fellow
*According to wikipedia, "Interceptor aircraft (or simply "interceptor"), a type of fighter aircraft designed specifically to intercept and destroy enemy aircraft." This picture shows the complete e-bike with controller, batteries and everything.
Technical data:
U_charged=54.6V (4.2 V/cell). 13s Lipo hybrid, 48V nominal.
U_cutoff=45V(battery pack votalge)-5V(voltage sag)=40V LVC (3.1V/cell - 3.5V/cell)
I_max=17A
Main fuse: Littlefuse 0326015.MXP 15A, 125VDC, slow blow. (15A=4h continuous, 20A=1h continuous, 30A=5 to 60 seconds) to protect internal wiring.
Other fuses=down/diagonal tube pack (8+5 cells) 10A, Seat+top tube pack (6+7 cells) 10A.
P_in_peak=0,9kW.
P_out_peak=0,7kW at 75% efficiency
P_in_wheel_in_the_air=54W (1A@54V) @ full throttle.
Motor: Bmsbattery Q100H 201rpm 36V@48V / Aikema ZYJZ-100, ATF-U LT71141oil cooled. m=2.2Kg. Total oil volume is 80ml. 15.7:1 internal gearing.
Wheels: Schwalbe Nobby Nick 26" 57-559. Front 1.6 bar, Rear 1.8 bar. Schwalbe recommends 1.8 bar min, but it felt too harsh offroad.
Controller: Frankenstein S06S, upgraded to 6x IRFB4110bpf mosfets (100V rated). The original 68V mosfets are not suitable for 54.6V!
Charger: 54.6V, 2A. Charging time 3 hours.
Batteries: Panasonic NCR18650PF in 13s2p configuration. Chemistry is LiNiCOMnO2/Li-Manganese/INR/ICR/IMR hybrid. m=1.2Kg (45grams per cell x 26 cells).
Efficiency: 17.6Wh/Km
Range: 18km without pedalling, without external add-on pack.
V_max=32 km/h (30Km/h usable).
Total mass: Less than 17Kg.
Images attached below.
Technical data:
I_max=17A
P_in_peak=0,9kW.
