Machined up some shock top mounts , as you can see iv'e gone for a dhx air shock, very light around 2kg lighter than a DNM :D .
trevc2   100 W
Post by trevc2 » Feb 13 2014 5:56pm
That's great, thanks. i was chatting to another member who said the 2.75's ended up at 3" on his 1.6 rims, so I guess it's good to plan for some extra width being required.
Cheers
Cheers
Dlogic   1 kW
Post by Dlogic » Feb 14 2014 6:31am
Splendid. This makes me think about updating my TIG welding system in order to be able to weld aluminum.
Looks so neat and professionally done. Not just like a purpose build. :mrgreen:
Emoto   10 kW
Post by Emoto » Feb 14 2014 11:29am
trevc2 wrote:That's great, thanks. i was chatting to another member who said the 2.75's ended up at 3" on his 1.6 rims, so I guess it's good to plan for some extra width being required.Cheers
Trev My rear rim is also 1.6 . my swingarm inside is around 3.25", cant see myself going any bigger than 2.75. im told by my mc tyre shop the m45 will be run out in aus soon,
Dlogic wrote:Splendid. This makes me think about updating my TIG welding system in order to be able to weld aluminum.
Dlogic my frame welders mainly do aluminum, there in big demand which is always a good sign but therefore a bit slow , which has motivated me into looking at a tig as well imagine 8) . there are some good tutorials on utube how hard can it be :D
http://www.youtube.com/watch?v=ZWJt3fFJ6Hk
My estimated frame weight will be close to 6.5kg i have over engineered the swingarm but that will future proof it if i up the power/ motor, if im right a bommer with vbox is 10kg so thats quite a saving.
Did you weigh your frame.
Dlogic   1 kW
Post by Dlogic » Feb 14 2014 3:34pm
Yup, my frame weighs 10,7 Kg including the Vboxx and swingarm.
A friend of mine works as an engineer and calculated the frames rigidity.
He told me that there´s about 2,6 Kg of steel that could have been saved.
But this makes for a super tough structure. At least it feels very sturdy. Nothing feels like it´s twisting or giving away under load. :mrgreen:
Did around 70 Km today in perfect weather. The Heidenau K65 tires are highly recommendable. With the power and speed this bike is capable of there´s no better tire. :-)
Emoto   10 kW
Post by Emoto » Mar 31 2014 10:17am
After being stalled 6 weeks swingarm is done but the welder wanted payment for the fix to his mistake :lol:
long story short ive got another welder, so i bored and aligned the bottom bracket tube and off to the new welder, the good news the turnaround was 24 hours i almost couldnt believe it, awsome! now i can get to work.
So machined bottom shock mount.
And here she is standing for the first time :D
Dlogic wrote:Yup, my frame weighs 10,7 Kg including the Vboxx and swingarm.
Just weighed my frame 6kg , i agree i also over engineered it a bit so hopefully no worries.
Emoto   10 kW
Post by Emoto » Mar 31 2014 11:31am
Also thinking on mounting my 18 fet like this busbar direct to frame :D im hoping it would be a cooler option using the frame as a large heat sink, than a common external mounted controler in its case. discussion here http://endless-sphere.com/forums/viewto ... =2&t=58474
