KMX tadpole trike with canopy, Windwrap, cromotor, 10KW
MattyCiii   100 kW
Re: KMX Typhoon trike, cromotor, 10KW controller, winter des
Post by MattyCiii » Sep 28 2013 7:12pm
Amazing work, as always Adam. An inspiration!
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 32mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 39mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike. Based on a common power module using a NuVinci left side freewheel.
wojtek   10 kW
Post by wojtek » Sep 28 2013 7:14pm
Holy Moly! that is indeed a piece of art combined with perfect battery placement!
what battery solution are you going to go for? chemistry / v / ah ?
WIRES AND CONNECTORS
http://www.endless-sphere.com/forums/vi ... 31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Giant CRS Alliance - yes, just pushbike! frock you..
3Element Espire - SOLD
Custom built Specialized BigHit with BBS02 - SOLD
Velokraft e-VK3 SOLD
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
adam333   100 W
Post by adam333 » Sep 28 2013 7:30pm
Thanks Matt and Wojtek :D
wojtek wrote:Holy Moly! that is indeed a piece of art combined with perfect battery placement!
I will have 12 x LiPo Zippy Flightmax 6S/8Ah from Hobbyking combined in a 18S ( 75V )/32Ah pack.
clark   1 µW
Post by clark » Oct 13 2013 1:16pm
awesome work adam, absolutely professional.
would love to know your sources/info for battery box, specific wiring#, and connections/plug/switches.
would be a great writeup post of its own, great for serious newbies like me. i've been trying to find it on ES but haven't stumbled upon it yet. i'm probably not looking in right places.
a-line awesome as well.
adam333   100 W
Post by adam333 » Oct 15 2013 7:53pm
clark wrote:awesome work adam, absolutely professional.
thanks Clark :D
I started to scan the KMX with a 3D scanner then builded a 3D cad around it using solidwork. The battery box is custom made from my design and was 1050$ for the 4 pieces. ( Alu 5052-H32 1/16" for the top pieces and 3/32" for the bottom ). Finish was done with black powder coated paint. If you go that way, make sure to also have a clear coated powder paint on top of it.
All battery cables came from hobbyking, silicone 8awg. http://www.hobbyking.com/hobbyking/stor ... BLACK.html
I use the 5.5 mm conector from Hobbyking as well, good for 100+A. http://www.hobbyking.com/hobbyking/stor ... 20pc_.html
The key switch came from Digikey: CKL12BFW01-024-ND http://www.digikey.ca/product-search/en ... W01-024-ND
regular switches DPDT from Digikey: EG1890-ND http://www.digikey.ca/product-search/en ... maction=on
I used those component on previous bike and they never let me down.
It is always time consuming to build an E-bike, but the time and money is well worth it as you will enjoy the end result for years.
clark   1 µW
Post by clark » Oct 16 2013 10:49am
Cheers adam for info on battery plug and wiring. Sorry i looked at digikey and hobbyking, but couldn't find info about the 5 pin power outlet, fuse holder & which level power fuse do you use? Thanks again and in advance
adam333   100 W
Post by adam333 » Oct 20 2013 3:52pm
clark wrote:Cheers adam for info on battery plug and wiring. Sorry i looked at digikey and hobbyking, but couldn't find info about the 5 pin power outlet, fuse holder & which level power fuse do you use? Thanks again and in advance
np,
5 blade connector Female: 7184k33 Mc Master 29.81$
5 blade connector Male: 7184k31 Mc Master 22.62$
Fuse holder AGU Car Audio: Ebay 6$, http://www.ebay.ca/itm/181223189978?ssP ... 1439.l2649
As for the fuse, I used a 120A as the controler is limi0ted to 10 KW.
adam333   100 W
Post by adam333 » Oct 22 2013 9:32pm
Took me some time to figure it out, but here is the way to modify the controller to have the wheel go reverse direction.
Cabling is roughly 80 % done now.
adam333   100 W
Post by adam333 » Oct 27 2013 10:08am
A few update...
Delrin brackets to hold the controller in place behind the seat:
I wanted to have the throttle on the right side like a real bike, so I had to make a hole on the bar to pass the wires.
top bar adaptor to pass the wires while keeping it water sealed ( made out of soft rubber ), sealed with black silicone.
Right side handle with the 3 speed switch ( 30, 70 and 40 km/h setting ). Throttle with the green button to activate the break regen and the rear break handle.
Left handle with mirror, front brake handle. I'm still missing the switch to go foward/reverse.
I am now working on the LED flag while waiting for pieces to finish the battery wiring.
wojtek   10 kW
Post by wojtek » Oct 27 2013 10:44am
great work as usual
if you struggle with the dimensions of the contoller, I actually have source for much more compact one [half size] able to give you up to 10KW. Made in Poland from best possible parts/ components based on 4115 mosfets.
adam333   100 W
Post by adam333 » Oct 28 2013 11:00pm
Thanks Wojtek,
I would like to know more about the controller you mentioned pls.
I am now working on the LED flagpole design.
The LED sequence will be driven by an Arduino nano v3.0 @ 12V and I will use Mosfet to drive the leds modules. Power consumption is < 2.4W
Light on:
light off:
The intent design was to have 2 flagpoles like this, but I am now considering scraping this concept and rebuild a new one with a single Flagpole LED.
agniusm   10 MW
Post by agniusm » Oct 30 2013 1:42pm
Better get red/blue for sure everyone will slowdown :D
adam333   100 W
Post by adam333 » Oct 30 2013 2:00pm
agniusm wrote:Better get red/blue for sure everyone will slowdown :D
hehe, I thought about it, but it is illegal in Canada.
adam333   100 W
Post by adam333 » Dec 01 2013 2:25pm
finally some update on this bike.
Arduino Nano package to avoid unwanted spark in the battery box:
Installation of the battery heater modules:
12 x 8000mAh 6S LiPo packed in a box: ( 75V 32 Ah )
Rear fender installed as well with the functional chain:
Winter is cold, and less wind on the body will help.
WGX Windwrap adaptor for a KMX:
As per the law, the manifacturer must install an " assisted vehicule" sticker on the bike, so here we are: :wink:
No rear fender no windwrap look:
Another pic without the windwrap:
Now with the WGX Windwrap while being charged:
samoloh   10 W
Post by samoloh » Dec 02 2013 1:37am
U finally got it done, nice work
30mph Rebook 26" Hardtail, 9C hub motor, 48v 10Ah Lifepo4 12Fet Lyen controller
madin88   100 MW
Post by madin88 » Dec 03 2013 5:48am
this trike looks like a beast with this big tire :)
how does the battery warmer work (main battery?) and do you know how many watt hours it take to warm the battery from lets say 0 to 20 degree?
At my home we also have winter now and the battery sags a lot more than in summer. Less volts, capacity and so less usable watt hours.
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
charleyhaze   1 W
1 W
Post by charleyhaze » Dec 03 2013 5:53am
WOW! That is the coolest trike I've EVER seen! Nice man, nice.
adam333   100 W
Post by adam333 » Dec 03 2013 10:39am
Thanks guys :D
madin88 wrote:this trike looks like a beast with this big tire :)
All battery warmer pads are in series and they draw 70W on the battery. I placed in serie with my switch a module that will stop the current when the inside temperature go above 30 deg C. ( never happen in winter though ) The internal temperature is roughly 10 to 15 degree higher inside compare to outside. So far, I saw now sag at all. I also have 32 Ah available in this pack. ( I leave the heating on full time )
Positive points so far: stable on ice and snow, verry strong acceleration ( I feel pushed into the seat ), no sag with cold temperature, regen alone is verry eficient to stop the bike.
Negative points: Suspension is bad, front fenders are verry bad at stoping water, the rear of the bike slide on the side when using the regen agresively and it can be dangerous to flip on the side.
jateureka   10 kW
Post by jateureka » Dec 03 2013 5:18pm
That's a really beautiful, professional looking build with great attention to detail!
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
IRON DOG   10 mW
Post by IRON DOG » Dec 05 2013 1:10am
REALLY , REALLY , NICE !!!
Specially for the finishing touch on all and every parts :shock:
Please VIDEO , VIDEO , VIDEO
OH , by the way , nice sticker :wink:
Mark H   10 mW
Post by Mark H » Dec 08 2013 12:05pm
Epic build!
That is all ;-)
adam333   100 W
KMX tadpole trike, night time, winter riding
Post by adam333 » Jan 22 2014 2:19pm
thanks guys :D
Here is a short video of the trike in action:
( sorry about the video quality, we had several issues with the camera and I lost several frames )
I will make a new one with a beter camera.
jateureka   10 kW
Post by jateureka » Jan 22 2014 5:42pm
Nice vid, love the flashing light pole - makes it look like a police vehicle! Do people move over to let you past?
adam333   100 W
Post by adam333 » Jan 22 2014 9:25pm
jateureka wrote:Nice vid, love the flashing light pole - makes it look like a police vehicle! Do people move over to let you past?
thanks, actually, one guy in a car moved over and let me pass at night. I believe the flashing light was harassing him.
samoloh   10 W
Post by samoloh » Jan 23 2014 2:51am
nice ride, am so impressed, super neat build
