Cowardlyducks Commuter Build - E-bikeE
Chalo   100 GW
Re: Cowardlyducks Commuter Build - E-bikeE
Post by Chalo » May 18 2015 12:00pm
Kool Stop is the gold standard for rim brake pads. You want the "Salmon" (red iron oxide) compound.
Also consider adding a booster arch to stiffen the brake studs for improved braking response.
Cowardlyduck   100 MW
Post by Cowardlyduck » May 18 2015 7:39pm
Chalo wrote:Kool Stop is the gold standard for rim brake pads. You want the "Salmon" (red iron oxide) compound.
Thanks Chalo. Yes I've seen and used the Kool Stop pads before, but had forgotten about them, but your are right...they are very good. Thanks for the suggestion.
I've shortlisted a few options below....but don't really know what the difference is between them...anyone care to comment:
KOOL STOP Brake pad "Supra 2" Dual Compound
Kool Stop bicycle bike Eagle 2 II THREADED brake pads BLUE
Kool-Stop Mountain Threaded Post V-Brake Pads Salmon Wet / All-Weather Pads MTB
Kool-Stop Eagle 2 II Threaded Brake Pad Canti Salmon
Kool Stop Eagle Claw 2 threaded caliper SALMON bike brake pads bicycle mtb dry
Kool-Stop Mountain Brake Pads Threaded Posts MTB Bike Black/Salmon DUAL-COMPOUND
I think I like the last one's the best.
Any thoughts?
Cheers
Custom made 18650/21700 battery packs
Modified Stealth Fighter - Force air cooled motor @ 6KW, Adaptto Mini-E. 49AH, 52V 18650 - 2.5Kwhr
Cowardlyducks - Stealth Fighter Videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
Ebike Garage - My YouTube Ebike ramblings.
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
Ottodog   100 W
Post by Ottodog » May 18 2015 9:50pm
If you'd rather not deal with eBay, you can get them at Amazon.com as well with free PRIME shipping: http://www.amazon.com/s/ref=nb_sb_noss? ... Brake+Pads
Cowardlyduck   100 MW
Post by Cowardlyduck » May 18 2015 10:14pm
Ottodog wrote:If you'd rather not deal with eBay, you can get them at Amazon.com as well with free PRIME shipping: http://www.amazon.com/s/ref=nb_sb_noss? ... Brake+Pads
Thanks Ottodog. Just ordered them from Amazon! :D
I'm in Australia so don't get free shipping, but it was still cheaper for 2 even with shipping. :)
Cheers
Ottodog   100 W
Post by Ottodog » May 18 2015 10:17pm
Cheers
No problem CD. Glad it worked out for you. I'm always amazed at the sheer volume and variety of stuff they sell on Amazon. 8)
Alan B   100 GW
Post by Alan B » May 18 2015 11:32pm
Magura hydraulic rim brakes are said to be very good. Not sure if they would fit the bikeE or be worth the cost.
Let me know which pads you get, I should upgrade mine as well.
Cowardlyduck   100 MW
Post by Cowardlyduck » May 19 2015 12:07am
Alan B wrote:Magura hydraulic rim brakes are said to be very good. Not sure if they would fit the bikeE or be worth the cost.
I did look at the Magura hydraulic previouly, but have since come to realise they would not help much in my case. My front wheel does not have enough weight on it even when braking to need such a strong brake before it starts locking up and my rear has regen which is very effective when combined with the rim brakes.
The reason I needed new brakes now was because my rear ones have somehow gone completely slick...I don't know how it happened, but one day they were still 'good enough', then the next they became next to useless and I've been forced to use either the front or my feet for the last few kph when stopping as Regen doesn't work that slow.
Anyway, I bought the pads linked above by Ottodog:
http://www.amazon.com/Kool-Stop-Compoun ... Brake+Pads
I highly suspect they will be better than my current ones...I think my current pads are the original pads that would have come with the bike over a decade ago!
Cheers
Alan B   100 GW
Post by Alan B » May 19 2015 3:20pm
Will those fit both front and rear bikeE standard brakes? Mine screech badly and undoubtedly could be improved. Especially on the front.
Is the curvature of the small front wheel going to be a problem?
Cowardlyduck   100 MW
Post by Cowardlyduck » May 19 2015 6:17pm
Alan B wrote:Will those fit both front and rear bikeE standard brakes? Mine screech badly and undoubtedly could be improved. Especially on the front.
Good point...I may have just bought myself a spare set for the rear. ;) :lol:
Will let ya know. :)
Cheers
Alan B   100 GW
Post by Alan B » May 19 2015 8:30pm
Cheers
I was thinking the same thing. :)
StudEbiker   1 MW
Post by StudEbiker » May 20 2015 12:13am
Those are what I use on the rear.
tomjasz   10 GW
Post by tomjasz » May 22 2015 7:39pm
Based on the Guru above I went kook stop mountain pads. Great choice. Now I want to look at Magura hydraulic Rim upgrade.
Alan B   100 GW
Post by Alan B » May 22 2015 11:06pm
Check the mounts and spacing. Seems to me the BikeE had somewhat unusual brake mounts or clearances.
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 02 2015 8:52pm
I still haven't got around to mounting the Kool Stop pads, but it looks like they should fit both rear and front rims ok...just not sure about the mounts. :)
I'm continuing to have axle rotation issues. Last night I tried re-adjusting things for the 5th time in as many weeks, but on today's commute it's made no difference. :roll: :cry:
Basically, I can hear/feel a small amount of play in the axle when going from acceleration to regen, or vice versa. The torque arms seem to be catching the play, and preventing any catastrophic consequences, however it still loosens my axle nuts over time.
I've now tried locking the axle in full forward (clockwise) position and full backward (anticlockwise) positions. Last nights attempt was to pre-load one torque arm (non-freewheel side) clockwise and the other (freewheel side) anti-clockwise. It seems the amount of torque though it just too much, and any attempts to keep things in place is just eventually overcome every time.
I think I will buy some new nuts as the nylon on my current nylocks seems to have worn out a bit.
Any other suggestions welcome.
Cheers
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 02 2015 9:16pm
These are the nuts I've been using...
http://www.ebay.com.au/itm/Mercedes-22- ... 182832479?
Cheers
Alan B   100 GW
Post by Alan B » Jun 03 2015 5:02am
I use NordLock washers. One pair each side. Between the torque arm and the nut. I re-tighten them daily after a tire change, but after a few commutes they stop moving.
The NyLock nuts are not as good (though I use them elsewhere), and they need to be replaced often.
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 03 2015 7:32am
Thanks Alan. :)
Good idea, and I've just ordered some nordlocks. The combination of nordlock washer + Nyloc nut can't hurt, and at at this stage I'll try almost anything. :)
Cheers
Alan B   100 GW
Post by Alan B » Jun 03 2015 8:48am
I'd try a regular nut first with the NordLocks.
It does sound like there's too much play in the torque arms, that might need to be fixed. With the nut loose there should be almost no play. What part of the torque arms is allowing this motion? Can that be improved?
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 03 2015 7:37pm
Alan B wrote:I'd try a regular nut first with the NordLocks.
What makes you say that? Wouldn't the combo help each other?
Alan B wrote:It does sound like there's too much play in the torque arms, that might need to be fixed. With the nut loose there should be almost no play. What part of the torque arms is allowing this motion? Can that be improved?
It's quite hard to see as it takes some force to make it move...i.e. I can't normally get it to happen with the bike flipped over and the wheel freewheeling...so it's hard to know exactly what's moving. I 'think' it's the axle rotating slightly inside the rectangular flats of the torque arm block. This would make sense as the nuts loosen over time.
I don't really see how that can be improved without some tighter tolerance torque arms though. The V2 torque arms I'm using are the perfect fit as they can use the eyelets in the rear dropouts nicely...it's just a shame they aren't tighter around the axle flats.
Cheers
Alan B   100 GW
Post by Alan B » Jun 03 2015 10:27pm
The NordLock washers bite into the nut to hold it in place, not sure the nylock feature is going to help that. I'd try it both ways to see.
The best torque arms come too small and have to be filed slightly for a perfect fit, or they clamp solidly onto the flats with a flexure and clamping bolt.
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 05 2015 9:05pm
Brakes fit! Front and back! :)
Cheers
Alan B   100 GW
Post by Alan B » Jun 05 2015 10:20pm
Good fit. How do they work? :?:
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 06 2015 1:16am
Alan B wrote:How do they work? :?:
Just tested.
The front is great. Easily locked it up.
The rear is better, but still not able to easily lock up without squeezing the brakes quite hard. I may be able to help that by tightening up the cable somewhat. I loosened it right off when changing over the pads, so there is probably a bit of room to play before they start rubbing.
Overall, an upgrade well worth it IMO.
I may soon be finished my Solar setup also...I put some time into soldering up connectors, diodes and the DCDC converter recently. The hard part will be getting the wiring through the already cramped frame.
Cheers
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 08 2015 2:18am
My Solar setup is done at last!
The setup is as previously posted in multiple places in this thread, but to summarise it's:
-18W - 20.5% efficient 12V panel
-CC-CV - 5A capable DCDC converter
-2x Schottky Diodes
-Cheap '150A' Watt meter
Plus a bunch of JST 2.5mm connectors and 20AWG silicone wire.
I did a little testing today and it seems really solidly mounted. Doesn't move at all. Today was a really windy day and if ever the panel would cause problems with cross-winds etc, it would have shown up today. The position above is the second attempt. The first time, it was too low and the tops of my feet would catch the panel as I pedalled. That was fixed by moving it up as high as possible. The very top of the panel is a little obscured and I had to trim off the very top corners of the panel (but not the solar cells themselves) so my hands would still fit, but I don't mind if it makes it practical and usable.
The watt meter is only temporary. I will monitor how it goes and best sun tracking positions where I park it at work, then remove it as it doesn't look great, chews up a small amount of power and just isn't necessary normally.
The only other change I'm considering is trimming off the white edges. They don't seem necessary and I think the panel would look cool without the white bezel.
I also rearranged my rear reflector. It was previously mounted to the tail of the frame, but my backpack would sag over the end and cover the reflector making it useless. I found my rear mudguard was a bit too short and would still let some rain/muck flick up into the end of the frame. Adding the reflector to the end of the guard seems to have fixed that also. :)
It bounces up and down when I hit bumps...adding a bit of reflector dazzle so I'm seen even better by cars. :)
Cheers
Cowardlyduck   100 MW
Post by Cowardlyduck » Jun 09 2015 7:29am
Quick update on how this went today...
It seems my cruising watts has decreased by 50-100W. It's hard to quantify, but that's what I'm seeing...I guess the wind resistance really does add up. :)
Today was quite cloudy so I don't think it charged much. When I checked on it in my lunch break I saw the watt meter voltage drop as a cloud blocked the sun meaning it stopped charging. It seems to need mostly unhindered sun to charge at all.
I had to ride further than I have been and used a total of 13.05Ah today. Cells were down around 3.5V.
Prior to today I was hitting 3.5V per cell at around 12-12.5Ah, so it would seem the Solar managed maybe 15-25WH if I also factor in the reduced power consumption I now have at cruising speed.
This solar setup is turning out to be a double whammy for adding range. :mrgreen:
It also didn't cost a whole lot...all up I spent less than $150. :)
Tomorrow is forecast to be sunny, so hopefully a better charging result.
Cheers
