don27dog
- Joined
- Sep 18, 2012
- Messages
- 31
Setup Crystalyte Phoenix II 4840. 52v Lifepo4 20 AH battery
Here is what I am starting with
Next step was constructing a battery box
I then wrapped the box in 3D carbon fiber vinyl. The box is attached to the frame with 4- 5mm bolts for holding water bottles. The box is also held in place by and 1 1/2" U bolt around the head tube and 1 1/8" U Bolt around the seat post.
Here it is on the bike.
Next step is line the inside of the box with 1/4" foam around the battery and finish mounting the controller. Then on to the last hurdle. What to do with the dropouts. I ordered a set of Dr. Bass torque arms. They arrived very quickly and look wonderful but I am a little worried about the side with the rear derailleur.
I ordered dp420 epoxy which was recommended on the Dr. Bass torque arm thread. It should arrive on Monday so I am going to give that a try unless someone else has a better suggestion?
