Vector bike and frame owners.
Artur   100 kW
Re: Vector bike and frame owners.
Post by Artur » Oct 07 2019 1:23am
John1deere wrote:
Oct 05 2019 5:49pm
You guys lowering bikes while I try to make mine higher :lol: 1 thing I would like different is the seat. God that seat is awful. Im 170 pounds and my lower back rubs on the raised portion. Also forces to spread my legs because my thighs rub on the frame. Something like a motocross seat would be perfect, Something with same height the whole length to be able to slide on it just like a motocross and thicker to be further away from the frame with my legs.
I will take it into account! Thank you
Artur   100 kW
Post by Artur » Oct 07 2019 9:08am
jordanking515 wrote:
Oct 07 2019 7:56am
Hey bro , hope your well, I’ve got a problem with my ebike maybe you might be able to shed some light on for me I’m getting error 30h on my sabvoton set up? It seems to come on after the wheel spins on the spot for a second (loose ground or wet) I’ve got a hub motor and it seems if I do a hall test it resets until the next spin,
Any help or info would be greatly appreciated thanks
we dont work with Sabvoton controllers, sorry.
DasDouble   100 kW
Post by DasDouble » Oct 22 2019 5:33pm
John1deere wrote:
Oct 05 2019 5:49pm
+++++ Yes
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
Bg-electric-cycle   10 W
Post by Bg-electric-cycle » Oct 28 2019 7:36am
Finally some photos next step from 14s 18p to 21s 18p.
Sargenebike   1 µW
Post by Sargenebike » Oct 29 2019 6:11am
Hello!
I'm planning to build powerful e-bike for enduro frame. I have 36v 500w fat e-bike and it is very awesome too but sometimes i hope more power and more range than 30-40km.
If i will use the Qs205 motor with 72v can i get over 10kw power with it or should i rewind it? What controller and BMS you recommend for good performance and avoid over heating? I'm thinking to build battery for myself. Maybe it must have at least 40ah?
Thank you!
Artur   100 kW
Post by Artur » Oct 29 2019 6:37am
You asked many questions :) most of them answered on forum already. I can help you, send me your number and we can have short talk.
Artur   100 kW
Post by Artur » Nov 25 2019 4:29am
We have black Friday sale right now :flame:
Artur   100 kW
Post by Artur » Nov 25 2019 8:59am
Artur   100 kW
Post by Artur » Nov 25 2019 2:32pm
tylerstilla   10 µW
10 µW
Post by tylerstilla » Dec 01 2019 2:46am
Hey Artur ive put in an order just waiting for an email back. Thanks
Artur   100 kW
Post by Artur » Dec 01 2019 5:10pm
tylerstilla wrote:
Dec 01 2019 2:46am
Thank you, we will answer on Monday CET
tylerstilla   10 µW
10 µW
Post by tylerstilla » Dec 08 2019 1:20am
Quick question, can i use a Tapered DNM USD-8 Fork in the typhoon frame??
Legna199111   10 mW
Post by Legna199111 » Dec 10 2019 1:08am
I was looking at the cyclone 18kw for a while until I discovered the vortex frame! I was wondering with this frame kit what's the largest motor that can fit on here? I want to run a 32s pack at 80% for around a voltage of 108v however I do want the capability of using at 100% as well :twisted: https://batteryhookup.com/collections/g ... -batteries each parallel pack would only cost about 250 with bms and nick knacks :wink: I want a high top speed around 100 mph but I dont plan on using it for more than a few seconds :) pretty much need a drive train lol....what motor gear ratio and controller can handle this
Artur   100 kW
Post by Artur » Dec 11 2019 3:17pm
Legna199111 wrote:
Dec 10 2019 1:08am
please contact us by email info@vectorebike.com
Artur   100 kW
tylerstilla wrote:
Dec 08 2019 1:20am
yes
Post by Bg-electric-cycle » Dec 14 2019 9:48am
100mph what a rad idea. Do bring that to existence. :bigthumb:
Different Typhoon seat options would be a great. Particularly if those were slight extended and flat horizontal rather than at an angle. Although, appreciate maybe a reason seat remains at an angle to the vertical of ground.
My Vector Typhoon the works continue next week. I hope to extend the frame width 190mm and add 177mm BB axle. If the chain alignment prohibits a plan B & C are available. More on completion whenever that does happen. :D
Legna199111 wrote:
Dec 10 2019 1:08am
tylerstilla   10 µW
10 µW
Post by tylerstilla » Dec 24 2019 2:51am
Just received my Typhoon frame today! Very impressed with it so far! Having some issues with the headset though, theres a bit of play in it, any ways i can fix this? (edit.. Fixed now)
Malice   1 µW
Post by Malice » Jan 11 2020 8:16pm
Hey Artur I was wondering if u gut have this rack for the Moto seatImage
https://www.instagram.com/p/B6BGxJugQfa ... e4kj7zlakr
snejky   10 W
Post by snejky » Feb 01 2020 2:35pm
Hi. I need to know type of pegs, which is suitable for Vortex frame. Do you know? Thanks
Hertzelz   100 mW
Post by Hertzelz » Feb 03 2020 2:04pm
Hey guys. looking to extend my Typhoon 15mm each side, anyone has done an extension frame and have a CAD file to share?
Post by Bg-electric-cycle » Feb 13 2020 7:03am
Yeah, I’ve extend my Typhoon, 10mm each side and changed out the bottom bracket 177mm. Did involve grinding the left crank down.
Beyond 177mm is more complex as the chain alignment must be taken into consideration. I have a plan resolve the issue but as yet not ordered any parts to validate the idea.
Extra 15mm would be good I’m consideration of going wider than 10mm each side. For this to happen better to have custom fibreglass panels manufactured imho.
The cost of these spacers create a CAD was 100s of quid involved three D model scan insure perfect fit. Fibreglass I believe would be lesser cost. The next issue is the spacers reduce the turn circle. Custom fibreglass panel could hug the frame at this important area thus no reduced turning circle.
Hertzelz wrote:
Feb 03 2020 2:04pm
Post by Bg-electric-cycle » Feb 13 2020 7:13am
Now having extended the frame width was able to build King Kong battery a 21s 18p 60+Ah pack.
Been ramping up the voltage just rode at 86volt with the Kelly controller dialled down on battery and motor phase current less than 50%. Level three power switch is at 80%.
Battery has available a facility connect 21s of Deligreen active balancers.
King Kong. With 100amp AC breaker, Ant BMS 200amp 24s.
Post by Bg-electric-cycle » Feb 14 2020 2:27pm
Vector Typhoon, at EV charge station. Successful initialisation of charge station with RFID, card.
I’ve charged the pack several times with the Kelly controller live and experienced no problems. Also charged with the alarm activated and found no problems. The higher voltage up from 52v extended the remote range and loudness of the alarm.
Artur   100 kW
Post by Artur » Apr 15 2020 4:21am
Guys we are vorking on a new frame design. It is going to be a mid drive that can work with hubmotor or 4-5k rpm motor. With linkage suspension, and removable battery. It will be designed for around 10kw power and will have right geometry. We want to make it with pedals (you can remove them if you dont need them), and bicycle seat (moto seat will be as option) to make it look as a bicycle to avoid maximum attention :) What do you think? any advises or ideas?
scrambler   1 kW
Post by scrambler » Apr 15 2020 1:19pm
Great news Arthur. Below my hopes /suggestions, beyond the obvious.
Now that Neematic /UBCO has abandoned the pedal/pedal assist version you have an opportunity for something similar to their original design.
Key differentiating factor for a high power pedal assist mid drive:
  • Pinion gearbox 1.9XR for great gearing range without too many gears
  • Adjustable torque based pedal assist
  • Decently good looking design :)
Nice to have:
  • Removable battery
  • Different power modes to match local street restrictions
  • Programmable Regen on throttle
  • DC power source for lights option
  • Cell phone programmable APP
  • Gates Carbon Belt option
Looking forward to your new project.
