crossbreak
Some pics of my last built. Did 4 bikes with mentioned motor and controller. Bought them from cell man. Works good.
The whole system is intended to be fool proof. As these bikes are commuters, they have to be reliable. So I chose components that are known to be reliable. The battery is somewhat oversized for the range aimed for (30km). The tires are puncture proof. The connectors can not be plugged in a way that anything would be damaged. Ther is a killswitch/ignition switch directly at the throttle, in case a malfunction of the throttle or other part of the drive system occurs
Fenders, Reflectors, side stands and so on make these vehicles usable and save in workaday life.
The charger is fan-less/noiseless, so the battery can be charged at work without being annoying workmates
A PAS sensor can be used for cruise control if a longer range like 60-80km is desired. The Cycle Analyst (CA) V3 has been setup with an Economy mode: PAS Power is limited to 1000W and PAS speed to 40kph (the throttle still works as usual up to 60kph and 4kW). Not really usable ATM since the brake cutoff switches at the brake levers are still missing. PAS cruise without these switches is a bit dangerous.
Major Parts:
Motor: 6T upgrade MAC from cellman
Controller: Kelly KBS48121X controller from kelly (without 70k e-rpm upgrade, it does >50k e-rpm without issues)
Cells: 13s7p Samsung INR 25R from nkon
BMS: OZ890 Smart BMS from bmsbattery, added 10pcs IRFB4110 MosFETs to make it handle 120A instead of only 20
Display: Cycle Analyst V3 DPS from Grintech
Charger: Meanwell HLG 240H 54 (fanless, 240W, weight is only 1.2kg, a full charge takes about 3.5 hours)
Bikes: 2xKona Stinky (2008 and 2009?), Giant XTC (2001), Centurion (2008)
1st step: Kelly soldering session.
I put on:
- CA-DPS plug: 6-pole JST-SM plug, the yellow wire was used for the thermistor instead of the speed signal from the hall sensors (which is not suitable for geared hubs)
cellman told me to do so, saves me one cable to the handle bar (the rest of the CA-DPS Plug is the same for the CA-DP plug. I had to open the CA V3 DPS and solder the yellow wire of the DP plug to the thermistor pin)
-0.25 m long AWG12 wire as external shunt ( I ran out of AWG10 and AWG8 was too thick/would have been too long for an 1mOhm shunt: AWG8 would be 0.5m @1mOhm) it drifts a bit with temperature ( up to 10%) better go fo Constantan if you want something really precise
- fuse for CA and lights
- killswitch plug: a 2-pole JST-SM plug
-XT90 plugs for the battery, shortened the wires
-4mm bulltes connectors with HXT connector insulation for the 3 motor phases, shortened the wires
-Insulated all remaining unused controller cables with heat shrink
-program the Kelly throttle settings, so it will accept the Cycle Analyst throttle signal 1V...4V (last picture below)
Major Parts:
I put on:
