Giant dh team, with custom build frame
flua73   1 W
Re: Giant dh team, with custom build frame
Post by flua73 » Sep 15 2014 11:27am
The batteries have arrived lipo 24x4, missing only some contacts that are on the way. Made some "battery cover" in fake carbon fiber, was quite ok. Waiting for the new rear rim to come any day (original was damaged in transit) so it is approaching a test drive, should be fun ... :D :D
Giant dh custom alloy frame, cromotor v2, kelly kbl 96251, cycle analyst v3, lipo 24s 4p
my building threads http://endless-sphere.com/forums/viewto ... ustom+fram
Nyx, Adappto Max-e, cromotor 21s/16p :D
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 29 2014 1:02am
Awesome build! Well done!
http://ballaratebikes.com/
ridethelightning   1 MW
Post by ridethelightning » Sep 29 2014 3:50pm
that looks great. you must be so satisfied with that :D
let us know how the DNM forks feel...
dan974   1 kW
Post by dan974 » Oct 01 2014 2:34pm
yeah very good job ! appreciated !
flua73   1 W
Post by flua73 » Oct 02 2014 3:22pm
dan974, ridethelightning, Samd, ...
thanks for those positive comments, yes I'm getting satisfied. soon time for the first test run. Then it shall be sorted out before it is taken down and powder coated ....
Samd   1.21 GW
1.21 GW
Post by Samd » Oct 04 2014 3:43pm
Im about to do a similar job with suspension pushing on a point on the aluminium box.
Would you mind posting a photo of the stainless plate inside?What thickness did you use inside the 5mm ally?
flua73   1 W
Post by flua73 » Oct 06 2014 2:38pm
Samd wrote:Im about to do a similar job with suspension pushing on a point on the aluminium box.
Here you go, the plate is 8 mm thick. It probably works just as well with 5-6 mm, but it was a piece I "found" on my job ..
flua73   1 W
Post by flua73 » Nov 22 2014 4:36pm
A small update, has made a "splash gard protection" in polycarbonate for my kelly controller.The controller is purchased as "water resistant" but in the rain sprays water / mud straight to the contacts and connections, and it does not feel good. Could be solved with a longer front fender but I like this fender. Only details remain then it's time for powder coating. Have driven a lot recently and am very satisfied, every time you pull on the throttle, you become happy :lol: ..
toula.tomas   1 W
Post by toula.tomas » Nov 23 2014 7:54am
nice-looking...nice
flua73   1 W
Re: Giant dh team, kickstand modifikation
Post by flua73 » Dec 06 2014 1:37pm
kickstand or Not? it has been the question, on my second e-bike (specialazed big hit), I have a rear mounted kickstand has not managed any good instalation on this bike. So it ended with a converted kickstand, extended and + 12cm modified start stop angles. And strong magnet that fixes it in place when not in use. Now it only remains to paint it with black texture powder coat with the bike ...
IMG_2192.JPG[/attachment [attachment=0]IMG_2199 - Kopia.JPG
chucho   1 kW
Post by chucho » Dec 06 2014 2:32pm
love youre work!! Very very nice!
Someone who does not doubt is a danger to the rest
9c+24slipo+60A lyen12fets+CAv3+26"hookworms=Fun commute
Cargobike+9c+13s33Ah=Fun transport
Kona entourage+ gng+ 40A lyen12fets+CAv3=Fun crosscountry
Flux+adaptto Max-e+Mxusv2+19" shinko= Monster fun Any Way
bitcom77   100 mW
Post by bitcom77 » Dec 07 2014 2:22pm
interesting
I have tried various stands, but they either won't fit at all or easily break from the weight
if I see this right you used on L bracket and bolted it to the swing arm just behind the rear shock
flua73   1 W
Post by flua73 » Dec 10 2014 8:38am
bitcom77 wrote:interesting
Hi
I have had the same problem with finding a suitable kickstand, I ended up changing the whole profile / tube, the alloy to a stailess 10X20 mm which fitted after some adjustments. Then I got even change the angle up / down position, yes I have been using an L-bracket to mount just behind the rear shock, and finally I have secured it in the up position with a super strong magnet. Original spring works well but want to be sure that it does not come loose out in the bush ...
the magnet is behind cover spring for cabling
MAGICPIE3FOCUSPOWER   10 kW
Post by MAGICPIE3FOCUSPOWER » Dec 10 2014 4:44pm
Woowww :) nice man man! Very crafty! 8)
Do you have a close up for your chainguide system?
Nothing is perfect until I touch it...
flua73   1 W
Post by flua73 » Dec 11 2014 10:47am
MAGICPIE3FOCUSPOWER wrote:Woowww :) nice man man! Very crafty! 8)
Hi
Here you are, rear sprocket 16t White Industries ENO freewheel, front Rennen 52T. Maybe Schlumpf High Speed Drive in the future .....
Post by MAGICPIE3FOCUSPOWER » Dec 11 2014 12:27pm
Thanks!
Chainguide is home made? Yeah Schlumpf drive is all the way! but will it fit? is only only for 68mm BB?
flua73   1 W
Post by flua73 » Dec 17 2014 3:31pm
Started assembling after painting ......
soaresdacosta   1 kW
Post by soaresdacosta » Dec 17 2014 4:30pm
Top work, nice details. Professional craftsmanship.
Luís.
GiantEV   100 W
Post by GiantEV » Dec 18 2014 3:48pm
Very nice build!
How do you like your DNM forks?
flua73   1 W
Post by flua73 » Dec 19 2014 12:23pm
GiantEV wrote:Very nice build!
Thanks :D According to me it feels very well built and sturdy, no flex and looks fine. have not been driving so much yet, but a good front fork to a highpowerd e-bike build. Spare parts might be a problem, have not found any shop that provides parts, but in terms of price so +++
Post by MAGICPIE3FOCUSPOWER » Dec 19 2014 1:40pm
Yeah find this frame or spare is very hard :cry:
I know it is old skool now, but Iove the suspension linkage sytem 8)
Your Truvativ chainguide is modified?
flua73   1 W
Post by flua73 » Dec 19 2014 2:44pm
MAGICPIE3FOCUSPOWER wrote:Yeah find this frame or spare is very hard :cry:
Yes, the Truvativ chain guide remade on a judgment most points to suit 52T chain wheel, the suspension linkage sytem is nice, but extreme tight ...
Post by MAGICPIE3FOCUSPOWER » Dec 19 2014 2:55pm
Thanks!
What do mean by tight; very hard to get rear to shock work?
I will keep on looking for this frame, still my favorite frame for Ebike 8)
Have fun with your great bike 8)
flua73   1 W
Post by flua73 » Dec 19 2014 3:05pm
MAGICPIE3FOCUSPOWER wrote:Thanks!
what I meant by "tight" was that the rear suspension is that the space around the bumper is constructed to find very little room for other shocks than the original. And it's hard to find dampers that fit this framework today, or I'm bad at finding ...
Post by MAGICPIE3FOCUSPOWER » Dec 19 2014 3:12pm
Aaha yup!
:x
Where did you found your frame? Ebay?
