KMX tadpole trike with canopy, Windwrap, cromotor, 10KW
cwah   10 GW
Re: KMX tadpole trike with canopy, Windwrap, cromotor, 10KW
Post by cwah » Mar 15 2016 6:12pm
amazing
adam333   100 W
Post by adam333 » Mar 29 2016 9:21pm
The nice thing about the front suspension is that I have now the clearance to install some fat tire at the front.
Last year, Schwinn introduced a 20" fat bike for kids:
It was actually cheaper to buy the complete bike compare to only buy a set of wheels from Schwinn...
Sadly, the KMX hub number of holes didn't fit the fat rim. I had to build my own hub:
Once the new set of wheel is trued, it is time to install em on the bike for a test:
pucksterpete   1 kW
Post by pucksterpete » Mar 30 2016 10:20am
BAD ASS!!!
Optim Alp Hardtail with MXUS Motor
20S 2P Turnigy 5.0 Hard Case
Top speed 38mph tops :)
Hyena Special
http://endless-sphere.com/forums/viewto ... 97#p585997
Excelsior/Strong GTS with Cromotor
24S 3P Turnigy 5.0 Hard Case
Top speed so far 53mph
http://endless-sphere.com/forums/viewto ... =6&t=46993
dmwahl   10 kW
Post by dmwahl » Mar 30 2016 3:13pm
Now you're just showing off...
Frakentrike   10 W
Post by Frakentrike » Mar 31 2016 4:19pm
Wow, what an amazing machine Adam. Your engineering skills and precision fabrication are simply astounding. With all the CNC milling and 3D printing, is that what you do for a living or is it just perfection in your hobby!
I love your new suspension - Is bump steer and brake steer a lot worse now that the king pin axis doesn't hit the ground where the tire contacts the ground? Or do the new larger diameter wheels now bring the contact patch much closer to the king pin axis again? (hard to tell from the photos)
e-assist FrankenTrike homebuilt 1984
Current build: EATSRHPV E-Assist Tilting Full-Suspension Recumbent Trike
Build Blog: http://www.bentrideronline.com/messageb ... p?t=113645
Youtube Channel: https://www.youtube.com/channel/UCy5hIJ ... b3XYsXMlAw
adam333   100 W
Post by adam333 » Apr 01 2016 10:18am
Thanks guys :D
Frakentrike wrote:With all the CNC milling and 3D printing, is that what you do for a living or is it just perfection in your hobby!
I do mechanical design on computer at work and I have a CNC lathe and milling at home.
Frakentrike wrote: I love your new suspension - Is bump steer and brake steer a lot worse now that the king pin axis doesn't hit the ground where the tire contacts the ground? Or do the new larger diameter wheels now bring the contact patch much closer to the king pin axis again? (hard to tell from the photos)
On the 16" KMX wheels, the bike is really stable at low or high speed. But yes, on those fat 22.5" tire, I have a non zero scrub radius. The bike is definitively harder to steer and less stable at high speed. It also become important to balance the wheels.
Alan B   100 GW
Post by Alan B » Apr 01 2016 2:38pm
Very nice job Adam. Beautiful Trike.
I'd upgrade the motor controller to a Sabvoton or one of the other sinewave controllers, much nicer control on my Borg's Cromotor since I did that.
I'd also add a ham radio, with the trike you can carry stuff and have some radio fun! (At least while parked, the RFI is probably bad when motor is engaged.)
Enjoy!
Frakentrike   10 W
Post by Frakentrike » Apr 01 2016 6:24pm
adam333 wrote:On the 16" KMX wheels, the bike is really stable at low or high speed. But yes, on those fat 22.5" tire, I have a non zero scrub radius. The bike is definitively harder to steer and less stable at high speed. It also become important to balance the wheels.
That's a shame. Wouldn't want to hit a pothole or kerb at speed with one wheel I imagine. Direct steering no doubt gives you less leverage to handle the peak loads as well. Tricky.
So, I hope you have a matching green rim planned for the rear wheel just to get the look perfect? :-)
adam333   100 W
Post by adam333 » Apr 22 2016 6:40pm
The old flag "flapping" noise was really annoying.
I was told that making fringe in the flag with a blade would improve that. It is true, but the flag get ugly quickly.
I then made my own flag : ( new vs old flag )
Latest flag version completely noiseless:
adam333   100 W
Post by adam333 » May 30 2016 2:02pm
2.5 min video showing the trike in action with the 20 x 4.24" fat tire.
macribs   1 GW
1 GW
Post by macribs » Jun 01 2016 6:16pm
Love the new look, now its angry and mean looking with a wide stance. And in the dim light in the video that windwrap and those low hanging lights really make it stand out in a positive way.
Man that "flagpole" is a torn in my eye. Great looking trike, and then a flagpole in the back? A nice bright rear light would looks so much meaner.
As it is that pole kind of take away that bad boy look you got going there, flag poles kind of makes it mix of bad boy and accountant trike. :)
Those poles are mandatory? Like a fine if you get pulled over without one?
adam333   100 W
Post by adam333 » Jun 02 2016 7:13am
hehe, thanks :)
No, the flagpole is not mandatory, but the trike is so low that I almost got me killed 3 time from cars that "didn't saw me".
Since I have the flagpole, It is no longer an issue.
adam333   100 W
Post by adam333 » Jun 28 2016 8:36pm
New set of front wheel (lighter and more comfortable to ride with compare to the Fat 20x4.25 tires)
E-bike Tire 16x3.0
more details here: 16x3.0 E-bike tire review
Shane07   1 µW
Post by Shane07 » Oct 10 2017 2:25pm
Hi! What did you use to mount the cycle analyst? I'm looking for a solution on my kmx recumbent.
regards Shane
pucksterpete   1 kW
Post by pucksterpete » Oct 11 2017 2:26am
Shane07 wrote:Hi! What did you use to mount the cycle analyst? I'm looking for a solution on my kmx recumbent.
regards Shane
you might find something your looking for on this page
https://hostelshoppe.com/Bike-Accessori ... ory-Mount/
Hyena Special
adam333   100 W
Post by adam333 » Oct 11 2017 9:01am
regards Shane
I made this bracket in Black Delrin:
Then i tapped 2 holes on the KMX boom tube.
I can make another one if you are interested.
amberwolf   100 GW
Post by amberwolf » Oct 12 2017 2:46pm
adam333 wrote:No, the flagpole is not mandatory, but the trike is so low that I almost got me killed 3 time from cars that "didn't saw me".
That problem is why I abandoned my first (and only) lowracer build, and developed the semi-recumbent CrazyBike2 instead, and stuck with "car driver height" seats after that, simply to ensure visibility (and my ability to see around cars, rather than having to look under them ;) ).
Around here, the flags and such don't really work--if you can't be directly seen, you're probably just a "construction sign" or something that can be run over with impunity. :(
But if you're bike/trike is big enough they might hurt their car when they do it, they're less likely to. ;)
adam333   100 W
Post by adam333 » Jul 01 2018 12:23pm
My daughter is growing up. It was time to adapt the KMX to accept the Trail-a-bike.
pucksterpete   1 kW
Post by pucksterpete » Jul 02 2018 2:17am
Nice job, You might need some kind of mud guards on the back wheel of yours to protect her
Hyena Special
adam333   100 W
Post by adam333 » Nov 17 2018 9:14pm
Here is a few pics of the ABS Front fenders glossy finish 2.5mm thick I've made for my trike ( 16 x 3.0 with 160mm Disc brake rotor )
pucksterpete   1 kW
Post by pucksterpete » Nov 18 2018 1:59pm
Nice work man
Hyena Special
